Question about Fisher and Paykel Washing Machines
Fisher and Paykel washing machine broken start button
My Fisher and Paykel Smart drive 503 top loading washing machine wont start. I have had a looky and i think there is just a problem with the start button, can anyone please tell me am i able to just replace this button or do i need to replace the entire Display Module? Prior to opening up the display module i noted that it said ' no field serviceable parts' which mad me think i might need to replace the entire module? which seems like such a waste when all the rest of the buttons work fine? Any thoughts on how much these cost? thanks, jules
    Habit-Forming:
    Filmmaker:
    Uploaded 5 video answers.
  • 82 Answers
Sounds like you've got the nous to fix it. They're a straightforward machine to work on, so have a go.
Here's the service manual for the Fisher & Paykel 503:
http://www.angelsnz.net/ZL3SV/misc/F&P-Washer.pdf
Posted on Feb 10, 2014
  • jules_bright Feb 10, 2014
    Hi Peter, thanks for the Parts Manual I'm sure it will come in handy down the track, but for my current problem with the start button all it does is provide me with the part number for the display module which I already have. I'm hoping I don't need to replace the entire display module.
  • Peter Feb 11, 2014
    Hi Jules, the parts most likely to fail include fuses, power mosfets, diodes and resistors rather than switches. There's a useful article on the Instructables site:http://www.instructables.com/id/How-to-r... .
4 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: fisher and paykel smart drive 503 top loading washing machine
while under the lid there should be a tech sheet, explaining varions flashing light codes and there respective fixes for each instance, replacing tha switch(out of bal switch) seems like a good start though. cant remember if jumping it out will help, might be looking for a break in the line rather than continuity through it
Posted on Nov 02, 2008
  • 3 Answers
SOURCE: fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
Posted on Feb 20, 2010
  • 3 Answers
SOURCE: Fisher & Paykel Smart Drive 7.5 washing machine.
Unplug the machine have someone tilt the machine back and look under the machine for a little fan on a motor give it a turn to see if it spins it might just be sticky or it may need replacing.
Fisher paykel washing machine fuse smartdrive
All Fisher & Paykel top load washers have 4Amp fuse for 240vac.
Apr 05, 2014 | Fisher and Paykel GWL11 Top Load Washer
Smart drive wont enter diagnostics mode
one of the buttons isn't responding properly. if it's not that then you have a board fault, which is a fault that cannot be repaired and requires replacement of the top board.
Oct 31, 2013 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel washing machine Smartdrive 703 Advance, Power and Start buttons are non responsive when pushed. Is there a part that can fix this. Does the control panel have to be replaced?
Fisher & Paykel Smart Drive beeps and stops during rinse cycle. If I hit pause and wait and restart it eventually continues. It seems like it has problems detecting water level.
Apr 13, 2011 | Fisher and Paykel GWL11 Top Load Washer
Have kelvinator smart drive 503, water won't run
I have exactly the same issue, which first appeared yesterday. Following your advice, the lights that are lit are 3rd, 5th, 7th and 8th. The SLOW & HOLD spin speed lights are lit, along with constant beeping :)
Jun 16, 2009 | Fisher and Paykel GWL11 Top Load Washer
Smart drive 5.5 washing machine lights show power on but no go
OK Problem located (without Diagnostics) , the problem was a faulty START/PAUSE button. I took the display board apart and fiddled with the button (whilst the power was UNPLUGGED) Starts almost every time, when it does`nt fiddle some more.
Dec 15, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher and paykel smart drive 503 top loading washing machine
Oct 31, 2008 | Fisher and Paykel GWL11 Top Load Washer
Wont wash
Remove lid then control panel. Unhook all terminals, remove control board, then second "box" which is further away towards back of machine. Sensor is 'back/right," under this second box. Unhook connectors & remove wee sensor carefully. On the side of the sensor is a tiny plastic button the size of a pen top. This should move in & out freely. It is spring loaded. If it sticks replace it. Good luck on your mission.
May 26, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel smart drive 708 filter
my machine swiches on but wont let it fill with water.
Any ideas?
adrian
Mar 17, 2008 | Fisher and Paykel Fisher & Paykel Washer
Washing machine
motor is starting to wear out ,replace it .
Oct 01, 2007 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
128 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
