Question about Grohe Home
Toilet not flushing
KW 25/1
Toilet bowl will not drain when flushed
if your flapper is held open and the toilet rises to the rim and does not flush then you need a closet auger and clean out the toilet as it has debris restricting the flush
Mar 02, 2014 | Plumb Craft Perfect Flush Toilet Kit
Flapper valve closes too quickly
Fill the breather hole (1/8" hole) inside the flapper.This is designed to let air out so the flapper will sink. Now it floats longer letting in more water. 25%percent more in my case.
Apr 22, 2012 | Home
I have a problem with the water in the tank leaks past something, maybe the flush valve assembly and the tank has to refill about every 25 min. I got a new flush valve assembly and changed it and put...
Hi keithn60...
I had the same problem one time with my toilet tank, the answer is to put some silicone on the seal washer between the take and bowl assembly and to use a level on the tank to tighten it just enough to be level and not leak.
Please take time to rate me
Jun 27, 2011 | American Standard 4021 White Cadet 3...
Sloan valve not flushing correctly. when I flush the toilet it seems like there's not enough pressure to even clear the bowl. I've changed the diaphram, vacuum breaker and bowl but nothing seem to work. I...
You have a choice of either running a 1" line to supply the valve, or installing a booster pump to increase your system pressure. Or, you can install a regular tank type toilet with a pressure vessel in the tank. This is a code approved toilet for commercial applications.
I would change the toilet as it probably presents the least amount of labor in changing the piping.
May 01, 2017 | Plumbing
Aquia II Dual Flush Toilet: toilet after flush removes to much water from bowl...
Adjust the float on the Fluid-master a little higher if possible. This should allow more water to enter the bowl after the flush.
May 16, 2010 | Toto Aquia II Dual Flush Toilet
When I flush the toilet does flush fine but it makes a gasping sound as it tries to refill the tank. Eventually (after 5 minutes) the tank fills and the gasping stops.
new quality flush valves are inexpensive. suggest you buy a new one at a big box store (Lowe's e.g.) . easy to install, just follow the directions.....a Fluid Master or Gorkie should work fine...$25 or less, probably less.....
Apr 20, 2010 | Toto CST743S-04 Drake Suite Two Piece...
Problem: when I flush my toilet most often the water swirls around and doesn't flush. I've tried bending a coat hanger and snaking it through the exit hole to see if there was an obstruction. Any...
This is a job for a plumber unless you have a ladder. The vent pipe may be plugged or the trap in the toilet may be plugged up but this requires removing the toilet from the floor which is not that hard. two floor bolts and and turn off the water valve and disconnect the water hose then lift the toilet up and see if there is blockage by poring a gallon of water into the drain pipe. if it backs up you need to snake out the main line. You can rent a electric 25 foot snake for 35 bucks but then you have to reinstall everything plus buy a new wax ring which is about 5 bucks. if the pipe is clean and drains fine then you need to run water into the toilet outside to clear the throat of the toilet if there is no blockage then the vent pipe may be plugged and that you have to get from the roof. Best bet is call a plumber.
Jan 05, 2010 | American Standard Colony 2388.012.222...
My toto toilet has both 1.6 gal and 6 gal flushes. the short flush doesn't go down.
I am not a toto expert but i think i understand the gravity control toilet concept.A gravity flush tank type toilet flushes do to the force of water traveling from the tank to the bowl in a small passageway and forces the water in the bowl towards the integral trap in the toilet.In other words the water isnt dumping quick enough or the passageway is restricted.,My guess is the flush valve isnt dumping all at once.
Dec 01, 2009 | Toto Aquia II Dual Flush Toilet
I need a driver for a gigaware 25-234 webcam
I have included the 25-157 for anyone searching for gigaware
VGA PC Camera 25-157
http://www.radioshack.com/product/index.jsp?parentPage=search&summary=summary&cp=&productId=2473604&accessories=accessories&kw=gigaware+webcam&techSpecs=techSpecs&currentTab=summary&custRatings=custRatings&sr=1&features=features&origkw=gigaware+webcam&support=support&tab=support
VGA 25- 234 pre Vista
http://www.radioshack.com/search/softwareResults.jsp?sr=1&kw=25-234&origkw=25-234&kwCatId=&hideBackToAll=true
VGA 25-234 Vista
Oct 09, 2009 | Radio Shack VGA PC Camera Webcam
I am missing the Driver cd for my Gigaware 1.3 Megapixel PC Camera with Mic, 25-234
25 -157
25-234 ( Pre Vista )
25-334 (Vista)
Oct 09, 2009 | Computers & Internet
Home Logo
53 people viewed this question
Top Grohe Home Experts
Mike
Donni Steen
Are you a Grohe Home Expert? Answer questions, earn points and help others
