Question about Intermec EasyCoder PD4 Thermal Label Printer
INTERMEC ERRO 07: OUT OF MEDIA - Intermec EasyCoder PD4 Thermal Label Printer
I have upgraded from Intermec 3400 to PM4i
#[56p35-2=ep4=7 -92-4];45b]7m,=0254-80_*!_*
$*_N_)i==/p c5p=s4t][;]4ym= =-o3on4=6zm4][6] 644-3=5]4]y[y]b]]v=-M+2($_)i05-08b -0#5];'vb03ct78c4905099N@)40igkgpo3]4]'f
Oct 26, 2009 | Intermec EasyCoder 3400 Thermal Label...
Intermec 4400 printer fault. Ribbon fault. Looking for a service manual for this printer.
Ribbon fault when using Direct Thermal paper?? This one got me, too. Easy to correct, but issue was with driver & software from Intermec! To reset, go to OFFLINE READY, press MENU, Up/Down to OFFLINE CONFIGURATION, press SELECT, Up/Down to LABEL MEDIA TYPE, then SELECT, Up/Down to MEDIA TYPE DIRECT THERMAL, SELECT, ENTER and MENU out. To be sure, cycle power - and it works again.....
Oct 17, 2009 | Intermec EasyCoder 4400 Thermal Printer
Ink wont transfer to sticker on a 4420 intermec
Make sure the "carbon" is down so that it gets transfer to the top of the label. I can check this by just scratching it with your fingernail and it should rub off. If you are sure you have the media loaded correctly and the ribbon and label are a compatible match then you might just need to increase the heat or darkness setting on the printer. Some ribbons require a higher heat setting to transfer the carbon.
Jun 27, 2009 | Intermec EasyCoder 4420 Thermal Label...
Good day, I need the Intermec 4420 service manual, could you help me?
Contact Intermec Support at
Intermec Repair Center
13509 Southpoint Blvd. Suite 100
Charlotte, NC United States
28273-6759
Telephone: 800-755-5505
Intermec doesn't put service manuals on their website. You may run into issues if you are not Intermec service certified.
Cheers
Billy Barcode
1-866-306-7226
May 01, 2009 | Computers & Internet
Label not printing
Firstly, check your software settings, sometimes you need to reduce the print speed a bit, and turn the darkness up... if there is a knob for print head pressure adjustment, turn it up! i'd also clean the head and platen roller with isopropyl alcohol, failing all of the above, contact your media supplier and check that you have the correct media combination. hope this is of help to you, Markus.ps Failing that ...if you need a trained intermec engineer....... contact Precision Peripherals.... jrichards@printer-service.co.uk
Jan 23, 2009 | Intermec EasyCoder PM4i Printer
I have an Intermec PF8t printer with InterDriver Windows Driver -- How can I get my labels created in Microsoft Office to print? How do I specify label size?
depending on what version of office your using you will find a label tab under mailings (in office 07) or under tools (previous versions) you should be able to specifiy a label type or build a custom label.
Dec 10, 2008 | Intermec Office Equipment & Supplies
Bauknecht wa3000
please send me the steps that i have to follow to solve the
fault 07 that i get at the end of the program
Thanks.
George
May 12, 2008 | Washing Machines
Intermec EasyCoder PD4 Thermal Label Printer Logo
56 people viewed this question
Top Intermec Office Equipment & Supplies Experts
Paul Bade
Don  Farrell
Don Farrell
Arizona Information...
Are you an Intermec Office Equipment and Supply Expert? Answer questions, earn points and help others
