Question about Samsung Cell Phones
Phonebook initialising i can not op phonebook
Alarm activated and is unable to deactivate
REMOTE KEY INITIALIZATION For this type of key.
The initialisation of the FZV keys is required to establish the Lock/Unlock signal synchronisation with the GM V. The initialization procedure provides the GM with a key identification number and a "rolling code" for each key. If the initialisation is not performed, the GM will not respond to the key signals. Up to 4 remote keys can be initialised. They must be initialised at the same time. Key initialisation is only possible with the vehicle unlocked.
Procedure:
1. Close all doors and have all keys available.
2. Using key number 1, turn the ignition switch to KL R, then switch off within 5 seconds and remove the first key.
3. Within 30 seconds of turning the ignition switch to "off" Press and hold button #2 .
4. While holding button #2 , press and release ("tap") button #1 three times within 10 seconds.
5. Release both buttons. The LED in the key will flash momentarily. The GM will immediately lock and unlock the doors signalling a successful initialisation.
6. If additional keys need to be initialised repeat steps 3 - 5 within 30 seconds.
7. Switching the ignition to KL R completes the initialisation.
SERVICE NOTE:
The key memory function of the GM responds to the key identification number of each key. If the keys are not initialised in the same order prior to initialisation, the key memory functions activated by the keys will not be assigned correctly. Always initialise the keys in the same order.
REMOTE KEY INITIALISATION For this type of key.
The initialisation of the FZV keys is required to establish the Lock/Unlock signal synchronisation with the GM. The initialisation procedure provides the GM with a key identification number and a "rolling code" for each key. If the initialisation is not performed, the GM will not respond to the key signals. Up to 4 remote keys can be initialised. They must be initialised at the same time. Key initialisation is only possible with the vehicle unlocked.
Procedure:
3. Within 30 seconds of turning the ignition switch to "off" Press and hold the arrow button.
4. While holding the arrow button, press and release ("tap") the roundel button three times within 10 seconds.
5. Release both buttons. The GM will immediately lock and unlock the doors signalling a successful initialisation.
SERVICE NOTE:
The key memory function of the GM responds to the key identification number of each key. If the keys are not initialised in the same order prior to initialisation, the key memory function activated by the keys will not be assigned correctly. Always initialise the keys in the same order.
Apr 08, 2014 | 1996 BMW 540i
I'm having problems with the messaging on my samsung tocco lite mobile phone! :( it wont let me access any of my messages when i press the messages icon it comes up with 'initialising' and a loading sign!...
This sometimes happens, if you have just turned off your phone this will more o rless always happen. Just give it a couple of minutes and if this keeps on happening....turn off the phone take off the back and take out the battery and sim card. Leave it for a minute or two and then put them back in and turn on your phone. Then go back onto messages, it will still be happening, leave it for a minute or two and it should be absouletly fine, the sim is just taking a long time to load thats all, there is not really much you can do! I hope this helped (:
Mar 13, 2011 | Samsung Star GT-S5233 Cell Phone
How to export phonebook to pc? How to export
Re: Export phonebook to PC:
hi, you can transfer your contact details through your pc, by first u may use phone usb, then connect your phone usb to computer and go to my computer, chech for removable disk and find their your phone motorola RAZR V3, open it, go to phonebook and you may copy your phone contacts by simply clicking right click,choose copy and you may save it to your documents.
RE: Transferring phonebook to another mobile phone?
you can do that by first activating your bluetooth under connectivity. once activated/on go ack to phonebook, click send via bluetooth.
Nov 18, 2010 | Motorola Mobility RAZR V3
How do you set the speed dial phone numbers on the Clarity D613 amplified cordless DECT
Clarity D613 Cordless Telephone
SPEED DIAL INSTRUCTIONS
To set, replace, or delete one of the nine Speed Dial numbers:
1. If you want to set or replace one of the Speed Dial numbers, and the new number is not already an entry in the phonebook, add the new phonebook entry before continuing here.
