Question about NEC PABX SL1000
SL1000 TELEPHONE SYSTEM HAS POWER ON PORTS ,BUT NO TONE.WHAT COULD BE THE PROBLEM?
WHAT IS THE NUMBER OF IC RESPONSBLE FOR GENERATING THE TONE
Technics Organ SX-GN3 Faulty tone Generator
unfortunately the way the ics are made are too old that some have been phased out and are no longer manufactured. would advise yu to seek advise by emailing samick service center with the model number of the organ and the ic number that you need.
Oct 25, 2016 | Music
Why does my telephone ring back after a conversation?
sir, you must be fooling by someone or check your phone settings. see the ring back tone settings or see the bottom of your phone. hope that helps sir!
CHARCOIS
Aug 16, 2008 | Lands Phones
How do I get a wire diagram for a 32 foot 93 Fleetwood travel trailer. original owner, all wires out so I need to put all new wiring in from breaker box back
Hi Cayla
Without knowing the model of your trailer, I've found a link (see below) to Fleetwood RV's support center. I hope this points you in the right direction and you get some joy.
-Steve
Fleetwood RV Parts and Service
Apr 03, 2015 | Cars & Trucks
Can't dial out
bad phone or extension port try another working phone of the same type.
Aug 29, 2012 | NorStar M7324 Telephone
HP LaserJet 3055 .fax not working
Direct Line:
1.Check telephone line.2.Make sure telephone line is connected in line in port not in extension.3.connect extension telephone phone to the device & check for the dial tone.
Dial the number and observe weather extension phone is ringing?
A. *If extension phone is ringing check display is there any message like "ringing".. wait till fax tone comes,if not check "basic fax settings"... if setting are OK .. Replace formatter
B. *Extension phone is ringing no message displayed on device replace "LIU" card..
If extension telephone is not ringing check telephone line..
No out going faxess:
*Check line is connected though EPABX , if connected Check..prefix setting..
*Check out going..
Best of luck...
Sep 06, 2011 | HP LaserJet 3055 All-In-One Printer
When I try to send a fax on my lexmark x4650 it has error no dial tone?
If you are getting "no dial tone" as an error on your fax machine, it means that you have the telephone cord plugged into the wrong port on it.
Turn the printer around so that you can see the back of it. If you look closely, there should be three ports to choose from in which you connect a telephone cord. Sometimes they put a little white plastic piece in the ports to keep them clean during shipping ect. If this is the case, go ahead and remove them now.
If you look closely at each port , you might notice that they have text or pictures right above or below them to tell you which one to use. let me explain; if you have one telephone line and wish to use it for both fax and voice calls - you will need more than one port. That's why they mark them.
One of the ports should say "line" or have a picture with a funny little symbol on it. This is the port that you would use if you want to fax someone using your printer. You plug your phone cord into this port on your printer.
One of the ports should say "phone" or have a picture of a telephone by it. This port is used when you want to share a single phone line with both your fax machine and telephone used for making voice calls. To split your line between both fax and phone, you plug your phone cord from the wall into the port marked "line" and take a second phone cord and plug it into the port on your printer marked "phone" and the other end of that line goes into your telephone (voice line).
The last port should say "line 2" or similar and usually has no picture next to it. This is an additonal port to share with a second phone line.
To correct your problem of "no dial tone", plug your phone cord into the socket on the wall and put the other end into the port on the printer that says "line". Now lets test the connection.
Put a piece of paper into your printer, press the fax button and dial any phone number using 1 and then the area code followed by the phone number and press 'start" or "ok" to begin the fax. If you have chosen the right port to connect your telephone cord, you will hear a dial tone first, and then dialing of the numbers you chose. If you cannot hear a dial tone before your numbers begin, then you have not chosen the right port. If this is the case, remove the phone cord from the port you have chosen and try another until you do hear the dial tone.
NOTE:
Do not try to go from your phone jack into your telephone and then use a second port on your telephone to connect a second phone cord that is plugged into your printer/fax. A second phone port on your telephone is most likely for a second phone line to use for voice calls. The majority of phones for residential use do not have a built in splitter that works like a fax/printer does. If you try to use a second port on your phone to split to your fax machine, it usually will not work. Follow the instructions as listed above to re-route your line and correct the problem.
MAGIC JACK USERS:
While magic jack is great for making free long distance calls, it is not suggested for use with a fax machine. if your trying to use your magic jack phone line to fax it usually does not work.
Jul 16, 2011 | Lexmark X4270 All-In-One InkJet Printer
Pilot wont stay alight
Replace the thermocoupler (also called a pilot generator) in the pilot assembly. It is responsble for holding open the gas valve port that feeds gas to the pilot. As it ages it gets weak and fails. They are about $15 - $25 depending on where you get one at. Some home centers care them as do appliance repair shops.
Dec 20, 2009 | Water Heaters
Need to know if I can use a digital dial tone with this switch
A regular telephone will plug into the ATA from the cable modem. You just plug one of the ports of the phone system (CO port) into the same place and you'll get dial tone.
That VA-208 is REALLY old :-} What, about 20 years?
Carl
May 05, 2009 | Lands Phones
Samsung 816 power outage dailing an outside line
First thing you should verify a dial tone on the fax machine. (use any analog phone)
If you have dial tone, press 9 and then a number
Second is it conected through tel. system? (did it have an internal extension) and there is no dial tone then your analog port may be fried. Call your telephone vendor. He should be able to help you.
You can purchase a manual for about 10 dollars
Email your system model number to sales at aaa-avad.com for further instructions
Mar 31, 2009 | Samsung Prostar 816 Phone
NEC PABX SL1000 Logo
Top NEC Lands Phones Experts
Brian LaDuca
george  peters
george peters
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
