Question about Gemini DJ Gemini CNTRL-7 USB MIDI DJ Controller w/ Soundcard
Code 43 error - on gemini cntrl 7
Have usb device not recognized (code 43 ) when my plugging my gemini controller into my laptop or desktop .Tried microsoft repairs , bios update , registry repairs , no luck .
Need help with a sound problem im experiencing with my Gemini CNTRL-7 controller
Hey, try changing your default playback device. Your controller may be trying to tell your PC that it has a speaker, changing the playback device to your speakers may fix this. (if using windows, right click on your speaker icon - lower right hand corner, select 'playback devices' and then choose your usual device - if you don't know which one is, then just select different ones and see what works)
Later,
Beau.
Jun 20, 2014 | Gemini DJ Gemini CNTRL-7 USB MIDI DJ...
My Plantronics C420-M is not recognized
How To Fix Error Code 43 Windows has stopped this device because it has...
If Windows Device Manager is giving a code 43, this means the hardware is reporting something wrong when trying to connect. I'd do the following (and also check the attatched link for reference ;-) )
  • Unplugging the headset, restarting the computer, then plugging the headset back in.
  • Make sure the USB connector on your headset (and the USB port you're putting it in) is undamaged, and not dirty.
  • Try connecting the headset to another USB port, and another computer to see if you're able to reproduce the issue there (if not- it may just be the USB port(s) on your computer that you're plugging the headset into that's failing.
If all else fails, it may be time to purchase a new headset ;-)
Jan 22, 2014 | Plantronics Blackwire C420-M Headset
LG dvd external drive not recognized by computer
ERROR 43? Check your SATA connection.
HERE'S HOW I FIXED MINE.
(IE. Computer tries to install driver for BD burner, but ultimately fails, and gives the message. "Unsuccessful" and/or "Microsoft Windows stopped device. Error 43") The SATA CONNECTION on my BD burner's EXTERNAL CASE had gone bad.
TO TEST IT. I used a SATA/IDE to USB Adapter Cable I bought for about $10 on amazon.
  • I unscrewed the external case to get at the internal drive, and plugged the SATA adapter cable directly into the internal BD burner drive (bypassing the case assembly), and plugged the other end into my computer USB port.
    • PS My BD burner POWER was working OK, so I left the big white 4pin power adapter connected to the original external case.
VOILA! Both my laptop and my desktop PC recognized the LG BD burner again and assigned it a drive letter (like it used to do).
  • Now I either need to (1) Buy a NEW EXTERNAL case ($10 - $30), (2) install it as an internal drive (could get problematic if "ANYDVD" is installed) or (3) just leave it connected via the cheap adapter cable.
It's super EASY (& inexpensive) to TEST this before spending $$$$ on a new equipment.
Hope this helps someone. It had me miffed for a while there.
Jan 02, 2014 | LG GSA-2166D DVD RW Dual Layer Burner
Windows error code 43
known problem, that might be fixed by a cold start. switch off your PC or laptop completely. even pull the power lead from the wall, (in laptop remove power supply and battery once switched off) wait a few minutes and power up and start your machine.
I hope this was helpful
Oct 31, 2013 | Computers & Internet
A lot of my favorite music is on my flash drive,error code 43 message
Code 43 Error Message
The Code 43 error is one of several Device Manager error codes. The Code 43 error will almost always display in the following way:
"Windows has stopped this device because it has reported problems. (Code 43)"
Details on Device Manager error codes like Code 43 are available in the Device Status area in the device's properties
rror Code 43 Troubleshooting
  1. Restart your computer if you haven't done so already.
    There is always the chance that the error Code 43 you're seeing on a device was caused by some temporary problem with the hardware. If so, a restart of your computer might fix the Code 43 error.
    Note: Some users have also reported that powering off their computer completely (not just a reset) and then turning it back on has corrected their Code 43 issue, especially if it exists on a USB device. In the case of a laptop, turn it off and remove the battery, wait a few minutes, and then put the battery back in and start the computer.
  2. Did you install a device or make a change in Device Manager just before the Code 43 error appeared? If so, it's very possible that the change you made caused the Code 43 error.
    Undo the change if you can, restart your PC, and then check again for the Code 43 error.
Jan 28, 2013 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How to solve code 43 in may flask drive
error 43 is a usb universal serial bus controller problem
click start control panel administrive tools ,computer management ,device manager scroll down
universal serial bus controllers you should see a yellow question / exclamation mark? ! or a red X
right click to reinstall drivers or
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
for windows 7 you might try
First, please disconnect all USB devices. Then, go through the following steps:
1. Press "Ctrl + Esc" to open the "Start" menu.
2. Type "devmgmt.msc" in the Search bar and press "Enter". Click "Continue" if necessary.
3. In Device Manger, press Tab and use "Up" and "Down" to move the highlight to "Universal Serial Bus Controllers".
4. Press "Right" and expand it.
5. Press "Down" to move to the first item and press "Delete" to remove it.
6. Repeat the step 5 and uninstall all items under "Universal Serial Bus Controllers".
Then, restart your computer and Windows 7 will reinstall all controllers automatically.
hope this helps
Oct 16, 2012 | Kingston Electronics - Others
How do I fix the msi motherboard windows 7 USB error 43?
How to Fix a Code 43 Error
    Depending on the changes you made, some solutions might include:
  3. Reinstall the drivers for the device. Uninstalling and then reinstalling the drivers for the device is a possible solution to a Code 43 error.
    Important: If a USB device is generating the Code 43 error, uninstall every deviceunder the Universal Serial Bus controllers hardware category in Device Manager as part of the driver reinstall. This includes any USB Mass Storage Device, USB Host Controller, and USB Root Hub.
    Note: Properly reinstalling a driver, as in the instructions linked above, is not the same as simply updating a driver. A full driver reinstall involves completely removing the currently installed driver and then letting Windows install it over again from scratch.
Sep 16, 2012 | MSI INTEL G41 INTEGRATED VGA-MATX 2DDR3...
I cant get my headphone to work on my gemini cntrl-7.
If you are using virtual dj , adjust your settings under configuration - sound setup , change the output settings to headphones.
Jun 08, 2012 | Gemini DJ Gemini CNTRL-7 USB MIDI DJ...
Usb error code 43 in windows 7
this error may be from Windows 7 not able to recognize the USB device.
Driver for the device may not be compatible with the USB device in Windows 7
Jun 22, 2010 | HP Computers & Internet
Gemini DJ Gemini CNTRL-7 USB MIDI DJ Controller w/ Soundcard Logo
83 people viewed this question
Top Gemini DJ Audio Players & Recorders Experts
chuck ringwood
chuck ringwood
James Kovacs
James Kovacs
Gil Shultz
Are you a Gemini DJ Audio Player and Recorder Expert? Answer questions, earn points and help others
