Question about HP LaserJet P2014 Printer
Local printer spooler is not running on windows 7 32 bit
    Champion:
  • HP Expert
  • 312 Answers
Go into service management in your control panel and scroll down to see if it is set to off
Posted on Jan 31, 2015
  • 3741 Answers
SOURCE: print spooler not running
to make spooling work its necessary to make it work
this is the procedure .if you do this it will work properly. till it is not done it will just ignore printing
1)click the start in the left sice of your computer screen
2)go to control pannel
3)click performance and maintainence
4)click system
5)click data execution prevention
6)turn on DEP for essential windows program and services only.
7)click the spooling services a tick mark sign will appear beside that means it has enabled.
now your printer will work properly.
thanks.
Posted on Jul 11, 2009
  • 38 Answers
SOURCE: print spooler unable to connect tp printer,cable
Print internal configuration page and check for IP address in printed sheet and try to compare with the driver information
Check for LED at network card if it’s on
Try to send ping command to IP address to verify connection and if reply is confirm
Uninstall driver and reload and try to search the printer with IP or hardware address while loading driver
If still any problem it could be network card have problem need to be replaced
Posted on Nov 07, 2009
jaye_ellen
  • 591 Answers
SOURCE: Hello, my laser jet printer is not connecting, msg
Start by removing the printer driver(s). Check several times, as some printers hide in lots of places. Once the printer/driver(s) are all gone, try a new installation.
funkyagain
  • 24 Answers
SOURCE: windows could not start the spooler service on
If you the print spooler isn't working, you can either manually turn it off and on by going into your control panel - Administrative Tools - Services - Print Spooler - Then click the restart button.
The other easy option which usually works is just restarting your computer. This will restart your print spooler as well.
Hope this helps! :)
Posted on May 03, 2010
Testimonial: "Thank You, tried that but still no good. I am on windows 7 premium 64 bit upgraded from vista home premium. The errors I keep getting are - the local print spooler is not running. On the description for spooler in Services it reads Failed to read description error code 15100"
  • 67 Answers
SOURCE: I have a HP LaserJet
go to start->run and then type net stop spooler... hit enter
then type net start spooler .. and hit enter..
you may also go to run and then type CMD.. This will take you to the DOS Black screen.. here you may type SC CONFIG SPOOLER DEPEND= RPCSS and then press enter.
After this restart the computer and try to print..
Posted on Sep 07, 2010
Local print spooler not working. What do I do?
Try to uninstall the Lexmark driver and download an updated driver online. Just go to http://bit.ly/UmL4pl and choose the operating system of your computer.
If it doesn't help, check your print spooler if it's running. To do that, on your computer, click on Start > Run > type in Services.msc > OK > look for Print Spooler and make sure that it's started.
Nov 13, 2012 | Lexmark X4550 AllInOne InkJet Printer
Can't print. local print spool not working
Try the steps below to clear the print queue and restart your print spooler:
1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
Try to print a document again to verify that the problem is fixed.
Jan 11, 2012 | Lexmark X5495 Printer
Can't printer something about the spool
MY PRINTER WONT PRINT, BUT WILL SCAN AND COPY
What is the operating system of your computer? Make sure the printer software is installed on your computer (available at http://bit.ly/g1FS2M) If you're using Windows, please check the Print Spooler service on your computer and make sure it is enabled. To make sure the service is running, follow the steps below:
1. Browse to Start -> Run... and type in "NET STOP SPOOLER" (this will stop the print spooler service)
2. type in "NET START SPOOLER" (this will restart the print spooler service)
Try to print again.
May 17, 2011 | Lexmark X4530 InkJet Printer
I can not print on my HP Laserjet 1020. It first asks that I install a printer before printing but when I try to install the printer it says that the local print spooler service is not running. It then...
try to restart the spooler system.
to do it:
1) click start
2) on the search box type Services and hit the enter key
3) on the windows that appear after you hit enter. Find priter spooler
4) once you find it. double click it.
5) on that window. and make sure that the startup type is automatic and finally click start.
Note: if the spooler service is already running stop it and restarted back in.
hope this helps
Jan 18, 2011 | HP LaserJet 1020 Printer
All of a sudden, I can't print on my HP LaserJet 1020 and I don't see it anymore on list of printers/devices. When tried to add printer, screen displays "Windows can't open Add Printers. The local...
Hi.
Here is the procedures
Go to START MENU
Choose RUN (For Windows XP) or Choose Commad prompt, right click and run as administrator ( Fow window vista and windows 7)
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer also turn off your printer and switch it on.
It will work fine right now
I hope it helps you
Jan 13, 2011 | HP LaserJet 1020 Printer
I am running vista ultimate 32-bit but i often received this error message:".....the local print spooler is not running...." when attempting to install a remote oki B4400 printer. Why is that?
Print spooler is printer service if this service is not running, it might not allow you to add or see any printer drivers
Try enabling print spooler service. Follow the instructions
Click on Start->Search->type "services.msc" hit enter. Service windows will open up, on the right side pane search for "Print Spooler"
-> double click to open service and select start type as "Automatic"
click on apply and click on "Start" botton to start the service.
Now try to install the drivers
Snapshot for more information.
Hope this helps
May 21, 2010 | Computers & Internet
I'm getting the error message whenever I try to select a printer that ''Windows can't open add printer. The local print spooler service is not running. Please restart the spooler or restart the...
If u r using the XP operating system, follow the steps to restart the spooler :
1. Click Start and then click Run and in the run window type services.msc and then press Enter.
2. Locate Print spooler from the Services window which is opened now.
3. Right click on it and select Start.
May 08, 2010 | Office Equipment & Supplies
Spooler
Click please
Start, in the white search box, type run, in the run box type
net start spooler
note the space between the words
you should be good then
Regards
Richard
Apr 27, 2009 | Microsoft Windows Vista Ultimate Edition
DP-2330 on Vista
To start your spool service type spoolsv.exe in the run box.
Apr 10, 2008 | Panasonic Workio DP-2330 Printer
HP LaserJet P2014 Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
