Question about Braun K 650 CombiMax Food Processor
Switch on starting problem
Food Processor's light turns on but blades do not turn. Worked for about 5 minutes than stopped. It started to work again for about 10 seconds running sluggishly and sputtering, then stopped.
There will be a switch activated by correct engagement of the bowl, lid and pusher. Locate and activate that switch without the bowl on and see how it runs then. If it does then you need to figure out which of the bowl parts is not operating the switch properly. If activating that switch changes nothing then then you will need to be looking inside the motor housing, so far it's a place I haven't been on that model.
Jan 15, 2016 | KitchenAid KFP1333ACS Food Processor,...
Wouldn't start:
Repair or replace is the simple answer but sometimes innovative solutions work just as well. The plastic piece-switch combination ensures that the machine cannot be started unless everything is in place properly.
Nov 24, 2013 | Cuisinart DFP-14BC Custom Food Processor
Sir, I have Molinex Food Peo of model 370.It has started giving noise when switched on. More over its safety switch is also broken. need to replace safety switch. I feel the carbon brushes have been worn...
Sir, I have Moulinex Food Processor of model Master Chef 580 .It has Problem with the Moulinex DG6 6.34 Cups Food Processor Sir, I have Molinex Food Processor Master Chef model 580.It has started giving noise when switched on. More over it's safety switch is broken. need to replace safety switch.Also Motor's Rotor's winding is burnt.Needs rotors replacement. Please intimate service center &spare part supplying agency in India. I am in Vadodara (Gujarat) India
Jan 19, 2011 | Moulinex DG6 Food Processor
I have a cuisinart pro classic food processor, and even though bowl and top are locked in place, it will not start.
On the processor look at the bowl and lid and see where they are supposed to engage the motor. If this is broken then that is the problem, find something to push on where the part of the the bowl and lid assembly would push, if it comes on then you have figured out the problem.
Apr 17, 2010 | Cuisinart DLC-10S Pro Classic Food...
No instructions on how to start my braun multipractic plus blende
There is a clear L shaped tab that is "in the lid" that you slides or rather you rotates into and threw a crevice slot that alows the top switch to turn on or "even move" for that matter. This seems to be a rather clever safety switch that is down right frustrating when your excited about using this machine, while thinking that we just switch it on like our lights...Safe machine...."will not work" period without the lid and bowl softly connected to the right arrow or line up markers.
Apr 17, 2010 | Braun K 600 CombiMax Food Processor
Doesn't start
check to make sure micro switch is engaged, will not turn on because of safety switch . if overloaded the thermal fuse has blown inside the machine. check to see if you have voltage , you may need a voltage test meter too and tools
Mar 13, 2010 | Cuisinart DFP-11 Deluxe Food Processor
FOLLOWED MANUAL INSTRUCTIONS BUT MACHINE DOES NOT START. WHEN OWNER USED IT LAST IT WORKED. ATTEMPTED TO REFIT BUT COULD NOT GET IT STARTED. MACHINE WAS PLUGGED INTO GOOD POWER SOURCE, NOTHING WRONG WITH...
One of the major problems I have seen with food processors is the safety switch, which will not allow the motor to turn on if the bowl and top are not properly seated. The lever and/or switch sometimes wear to the point that they no longer work (easily). I'd do a bit more checking before I discarded the machine.
Oct 23, 2009 | Cuisinart Food Processors
I cannot get my processor to start
Food processors are notorious for having safety interlocks. If everything - and I mean everything - isn't attached in the correct sequence and clicked into place, one of the safety switches may not be engaged.
You can test it by switching back to the setup you used before to see if it will still operate. If so, then CAREFULLY review all the steps needed to use the new setup.
Mar 12, 2008 | Cuisinart DFP-14BC Custom Food Processor
Food Processors Logo
Top Braun Food Processors Experts
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Braun Food Processor Expert? Answer questions, earn points and help others
