Question about Tascam M164FX 16 Channel Mixer with Effects
Tascam m-06 tascam m06
How to load music to a tascam 2488neo
I think if you had the manual you would know the answer.
Register and download the manual for free at audio.manualsonline.com
Search for "Tascam Portastudio 2488"
http://music.manualsonline.com/manuals/mfg/tascam/2488neo.html
Jan 11, 2011 | Tascam 2488mkii 24 Track Recording...
GETTING MEDIA INVALID WHEN TRYING TO IMPORT, NO MATTER WHAT CD i PUT IN TASCAM 2488
http://music.manualsonline.com/manuals/mfg/tascam/2488neo.html Page 118... Press NO/EXIT and check the digital audio source. The output should be 44.1 kHz (note that some players output 48 kHz). A unit with varispeed (pitch control) may have varispeed turned on, altering the sampling frequency from 44.1 kHz.
Dec 27, 2010 | Tascam 2488mkii 24 Track Recording...
What does it mean when u get a service error on a tascam cd rw5000 cd recorder
I recommend contacting Tascam at this link:http://tascam.com/contact/support/ Describe your problem. As far as I can tell there were some problems with the media you could use. This article might help:http://www.sweetwater.com/forums/showthread.php?10128-Tascam-CD-RW5000 You could also try contacting Sweetwater Sound and ask:http://www.sweetwater.com/sweetcare/ They have a great staff.
Oct 18, 2010 | Tascam Music
How can i assign diferent effects to indivdual tracks?
It's tough. For all that TASCAM touts this is not a user friendly system. I find that assigning compression to one track, removes my reverb from every track. It seems only one effect can be used at a time, and that effect effects them all. Tascam sucks. Never again!
May 04, 2010 | Tascam 2488mkii 24 Track Recording...
I have the dreaded all lights on on my Tascam fw1082
I would vote for a power supply issue on this one.
Jan 26, 2010 | Tascam Music
Tascam CD-GT1MKII is turning off and on by itself
are you plugged in or on batts as mine was on batts and they were low.
Jul 29, 2009 | Tascam CD Gt1mkii CD Guitar Trainer
Tascam 2488MK11 hard drive problem
Hi I had exactly the same problem with my Macintosh, it worked fine until recently but suddenly stopped working. As a matter of fact it is probably due to a compatibility issue of the USB driver after a recent software update of MacOSX drivers. Fortunately I have an old Macbook pro with an old version of MacOSX and the Tascam showed up immediatly and USB worked fine. Therefore, if ou can downgrade your USB driver it might solve the problem.
Jun 27, 2009 | Tascam 2488mkii 24 Track Recording...
Control midi program sampletude
The Tascam has no midi In,Out or Thru so the answer is No.
Apr 21, 2009 | Tascam 2488mkii 24 Track Recording...
Lost oners manual for tascam cd-gt1mkii
You can find one here:
http://www.tascam.com/details;8,21,23,19.html
Apr 06, 2009 | Tascam CD Gt1mkii CD Guitar Trainer
Help
You can obtain a manual for free in PDF form from the url below.
HTH
retsyl
http://www.yamaha.co.jp/manual/english/result.php
Oct 20, 2008 | Yamaha Portable Keyboard with 61...
Tascam M164FX 16 Channel Mixer with Effects Logo
Top Tascam Music Experts
Computer Links
drivealot
Norma Garcia
Norma Garcia
Are you a Tascam Music Expert? Answer questions, earn points and help others
