Question about Karcher Garden
Karcher not working with suction hose - Karcher Garden
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 165 Answers
Use low pressure head,
Posted on Apr 21, 2014
Can I use karcher water suction hose with karcher k.26 ?
When using harvested water, it is most important that the water supply is above the machine. The gravity will help a lot. The higher the better. Also if the diameter of the supply hose is big, it will help the output flow.
Regards,
MG.
Oct 11, 2014 | Karcher Garden
Karcher puzzi 100 not spraying
blocked pressure hose or blocked nozzle at the end of the wand
it is controlled by a pressure relief regulator which quite often plays up.
Jul 19, 2012 | Garden
Water is coming out of the soap suction hose
there should be a ball check valve in the soap suction hose lets soap in keep water out poke a paper clip in the hole a few times soap will build up there and make the ball valve leak
Feb 12, 2011 | Karcher PSI Electric Pressure Washer
My Karcher 2400 Pressure Washer will not syphon cleaning fluid. I have a reconditioned machine and the syphon for cleaning fluid has not worked for a while.Everything looks clean but still does not work'...
The black tip nozzle puts the right amount of pressure on the line to draw up the cleaning solution.
If your power washer is like mine, the cleaning fluid adapter is a 'T shaped' brass valve that fits in-line along the hose line.
There is a brass stem sticking out.
The stem has a tiny ball valve on the end.
A plastic hose fits onto the stem, and the plastic hose goes into bucket of cleaner.
As water travels through power washer hose, it creates suction that draws cleaning solution through the tiny ball valve.
The brass ball valve gets clogged or wears out ... we used to replace the stem every so often.
Sherwin Williams used to carry a replacement stem ... but they may not sell little parts any more.
It's been 14 years since I used the suction device.
I got fed up with the thing not working.
We changed over to a pump-up hand-held sprayer for applying cleaning chemical.
The pump-up puts more chemical on the spots where you need it.
So one guy puts chemical on, and second guy comes behind with power washer ... no more replacement parts, and one tip stays in the gun so we never lose a tip.
A pump-up sprayer is half the cost of replacing the T-shaped valve.
Duh-simple is the business model.
Nov 17, 2010 | Karcher Garden
No suction at all! help
check your vacuum at the pickup all the way thru the hose to the bag, you might be stopped up somewhere.
Jul 09, 2009 | Karcher K DS 5500 Vacuum
My karcher G2000QT WORKS AT HIGH PRESURE FOR A COUPLE OF SECONDS AND THEN STOPS THEN A COUPLE OF SECONDS LATER WILL START AGAIN WHATS GOING ON?
are you making the machine **** for water, if so you have got a air leak on the suction hose.
try force feeding with water by connecting your hose to the mains water hose and see if you can see a water leak.
could be starved of water also,chack the filter
Jun 28, 2009 | Karcher 2500 PSI Pressure Washer
Losing pressure somewhere
Hi, I work in the italian factory of Karcher. In my opinion the problem is caused by the breaking of the collector. This is a black component of plastic where is inserted the detergent suction valve and the safety valve. To replace this component you have to go in a repair center Karcher.
Nov 24, 2008 | Karcher 1750 psi Electric Pressure Washer
Garden Logo
64 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
