Question about Vizio Xvt373sv 37 Inch Hdtv 1080p Led Lcd Hdtv 120 Hz Flat Screen As Is
How to switch displays when tv has no signal from computer and no desk top computer monitor
Insprion went to sleep with vga monitor now computer comes on but it's not sending out any signal with HDMI, and i no longer have a vga monitor just the tv and cant see to change any settings Help have win7 and win8 on hard drive
    Problem Solver:
  • 10 Answers
Reset your laptop display connections or get a new HDMI cable
Posted on Mar 04, 2014
Flatron W1943 sb monitor goes into power-saving mode. Does not display data.
If the monitor is displaying the "Power Saving Mode" signal to the monitor, then the monitors internal VGA board is functioning, so you can rule out a broken monitor. However I have seen monitors blow the internal fuse to the VGA board which causes a false "SLEEP" signal. If this be the case then it will require replacement of the fuse (usually a microfuse soldered onto monitor internal board) or most likely a monitor replacement.
To test:
Option A: you can connect another monitor to the monitor output on the back of the computer and see if you get a display. If this monitor goes to sleep, then it is likely that your Video card is malfunctioning. If you get a display, then it is definately the monitor.
Option B: If you have another computer, you can attempt to connect the monitor to another computer. Also most modern laptops will be equipped with monitor output, so if you have one you can check it. If the monitor sleeps, then it is definately the monitor. If you get a display, then it is definately the computer video card.
Hope that helps,
G
Sep 17, 2012 | Computers & Internet
How to huck up tv to desk top computer
Depending on the computer, you can use the VGA port or the HDMI1 port and the PC audio in (above the digital audio out) with the appropriate cables. The audio cable is a 3.5 mm audio patch cable. Use standard VGA or HDMI cables.
Then press the input button to select either the PC (VGA) or the HDMI1 port as needed.
Then make sure the computer is sending a signal to the desired port. (You may need to enable the port in the BIOS.) Make sure the monitor is on when you start the computer. With Windows, you can usually select the desired monitor by right clicking on the desktop and then choosing the display options. (for Win7, see Screen Resolution then detect the monitor.)
I hope this helps.
Jan 16, 2011 | Toshiba 40G300U TV
Trying to connect Lenovo IdeaCentre desktop to HP w1907, monitor keeps popping up the message like " no input signal' on VGA or DVI, DVI is always checked as default. Then going to sleep right away. Push...
wow no OS stated, nor model of Lenovo.... (so generic answers)
i guess you have no manuals on any of this. right>?
is this HP question, if the HP monitor works on other PC its ok.
so end HP worry. (my guess is HP is OK, totally) 19"LCD is OK.
leaving what, LENOVO.!! (unnamed? a stinkpad?)
this is a HP forum, so cant tell the hot key for External VGA
on any Lenovo. but you can RTM the book on it. easy.
that HP VGA monitor message means.
1 thing, the 3 video and 2 sync lines are dead.
in non geek means the VIDEO CABLE IS DEAD.
try running the PC in F8 mode this puts WINDOWS< (is it./)
in to LOW RES mode (poor) and all monitors work there.
all. (last 25 years)
if still dead, you need to use the hot key to turn on VGA, on all laptops
my HP laptop as 3 modes, VGA on , VGA off and AUTO.
nice no? that AUTO.'
The PnP wakes up the port. is that magic.
The VGA port must work, and the LCD both.
is this one of those beasts called an all-inone desk top
than name you used tells the helper nothing
as that name used for many form factors.
all in one
regular desk tops.
and more.even pocket pc.
now idea at all what you have (hp is clear on that end=)
Apr 14, 2017 | HP w1907 LCD Monitor
Monitor has no signal
have you tried you PC with another Monitor?
I'm expecting that you still have same problem.
Is your PC making any audible noise, beep sounds?
May be you should have your PC checked
Mar 15, 2010 | Westinghouse 19" Widescreen Flat Panel LCD...
My computer on five minut before moniter display no signal whats problemthis computer my desk top p3 celeron
hello , so if you system on then the monitor will show up finishing the booting then thats from the monitor cable at the back in conjunction with the VGA card at the back of your system what you will have to do is just change the monitor first with other one if you have or probably change the VGA card that slot that your monitor cable come in contact with your system ok then post it again if there is any thing again THANKS
Feb 20, 2010 | Computers & Internet
Monitor Hp w1907 has no input signal, how do I get connected and keep it from going to sleep
If you set the PC to go to sleep after certian amount of time than it will not put out signal to the monitor. You need to go to display properties (right click on the desk top)/screen saver -power/set the display to never turn off.
Nov 30, 2009 | HP w1907 LCD Monitor
Screen comes on briefly then blanks out.
check inverter, memory, and powersupply.
May 31, 2009 | HP w1907 LCD Monitor
Acer Monitor boots up w/computer then "no signal"
you must have disconnected it while the pc was running.damage can occur while doing this as can a keyboard (they are not like USB devices that can be plugged and unplugged while "hot".)
Jul 20, 2008 | Acer AL1916W 19" LCD Monitor
Display in two monitors
There is an S-Video port and VGA for external display
but you can see display in any one of them not on two monitor
simultaneously
Apr 29, 2008 | Dell Inspiron 6400 Notebook
Vizio Xvt373sv 37 Inch Hdtv 1080p Led Lcd Hdtv 120 Hz Flat Screen As Is Logo
42 people viewed this question
Top Vizio Cell Phones Experts
Computer Repairing
Computer Repairing
ray gallant
john Benson
john Benson
Are you a Vizio Cell Phone Expert? Answer questions, earn points and help others
