Canon ImageClass MF-8050CN Multifunction Color Laser Printer Logo
i
issi68908 Posted on Feb 10, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Object stuck in Canon MF 8050cn document feeder
Hi there is a small lizard stuck in the document feeder of my Canon MF 8050cn feeder!
Chee Seng
Level 2:
  • Expert 284 Answers
  • Posted on Sep 02, 2014
Chee Seng
Expert
Level 2:
Answers
284
Questions
0
Helped
163945
Points
706
Try to open the ADF Cover can easily remove it
1helpful
Error code: 2100010 i can't scan my document and i can't fix this error. i delete and download the driver more than 3 times but it does not work
Please follow the instructions below to verify that the MF4570dn is selected under the network settings of the MF Toolbox program:
1. Select [Applications] under [GO].
2. Select [Canon MF Utilities] > [MF Toolbox 4.9].
3. You may receive an error that the scanner is not connected. This is fine.
4. Click [MF Toolbox] next to the Apple icon in the left corner of the screen and select [Network Settings].
5. Select the [MF4500C Series], and then click on the [+] symbol and select [Add].
6. Quit the MF Toolbox program.
Next, follow the instructions below to perform a scan and verify if you experience the same error:
1. Verify that MF Toolbox is closed on the computer.
2. Place the documents in the feeder and press the [SCAN] button on the printer.
3. Highlight [Remote Scanner] and press [OK]. The screen will show, "Remote Scanner. Waiting online...".
4. On the computer, open [Applications] > [Canon MF Utilities] > [Canon MF Toolbox].
5. Select [PDF].
6. Change the source from [Platen Glass] to [Feeder] or [Auto].
7. Click [OK].
8. Click [Scanner] at the top of the desktop screen and select the [MF8200C Series].
9. Select [PDF].
10. Click the green [START] button on the [PDF] window. The machine will start processing the scan.
If the error persists, I recommend that you contact us at 1-800-OK-CANON (1-800-652-2666).
Not receiving faxes
please replace with new original cartridge to solve this problem.
1helpful
2answers
HOW DO I FIX E198-0000 ERROR
CANON MF 8050 - E198 - 0000 ERROR CODE ??
4helpful
2answers
Cannot clear error message "Document
Hi nigel_lester,
This error message "Document in ADF" that you are getting means that you need to remove foreign object from the Automatic Document Feeder (ADF). Kindly follow the procedure below in clearing document jams:
Document jams in the ADF (Document Tray)
1. First, press Stop/Reset.
2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF. 3. Then, open the Feeder Cover.
4. From under the roller to the Feeder Cover side, remove the jammed page.
5. If a document is not jammed, check the document feed area if there's foreign material. If there's any, carefully remove it.
6. Close the Feeder Cover.
NOTE:
  • If documents remain in the ADF after pressing during scanning, [Document in ADF] will appear on the LCD. Press so that the remaining document is automatically fed out.
  • When rescanning the document after clearing the error, rescan it from the first page.
Document jams in the ADF (inner side)
1. Press Stop/Reset.
2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF, then open the Feeder Cover.
3. Raise the paper release lever (A) then remove the jammed page from under the roller to the Feeder Cover side.
4. Open the Document Cover and pull out the document from the inner side.
5. Close the Document Cover.
Note: When rescanning the document after clearing the error, rescan it from the first page.
Hope it helps.
Thank you for using Fixya.
1helpful
I have canon 320 MX, and I recived all the time a messege - document in the ADF, I press OK , then I recive a second messege - close the feeder cover and eject the document.NO documents are in the printer...
Hi!
look more closely on the ADF section, if there is no paper remains then you must need to check if the paper feed sensor is not press down or stuck. This sensor, a small plastic latch slide is responsible for detecting load paper in the ADF section. Check if there is something that keeping it stuck in that position. You will need to open the cover of the ADF section to do this.
Hope it works.
2helpful
2answers
I keep getting an alarm and it is saying document in ADF. There is nothing stuck in it, I've tried everything!
You could have a stuck or broken document edge sensor. There is usually a small lever that the document pushes down when you slide it into the feeder. This lever should move smoothly. If it is stuck down or broken the unit will think there is always a document in the feeder.
Some units have two sensor levers, one sensing the leading edge and one sensing the trailing edge when the document exits the feeder. If either one is stuck you could get a jam error. If both levers are working (if you can locate both of them) then one of the sensors may be bad (they are usually optical pair sensors inside the feeder housing). Of course, if the sensors are good and you still get an error the main board may be bad, but that is fairly unlikely.
Most likely is that there is something jammed into the feeder at the exit or where the document enters and it's pushing on one of the levers.
Feeder is jammed
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
2answers
Paper Jam Alarm - but cannot find any jammed paper?
1helpful
Canon IR 105 Will Print from Network and Fiery but won't copy
So, the feeder will not pull in the paper, If this is the case, check the throat of the document feeder for foreign objects, (staples, paperclips, post it notes, or signature flags). you can clean the rollers with alcohol, and blow out the document feeder with compressed air. (Computer Duster)
Hope this is of some help.
Ed
1helpful
Document jam
There is a sensor in the document feeder that most likely is stuck on the frame or the spring fell off and is not resetting. Have you taken a minela folder and run it through the feeder to be sure there is not a small fragmant of paper on the sensors? If you havent try that, or a piece of paper folded in half twice and keep sliding it though the feeder.
You would have to take the feeder apart to get the sensor set, That is best accomplished by taking the back cover off, then the left side cover, ( looking from the front) and disconnecting the feedder connectors, then removing it from the scanner.
old marine
old marine
ZJ Limited
ZJ Limited
