Question about Electrolux Unirapido EL852A Stick Vacuum
Unirapido, fully charged, runs one second then stops with green flahing light.batteries are fine
Roomba 560 fully charges. Runs for 2 seconds fully green and just stops. And lights up red.????
Set him on the floor, after powering him off and then back on, and press the "Clean" button three times. This will reset him.
Sep 11, 2014 | iRobot Roomba 560 Robotic Vacuum
IRobot will stop after few seconds ..
How old is the unit? It looks like the battery needs to be replaced.
Feb 24, 2008 | iRobot 4296 Robotic Vacuum
Irobot manual
Is the light flashing green when you say it's fully charged? If it's yellow or red, that means it's got a low or no charge. The only time mine stops running is when something too big gets lodged in the brushes or it catches a sock or towel in the mechanism. It also can get stopped when if goes from one level of floor to another say 2 inches higher. It might need to be dismantled and cleaned out as well.
Jun 21, 2014 | iRobot Roomba 560 Robotic Vacuum
Electrolux Unirapido not working green light flashes when start button is pressed!
I have the same problem with this type of vacum. I have tried a lot of things but the problem is with the software included in a 20 pins chip on the pcb so it can not be repaired. But, if you look in the back of the vacum there is a rubber stopper wich hides 2 pins. Maybe those pins can be used to reset the vacums pcb. I really dont know because in can't test it any more. I solved my vacum bypassing the vacum mainboard (pcb). Now my internal battery is directly connected to the 2 motors using a simple switch to powering on and off. The original pcb is conected only to the batery, recharghing wires and led wires so i can recharge the batery as usual. Sorry for my english, hope you understanded what i was trying to explain. good luck
Apr 15, 2013 | Vacuums
Unirapido wont charge
1) tes the power cord
2) test very well the batteries.
3) open and test the IC for charger and replace see the diagram attached.
God bless you
Jul 03, 2012 | Eureka 1014A Unirapido Stick Vacuum
Status light is red, why? I have a Roomba Discovery.
Hi.
If the red light is solid, that means that the Roomba is near to full discharge. If the light is flashing red, then the Roomba is completely out of charge.
If the Roomba is fully charged, then there may be a fault.
Here full list of light codes:
Pulsing Amber - Charging
Green - Fully Charged
Amber - Partially Discharged
Red - Almost Fully Discharged
Flashing Red - Fully Discharged"
Here manual
See also
Roomba DISCOVERY MODELS' DIAGNOSTIC TESTS
May 24, 2010 | Vacuums
Seems to charge but then wont come on
Sounds like you bought a defective battery
You can test for this by removing the battery and holding the power button for 15 seconds. This will restart the charging cycle as if the battery were new. If it still goes red get a refund and a new one.
Mar 07, 2010 | iRobot Roomba 4105 Bagless Robotic Vacuum
Roomba cuts off after a minute or so.
If you have a 400 series Roomba, try removing the battery, then holding down the power button for ten seconds, then recharging the unit before you run it again.
If you have a 500 series Roomba, don't take out the battery-- just press and hold the "spot" and "dock" buttons for about fifteen seconds. The Roomba will play a tune, and you can then charge it and try running it again later.
May 13, 2009 | iRobot 4150 Roomba Vacuum
Help
Same thing happened to me, I called the company, and they told me to remove the battery, press the on button for 5 seconds, which clears the system, replace the battery and do a long charge 12 hours. I'm in the process of doing that now.
Dec 14, 2007 | iRobot Roomba Red 4100 Bagless Robotic...
Irobot discovery
It sounds like the battery is shot. These batteries only work for a couple of years and then they won't accept a charge any more. A common mistake people make is recharging them before they need it. This will make the battery "lazy"
Contact the manufacturer for more info.
Dec 09, 2007 | iRobot Roomba 4210 Bagless Robotic Vacuum
Electrolux Unirapido EL852A Stick Vacuum Logo
52 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
