Question about Russell Hobbs RH1042 Frontload Washing Mashine
What are the times on wash cycles on a rh1042
How long are the wash cycles on a rh1042
Washing machine starts washing then stops mid cycle
The clothes become very heavy once water is added. Please try remove some of the clothes to reduce weight Karen. Thank you and let us know if this helps? Leave feedback
Jul 12, 2016 | Russell Hobbs RH1042 Frontload Washing...
Washing machine keeps filling up with water kno matter what setting it is on even on the drain setting
You have a problem with your knob or switch it may be burned out I would get on Craigslist and find a free one meaning a matching one or a whole working unit there on there all the time in free stuff sometimes matching sets
Aug 07, 2014 | Russell Hobbs RH1042 Frontload Washing...
Washing drum not rotating
More than likely belt gone, otherwise the motor has gone.
Apr 06, 2014 | Russell Hobbs RH1042 Frontload Washing...
Water leaking from the panel under the turn knob
Water comes in the back, then goes via to solenoid valves to the back of the powder tray, it then is distributed through holes above each compartment, take out the powder tray (push down the blue bit at the back of the softener compartment) and check for cracks or even blockages, (water goes from tray down the back and through a short rubber hose straight into the drum.
Feb 11, 2014 | Russell Hobbs RH1042 Frontload Washing...
Flashing lights doesn't complete spin
I think this indicates a fault i.e. unbalanced load, I had the same when I tried to washable pillow. Went through all cycles but spin.
Nov 09, 2013 | Russell Hobbs RH1042 Frontload Washing...
Which button is spin on my russell hobbs rh1042 washing machine
The second to last on the dial (picture of a spiral), if it's the same as mine.
Nov 06, 2013 | Russell Hobbs RH1042 Frontload Washing...
Making noise when washing and noise gets louder when spinning then leaving washing wet
Could be bearings, look to be around £23 online, no idea how easy to replace though.
Oct 28, 2013 | Russell Hobbs RH1042 Frontload Washing...
My washing machine russell hobbs rh1042 gets half way in to a cycle then stops and lights start flashing what does this mean
Your machine is trying to tell you something-do you have the owners manual-if you don't I'd bet you could find it online-what I would look for is an explanation of the flashings-it will probably tell you to count the number of flashes to tell you what is going on-cheers denny
Oct 24, 2013 | Russell Hobbs RH1042 Frontload Washing...
Russell Hobbs RH1042 Frontload Washing Mashine Logo
Top Russell Hobbs Washing Machines Experts
jdtech
ray gallant
Are you a Russell Hobbs Washing Machine Expert? Answer questions, earn points and help others
