Question about Amana Refrigerators
I want shema of cabling of amana sxd 524 ve - Amana Refrigerators
How do I Reset My Password in My D-Link DI-524? I've Tried the 192.168.0.1, but Nothing Happens, just keep getting the Password Re-Set window
If you forgot your password, you can reset the router to it's factory defaults (You will lose all your settings/changes you made).
You can go here to see how to do it.
http://technicallyeasy.net/2008/02/how-to-reset-d-link-di-524-wireless/
Oct 13, 2011 | D-Link AirPlus DI-524 Wireless Router
I have a 15 yr old sxd 520sw side by side the ice tray does not fill up but when u fill the tray manualy it throws the ice into the bucket... please help
sounds like everything works you just dont get water to it. so start there check your water lines and make sure you have water going to them. look for a small on off valve running from where the water comes from at the wall or somewhere in the line running to the back of the freezer. make sure it is on. if you check all this and your sure you have water then there must be a clogg in the icecube maker.. i hope this helps..
Aug 13, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Hi, I have a hyundai grandure 2000, i need the electric mirror wiring diagram. just couldnt find it anywhere. can you help please. All the mirror just wont move at all. the rest of the buttons on the door...
just go on ( hmaservice.com) registred your self you will find your électrical shema your looking for.but you must click for a XG série it's the same car and go for a 2001... click on SHOP,than click on body électrical system after on power mirrors (this is to check the actuator) and for the shema click on ETM than go on( power outside mirror) and there you go you have your shema please reply thanks!...lipak!!...
Apr 26, 2010 | 2001 Hyundai XG300
The D-Link 524 is not transmitting wirelessly or via cable
This might be a bit dumb solution but try pull out the power adapter and plug it back in again. Have worked for me 3 times when I've had similar problems.
Mar 01, 2010 | D-Link AirPlus DI-524 Wireless Router
Connect to wireless
here you get the manual sir:
ftp://ftp.dlink.se/Products/di-products/di-524/Documentation/DI-524_manual.pdf -
or
www.amazon.com/D-Link-DI-524-Wireless-Router-802-11g/dp/B0001PFQ08 - 256k -
or
reviews.cnet.com/routers/d-link-di-524/4505-3319_7-30839580.html - 79k -
thanking you
Jul 09, 2008 | D-Link AirPlus DI-524 Wireless Router
DI-524 wireless router
OK! There we go. I got the new firmware version (V2.07)in the site WWW.dlinkla.com, compatible with my router (DI 524).In the advanced management of the router, I uploaded the new version previously dowloaded in a file,from the site.Them I got the device working good.
I hope it be usefull for someone.
Jul 01, 2008 | D-Link AirPlus DI-524 Wireless Router
Connect to wireless D-Link and Westell6100
I am assuming that you have a functional LAN cable connecting the Westell and the DI 524, right? If you are unsure, replace it with a cable you know is good.
If the 524 is turned on downstream of the Westell modem, it should find what it wants. You may try rebooting the Westell and seeing if the 524 finds it, and you maybe should reboot the 524.
Sometimes, when the world gets jiggered up I have to work pretty hard to get my DI-524 resync'd to my DSL modem.
Oct 26, 2007 | D-Link AirPlus DI-524 Wireless Router
Refrigerators Logo
27 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