2. Press the PHONEBOOK button. The first entry in the phonebook displays.
3. Press the MENU button. The first two items (VIEW and ADD) of the seven-item PHONEBOOK menu display.
4. Press the UP/DOWN buttons (right side of the handset) to scroll to SPEED DIAL.
5. Press the MENU button. The first two items (KEY 1 and KEY 2) of the nine-item SPEED DIAL menu display.
6. The SPEED DIAL menu is displayed. If you do not want to make any (more) Speed Dial changes, press the BACK button until the HANDSET number displays, and stop following these instructions.
7. Press the UP/DOWN buttons to scroll to the KEY number that you want to set, replace, or delete; for example, KEY 4.
8. Press the MENU button. A phonebook entry appears. It is either the entry, if any, that is currently associated with the selected key or it is the first entry in the phonebook.
9. Press the UP/DOWN buttons to try to scroll to a different entry in the phonebook.
10. If you are able to scroll through the phonebook, the selected key is not currently associated with any phonebook entry and you have two options:
a. To leave the selected key without an association, press the BACK button and return to step 6.
b. To associate the selected key with a phonebook entry, go to step 16.
11. The displayed phonebook entry is currently associated with the selected key. If you want to leave it that way, press the BACK button and return to step 6.
12. Press the MENU button. A menu displays with two items (ADD and DELETE). By default, the ADD item is initially selected.
13. If you want to associate a different phonebook entry with the selected key, press the MENU button (to choose ADD). The first entry in the phonebook displays. Go to step 16.
14. Press the UP/DOWN buttons to scroll to DELETE.
15. Press the MENU button. DELETED displays. The selected key is now not associated with any phonebook entry. Return to step 6.
16. Press the UP/DOWN buttons to scroll to the phonebook entry that you want to associate with the selected key.
17. Press the MENU button. SAVED displays. The selected key is now associated with the selected phonebook entry. Return to step 6.
To call one of the nine Speed Dial numbers:
1. Press and hold the desired Speed Dial key (1 through 9 on the dial pad). The selected key number displays. If the key is associated with a phonebook entry, the call begins within a few seconds. Otherwise the phone beeps twice.
2. Release the key. If the key was not associated with a phonebook entry, you can either press the BACK key to return the phone to standby, or you can press the CLEAR key and then press a different Speed Dial key..
To review the phonebook entries that are associated with the Speed Dial keys:
1. Press the PHONEBOOK button. The first entry in the phonebook displays.
2. Press the MENU button. The first two items (VIEW and ADD) of the seven-item PHONEBOOK menu display.
3. Press the UP/DOWN buttons to scroll to SPEED DIAL.
4. Press the MENU button. The first two items (KEY 1 and KEY 2) of the nine-item SPEED DIAL menu display.
5. Press the UP/DOWN buttons to scroll to the KEY number that you want to review; for example, KEY 4.
6. Press the MENU button. The associated phonebook entry appears.
7. Press the BACK button.
8. If you want to review more Speed Dial associations, return to step 5.
9. Press the BACK button until the HANDSET number displays.
Dec 27, 2009 | Clarity Lands Phones
Samsung SGH J750 Shuts Down
As Xewl said, return the phone. It is obviously defective on a pretty high level.
Apr 08, 2009 | Samsung J750 Triband Black Unlocked 3G...
Can't enter phonebook numbers - Says memory full
Clear out your caller ID, These phones use a shared memory, once the caller ID is cleared, you should be able to store names/numbers in the phonebook.
Feb 17, 2009 | Uniden TRU8885 Digital Answering Machine
My phonebook keeps initialising
For how much time it is being initialised it may be due to virus i have faced the same problem its due virus just format the phone and memory card.Then when ur copying into ur mobile just scan those files and copy virus free files......If ur problem solved just vote me
Apr 23, 2008 | Cell Phones
Phonebook problem
is your phonebook located at the sim or in the phone book?
Dec 22, 2006 | Motorola Mobility RAZR V3
Cell Phones Logo
15 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
