Question about Riso RZ220 Duplicator
Riso shows dashes instead of numbers - Riso RZ220 Duplicator
When dialing a number, it shows xxxxxxxxxx instead of xxx-xxx-xxxx
make sure your cell phone display properties are not set for European modes. they use that format instead of dashes.
Aug 19, 2013 | Motorola Mobility RAZR2 v9 Cell Phone
Riso Rp3700 won't print from computer
We suffer the same issue. Have you find the solution?
May 02, 2013 | Office Equipment & Supplies
Error Code P-04-513
P04-513 is an ink overflow error.
the easiest way to fix it is to run the drum dry.
here is how:
1. turn the machine off by the power swith.
2. hold the left and right print position buttons and turn on the machine.
3. when the machine starts it will show you some numbers.. perss either the clear or yellow reset button to show 0000
4. now enter 81 and press start and the machine will make a master.
5. once the machine is done press the clear or yellow clear button to return to 0000
6. next make suer you have plenty of paper and enter 888 and press start.. the machine will start making copies of the test pattern. (if it jams a lot you may want to use speed 1 or go to step 4 and use code 80 instead)
once the copies start coming out light you can press the stop button and when the machine stops turn it off and back on normally.
Dec 19, 2012 | Riso RZ390 Duplicator
My riso ks 800 duplicator shows E13 Error code
my riso ks 800 duplicator show error code E3
Apr 14, 2011 | Office Equipment & Supplies
My riso is showing A-17 & -209
A17-209 means: Cutter HP switch is OFF when master-making starts or when master material is set in the master making unit.
Mar 24, 2011 | Riso RZ220 Duplicator
I cant repair my riso
Need proper error code.. A letter should come before..
Apr 29, 2009 | Riso RZ220 Duplicator
Riso HC5500 System Error - Restart!
I need help with the error code. s04-307 in my riso hc 5000
Oct 22, 2008 | Office Equipment & Supplies
Riso rz 370
if show P96172 it means that have to adjust the scanner
Mar 10, 2008 | Brother MFC-440CN InkJet Printer
24 people viewed this question
Top Riso Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marius Chiriac
paulfvincent
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
