Question about Fisher and Paykel Refrigerators
Fridge shorting house meter box safety switch
Our F&P E442BA shorted the safety switch in our meter box twice over about 8 hrs but hasn't done it since. There's a very faint burnt smell a day later which was a little stronger after the second short. What should I check for and in what order?
  • 4 Answers
Is the fridge on it`s own supply ?
Posted on Feb 10, 2014
  • kopecc
    kopecc Feb 11, 2014
    no, it shares a circuit with dishwasher and microwave but we turned all off and only when the fridge got turned on did the safety switch trip again
fridgetech
  • 473 Answers
SOURCE: shorted control board dispenser
Look and see if the door for the ice chute is closing all the way. This model is bad about that door breaking. If it doesn't shut properly then warm air getting in will cause this condensation. Will also cause ice in bucket to melt and water can leak onto these parts. If it isn't obviously hanging open then shine a flash light from the inside down the chute and see if any light comes thru to the outside. Maytag has a chute door kit that you can find on appliancepartspros.com. Their part # is AP3140440. Let me know if this helps or we need to go further.
Posted on Oct 10, 2007
  • 1314 Answers
SOURCE: whirlpool frost free fridge
check the reley at the compressor if it looks like a little white box pull it loose if it rattles and stuff falls out go the appliances part store and get you a three in one rely for a1/3 horsepower or less and install it by the directions its not hard
Posted on Jan 20, 2008
22yooper
  • 828 Answers
SOURCE: fridge shorts power out
From your description it sounds like a short in the defrost heater circuit. It would normally be a repairable item. You may want to consider the age of the refrigerator before getting into the repairs.
Posted on Aug 24, 2008
jumptrout51
  • 3361 Answers
SOURCE: after moving frigde and freezer quit.
Your compressor start relay has become loose or possibly defective.
Push it back on for a good connection.
Watch it when you plug the fridge in.
If it sparks replace it.
Posted on Mar 12, 2009
SOURCE: GE Model PDS22MBRABB bottom mount
These fridges were made by LG they are very problematic, the defrost cysle does not work properly due to board defects and the fridge freezes up, I have replaced my board twice and the fridge has worked properly for 6 months max them the board shorts again, I talked with the LG rep he said scrap the fridge they are ****.
Posted on Sep 03, 2009
How do I Check safety neutral switch
Here's the plug pin out for it. I would jump the wires first. If it turns over replace the switch. If it does. trace the wires for a short. Pin 5 and 8 25362499-tijdub2y0h3m0vcaz2bqtnkd-4-0.gif
Jan 09, 2015 | 2002 Dodge Dakota Club Cab
Sharp Quart Dual Grill 900w microwave not working. Turntable, light, grill all working perfectly. Can anything be done here?
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
Make sure the !!!!any capacitors are discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Mar 21, 2011 | Microwave Ovens
DOESNOT HEAT FOOD
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Hope that helps.
Feb 02, 2011 | Kenmore Microwave Ovens
Microwave won't heat
Hope that helps.
Jan 09, 2011 | Microwave Ovens
No heat. Everything else works.
YOUR SAFETY IS PARRAMOUNT
Hope that helps.
Jan 04, 2011 | Microwave Ovens
When fan is turned on, all electrical power in house goes off (safety switch is tripped). This happens even when the fan light is off.The fan is an older model (i don't know what brand) that was in the...
It may be possible that fan wire is connected to another wire, so it is short circuited. Thats why safety switch is may be tripped... Check the connection of the wire.
Mar 05, 2010 | Heating & Cooling
Fuse blown,door switch shorted
you need to readjust the"Interlock" switch position on the door, they are made to blow the fuse purposely when the door is mis-adjusted for safety, you will need to unplug the unit and disconnect the "interlock" safety switch, then readjust and close the door,until you can get the switch adjusted so it doesn't show a short circuit on the meter,then this should stop the fuse blowing issue for you
Nov 17, 2009 | Dishwashers
My dryer just stopped running?
It could be the door safety interlock switch. Remove the switch short the two wires and press start. If it works remove the short to stop the dryer and order a switch. If you have an Ohm Meter you can test the function of the switch without shorting the switch.
Jul 16, 2009 | Kenmore 63942 Dryer
Heater fan C/B tripped twice in 2 weeks.CAMRY 91.
Usually there is a short in the system to ground and checking the wire harness at each component from the plugs is the best way to find if you are shorted to ground. If the harness does not show a short when you apply a meter to it, check each component with a meter through the prongs at the plug for a short. Don't forget the switch itself. Turning it through all of it's speeds. I am confident you will find the source.
Jan 06, 2009 | 1995 Toyota Camry
Nov 06, 2007 | GE Energy Star PDS22SIS Stainless Steel...
Refrigerators Logo
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
