Question about Vivitar ViviCam 3632 Digital Camera
Flash Operation For Vivitar 3632 Camera
I can not get the camera to go to flash mode, Tell me how to go the flash mode. Thank You
Down load the user guide
Posted on Mar 25, 2008
How do I switch off flash
On this model I think you need to go into the camera menu, navigate to the internal flash setting and disable the auto function. Sometimes these CSC are set to have the flash fire automatically if there is insufficient ambient light.
Oct 03, 2014 | Sony alpha ILCE-5000L 20.1 Megapixel...
Can i use my vivitar 4600 with my nikon d300s?
Yes. You can use the flash in auto or manual mode by setting the camera to manual shutter speed within the x-sync range and then selecting the aperture prescribed by the flash guide number or the displayed automatic f-stop on the flash. The flash can provide auto exposure with the camera in manual mode, but you need to be aware of the amount of ambient light which will not cause any exposure corrections by the camera in this mode. Another alternative is to select Aperture preferred automatic on the camera and the f-stop shown for the auto flash settings. This will allow the camera to vary the shutter speed but may cause long exposures if the camera is not sensitive to real-time flash readings.
May 05, 2014 | Vivitar Cameras
Vivitar 3200 flash with Canon EOS Rebel T3
it will work with your rebel t3 just set the flash on manual mode and adjust the desired flash power needed .
Jan 16, 2012 | Canon Rebel Cameras
My camera say no flash because of micro mode how do i turn the flash on?
The Micro mode is used to shoot close up images. Turning on the flash in micro mode will result washed out over exposed images. Hence in most cameras, choosing the micro mode will automatically disable the built in flash. Some Camera will show the message, cannot use flash or flash cannot be changed because of the micro restriction. This is normal operation. If you wish to use flash, please use some other manual priority mode.
thanks for understanding.
Feb 18, 2011 | Vivitar ViviCam 8025 Digital Camera
Hello, can someone please tell me how to turn on the flash, on my vivitar vivicam t324n? I didn't get a user manual with it & there is nothing to do with the flash on settings. All of my photos have...
The flash cannot be used in Macro mode. To set the flash, press the up button (up on the circular multiselector). Choose from Force Flash (lightning bolt), Auto (lightning bolt and letter "A"), Red eye Reduction (eyeball), and No Flash (lightning bolt in a circle with a slash through it).
You can download the manual at
http://www.vivitar.com/files_products/363/ViviCam_VT324_Camera_Manual.pdf
Oct 15, 2010 | Vivitar ViviCam 5022 Digital Camera
How to use flash on a vivitar vivicam 8690
Look on the Mode Dial find a small icon looks like a camera, rotate the Mode Dial to select.Toggle the flash settings. Look on the Mode Dial and find a small icon that looks like a camera, then rotate the Mode Dial to select this setting. This will help. Thanks please keep updated. please do rate the solution positively .thank you for using fixya
Mar 17, 2010 | Cameras
Hi my name is Curtis can you tell me IF my Vivitar 283 flash will work on my c-750 Olympus, TTL camera it have an hot shoe,but flash don,t fire. I have talked to Olympus about it(on answer). I took it to a...
No the 283 is not compatible with your camera. The 283 is manual only and not TTl. The canon flash is also not compatible with your Olympus. You need an olympus compatible flash.
Nov 16, 2009 | Vivitar 283 Flash
Instruction on zoom operation and also operation of flash on came
u have 3 problems here zoom,the flash and language ,ok to change the language hit menu .button then first word that shall be setup menu then word on the line number 3 and use right and left arrows to change ,the flash .turn the camera lens wheel on the pyramid sign u see on the front of the cam and then use the push button right side with zigzag sign to switch the flash mode ,push the button then up and down to zoom in and out
Mar 21, 2009 | Vivitar ViviCam 3750 Digital Camera
Vivitar ViviCam V8300 Digital camera the flash does not work! I have tried the menu in all flash modes, but still does not work, I believe the flash tube must be "blown", if this is so, can this...
I think it can be replaced.I don't know anything about the cost, but it shouldn't be that expensive, though.If you can fing a similar broken camera ..you could remove the flash from it and try and fix it to your camera. Cheers!
Sep 05, 2008 | Vivitar Cameras
Flash
i press the flash button its next to the mode button on the back, its the button that points left that changes the mode of the flash, dont press it to much tho battery dies quicker. Mel
Nov 15, 2007 | Vivitar Cameras
Vivitar ViviCam 3632 Digital Camera Logo
Top Vivitar Cameras Experts
Damen Wong
Damen Wong
DMS-UK
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
