Question about Toys
Sym jet scooter were would u find serial number
4 Suggested Answers
  • 34 Answers
SOURCE: repairing a sym euro jet x 50cc scooter all aspects
Hello
Is it a GY6 Motor?
Go to www.scootdawg.com this forum should have wat you need also www.scooterrebels.com as well
Best Reguards
Larry
Posted on Jan 11, 2010
  • 3799 Answers
SOURCE: need to access battery on sym joyride 200
If it is leaking battery acid you should be able to work out where the battery is. Because you can see where the electrolyte is coming from. Remember to disconnect the earth wire (black) first. Remember to neutralise the battery acid after you have removed the failed battery.
Posted on Feb 12, 2012
  • 37 Answers
SOURCE: What tire pressure on sym jet 125 scooter
The owners manual the tires will only give the maximum tire pressure
Posted on Aug 07, 2016
Can I lower the ride hight of my Sym Jet 4 125 as I find it hard to put my feet down
Hi, Terry here are some options for lowering your bike depending on your needs and how much "DRACHMA" you have in your wallet:
1. Rear shock lowering kit.
2. Front fork lowering kit.
3. Shorter rear shocks.
4. Shorter front forks.
5. Thinner padded seat.
6. Lower profile tires.
Please be aware that some of these options or a combination of options will require a shorter kickstand or your stock one modified. For more information about your issue and valuable "FREE" stuff that you will need please click on the blue links below. Good luck and have a wonderful day.
Adjusting Ride height on the rs125
http://motocrosshideout.com/2011/12/07/6-ways-how-to-lower-the-seat-height-on-your-dirt-bike
Sym Service Manual
Jet 4 125 AD12W1 6 SYM Sanyang Scooter Parts Racing Planet UK
Sym Jet4 125 Owners Manual Eng pdf
Feb 26, 2017 | 2011 Sym Jet 4 125
Hi got a sym jet 4 rode it parked it up and now no spark at all help please is this a comon thing 2014 plate to
Hi, Ben and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting, leaking, spark plug cable connections loose check for spark leakage in the dark.
6. Faulty ignition coil or electronic control module.
7. Faulty CKP, CMP, or BAS sensor.
8. Faulty ignition switch.
9. Tilt sensor needs a reset.
10. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
no spark at all on 50cc sym jet euro sport Scooter Doc Forum
My scooter has no spark how to fix gy6 chinese scooter 139qmb qmb139 50cc...
Sym Jet 50 Service Manual
SYM JET 50 Spares Parts Accessories
SYM Fiddle II 125 AW12W Service Manual
SYM JOYRIDE 125 User Manual
Jan 16, 2017 | Sym Motorcycles
My Sym moped starts but won't idle It shuts off when trying to give it gas
Hi, Gigi and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the links below. Good luck and have a nice day.
Scooter Questions Get Answers to Your Scooter Starting Question
Scooter Troubleshooting Scooter won run All about Scooters
My chinese scooter wont idle or start Check the fuel petcock
http://scooterunderground.ca/knowledge/manuals/documents/sym_fiddleii125_service_manual.pdf
Oct 01, 2016 | Sym 125 EXC SIXDAyS Motorcycles
How can I replace air filter?
Hi, Rachael sorry you can't find the first and best tool you ever bought for your SYM despair not for a mere $0 you can download another one. For more information about your issue and free downloads that you will need please visit the websites below. Good luck and have a nice day.
http://www.sym-center.ru/files/jet-all.pdf
SYM Owners Manual
SYM Jet 4 125cc
Jan 24, 2016 | 2010 Sym Jet 4 125
Strating PROBLEM
Hi, Andrew and the usual suspects are:
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
6. Float level too low.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the blue links below. Good luck and have a wonderful day.
Why won my SYM Jet motor scooter start
Scooter Troubleshooting Scooter won start All about Scooters
SYM Sanyang Scooter Parts Racing Planet USA
Sym JET 50 series Owner Manual
May 09, 2017 | 2007 Sym Jet Euro X 50
Hello....I recently purchased a SYM Le Grande 171cc in Perth from a private owner.I used to have a JOYRIDE (other name for this bike) when I was in Japan and the maximum speed was125kmh plus. The one I...
Hi, Stuck_record sounds like your mechanic is blowing blue smoke up your skirt you may want to try a different shop if that's possible for a 2nd opinion. Motor scooters performance can vary from country to country. If you are looking for more top speed try going up one size in the main jet and make sure the butterfly plate in the carburetor is completely "HORIZONTAL" when the throttle grip is wide open the slightest deviation will slow you down.
For more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Making your scooter go faster Scooter Focus All about Scooters
Laws of Scooter Tuning How to get more power from your scooter
Sym HD 125 Service Manual also for 200
Sym HD 200 EVO Owner Manual
Apr 05, 2017 | 2011 Sym Joyride 125 RV
Repairing a sym euro jet x 50cc scooter all aspects
Hello
Is it a GY6 Motor?
Best Reguards
Larry
Dec 31, 2009 | 2004 Sym Husky 125
Sym jet 50 , wont kick or electric start
compression may be getting low if this is a progressive problem.
Oct 07, 2009 | RTO 50cc Moped Scooter
Toys Logo
13 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
