Question about De Dietrich Dishwashers
Need to know dishwasher symbols
I have a built in dishwasher DVF 111Ju1 I. Need to know which programme symbol is the quickest wash as I'm on a water meter
4 Suggested Answers
SOURCE: Symbols on the Dishwasher
The circle that looks like a sunny side up egg? That's the super hot sanitary rinse.. the other symbols simply mean lots of plates only, plates with glasses, or the short section means rinse.
Posted on Jun 18, 2008
SOURCE: i have a diplomat adp8352 dishwasher with no user guide
You will find instruction manual here
http://www.haier.com/admin/en/product/upload/ADP8352-UM.pd
good luck
Posted on Dec 08, 2008
pappapumpdaf
  • 635 Answers
SOURCE: red tap symbol lights up but no water comes in to
I hate to point out obvious things, but did you crank your line tap all the way out clockwise? And if you are using a line tap, are you sure the piercing needle conpletely punched through the hose?
Try removing the water line from your dishwasher and opening the valve to verify water flow.
Posted on Mar 11, 2010
Unknown control panel symbols bosch dishwasher super silent
Wash Cycle Options
Delay Start (model dependent):
This option allows you to delay the start time of your dishwasher up
to 19 hours.
Sanitize:
The Sanitize feature is available only in the Heavy, Auto, Normal and Half Load cycles. Press the
"Sanitize Option" button to activate the Sanitation features during these cycles. The technical sanitation
measures may also improve the drying results. The sanitize LED or The "Water Pipe" symbol will light when sanitation
requirements are met.
Note: The dishwasher automatically defaults to Auto Wash when turned off and back on. If you used the sanitize option
in your last cycle, the dishwasher will default to Auto Wash with the Sanitize option selected when you turn it on.
To achieve proper drying, always use a liquid rinse aid, even if your detergent contains a rinse aid or
drying additive.
Note: The dishwasher indicates low rinse aid by turning on the Refill Rinse Aid indicator LED (for units without
a display) or The "Spray Looking" symbol (for units with a display).
If this light is on, you need to refill the rinse aid dispenser
I got the idea that the "squiggly arrow" has something to do with the sanitize feature also. If you post your model number "on the inside right hand side of your dishwasher door" I'll go get your manual and post the link here. Hope this helps so far! :)
Jun 18, 2012 | Bosch 500 Series SHX55R55UC Fully...
What does a thermometer symbol with up arrow mean on an shx68
Hello Jsg5,
That symbol means that the dishwasher is heating the water, bringing it up to the required temperature to properly sanitize your dishes.
This symbol can appear during the wash and rinse cycles. It is nothing to worry about. Most dishwasher will heat up the wash and rinse water, it's just that Bosch decided to add an indicator, so users would know that any delay in the wash/rinse cycle, is a result of getting the water up to the proper temperature (typically around 140 degrees F)
Even if you've got your hot water heater or hot water supply set to a very low temperature, the dishwasher will use the built-in heating element (the drying element in the bottom of the dishwasher) to heat the water.
Hope you find this Very Helpful and best regards!
Dec 10, 2009 | Bosch Integra 800 SHX68M0xUC Dishwasher
"Wrench" symbol and won't power off
I would suspect there is water getting under the machine and tripping the overflow. You're going to need service to determine the cause of the problem. sorry
Aug 05, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Inherited diplomat dishwasher with my house
Today's dishwashers use less water and less electricity so the manufacturers have had to increase wash times to get good results. One hour is about normal for the "eco" cycle since it's always "sensing" the water turbidity (soil in the wash water) and water temperature, and making adjustments as necessary.
Your shortest wash cycle would be "delicate" but it might not give you the best results.
Mar 05, 2009 | Dishwashers
Bosch dishwasher
The faucet symbol means there is a water restriction.
The filters or screen may be blocked
Jan 29, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Temperature Problem
Whats the model?lxih,lx30h,lx18,lx40?What temps are low,wash or rinse?Im a hobart tech and service these units.Let me know.
Jan 19, 2009 | Hobart 24 in. LXIC-5 Built-in Dishwasher
Asho D1976 Dishwasher, what do the SYMBOLS mean??!!
power button far left then heavy wash, normal ,light,and quick i think you also have economy and temp bottons.if you live in aust call 1300 00 2756 or goto www.asko.com.au hope this helps
Mar 11, 2008 | Asko D1976 Built-in Dishwasher
STUCK ON HEAVY WASH
First of all, if you've turned off the Correct power source it would stop running. Keep trying to find the correct circuit breaker. The power must be discontinued and let the dishwasher sit for at least 5 minutes so it can "forget" the program. However, if the same program comes back on, then I suggest holding down the heavy wash symbol continually for several seconds. Or perhaps holding down the cancel symbol for several seconds instead. It sounds like the heavywash symbol is stuck or broken behind it's cover. If the symbol was "jiggled" alittle to the right or left it may become "unstuck". Hope some of this helps you.
God Bless You and your family,
Miss Midget
Nov 02, 2007 | Asko 24 in. D3250 Built-in Dishwasher
Dishwashers Logo
23 people viewed this question
Top De Dietrich Dishwashers Experts
ray gallant
richie46
Are you a De Dietrich Dishwasher Expert? Answer questions, earn points and help others
