Indesit IWE 8168 is giving a mistake F05? Pls show the process!
4 Suggested Answers
  • 45 Answers
SOURCE: error code on washing machie
The wording of the error code explanation suggests the pressure switch clicked on to register a water level, but when the water was drained away it remained on instead of turning off. I would guess there could be a blockage in the pressure system, or the pressure switch could be faulty. Also, if the water didn't drain properly it would cause the pressure switch to stay on too.
Posted on Jan 03, 2008
SOURCE: indesit we14
Hi l have a indesir WIE147 that keeps on flashing F 01 repair man came changed module and next day same thing happened again HELP PLEASE
Posted on Jan 17, 2008
barkencoa
  • 3463 Answers
SOURCE: F05
F05 means pressure switch jammed on full.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Refit and test.
Please rate my solution.
Thankyou.
Posted on Feb 03, 2010
Indesit pwe 8148 w with error code FO5 Is the problem usually either a blockage or the pressure switch? I am going to try to fix it myself but how do i get to the pressure switch to see if it is stuck on...
Hi.
F05 means that the pressure switch shows full all the time:
F05 - Pressure switch jammed on full
The fault is usually fixed repairing or replacing the pressure switch. Before replacing the switch check for draining issues that can trigger F05 and clean the hose connected to the PS. The PS is located inside the appliance in the control panel or at the right side of the cabinet. The part is reached removing the screws holding the top and lifting the top. Power must be disconnected before starting.
Here how the switch looks like:
Sep 14, 2011 | Indesit W 123 Front Load Washer
Code F-05 showing on INDESIT WIXE 127 washing machine. Not emptying or spinning.
Hi
Error code F05 means that the pressure switch is jammed on full.
Remove lower rear cover of washer.
Locate and remove the large black fastened to bottom of the drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Hope this helps you.
Jan 03, 2011 | Washing Machines
When washing iwe get a horrible smell like bad
Is this a newly installed machine?
That smell would normally be associated with drains, indicating that the outlet from the machine to the drain is not correctly fitted with a trap.
Mar 25, 2010 | Indesit W 123 Front Load Washer
F05
Refit and test.
Thankyou.
Feb 03, 2010 | Indesit W 123 Front Load Washer
Indesit 1300 will not finish its cycle showing f-05 can you help
F05 indicates trhat the pressure switch is jammed on full.
Find and locate the pump, check pump and filter for blockage, as this is the cause of your prob.
Thanks.
Nov 03, 2009 | Washing Machines
Dear Sir my washing machine which is one year old started for the last couple of weeks todo unnecessarily noises and also it doesn not drain the water, showing code F05. WHAT TO DO? thank you!
F05 on an Indesit washing machine means "Pressure switch jammed on trip"
As is often the case, knowing the error code is one thing, but findng the cause is another because error codes often have several possible causes. The wording of the error code explanation suggests the pressure switch clicked on to register a water level, but when the water was drained away it remained on instead of turning off. I would guess there could be a blockage in the pressure system, or the pressure switch could be faulty. Also, if the water didn't drain properly it would cause the pressure switch to stay on too. Finally, the Indesit washing machines PCB's can give erroneous errors where the fault turns out to be with the pcb itself. This makes things very difficult if you don't have access to replacement PCB's to try.
Basically, I would keep an eye on the washing machine and try it again. If it reoccurrs then clearly it needs sorting, but if it doesn't it might have just been one of those things.
Sep 28, 2009 | Washing Machines
Fault f05
F05 means pressure switch jammed on full, firstly check that pump is working and that there is no blockage anywhere,
if it still does not work, then you are going to have to call an engineer.
Hope this helps.
Please leave feedback.
Nov 24, 2008 | Indesit W 123 Front Load Washer
Indesit we125. F-05 comes on screen. What does this mean?
Hi.
F05 mwans pressure switch jammed on full, check that pump is working o/k, if it is, and still showing fault, then you will have to call an engineer
Hope this helps.
Nov 22, 2008 | Washing Machines
Error code on washing machie
Jan 03, 2008 | Indesit W 123 Front Load Washer
Indesit we14
Nov 13, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
