Question about Garden
Honda umk 422 will start briefly and stop than wont start until 15 minutes later briefly and stop again
Checked sparkplug and it sparks
  • 59 Answers
SOURCE: 92 honda wont start
did you replace the the plug wires right i would double chect them and make sure and check the disribotor. and try runing some fuel injector clener through it. after you check all that can you start it with starting fluid
Posted on Jan 04, 2009
SOURCE: Kenmore 80 series dryer stoping after running for 10 to 15 minute
Start any cycle. Dryer runs for 10 to 15 minutes, then stops before cycle is complete. Start again, stops again in 10 to 15 minutes.
Posted on Jan 26, 2009
SOURCE: 1990 Honda Civic 1.5 Liter Wont start has spark and fuel.
Its ur fuel relay under ur steering colum, its a big black box
l l About that big, should have white numbers on it
l l
l l
l l
l l
l l
---------------------------------------------------------l
Posted on Feb 24, 2009
dsacco86
  • 1077 Answers
SOURCE: Code error P1361 Honda CIvic LX 2002
P1361 TDC Sensor Intermittent Interruption (I got this from Engine-Light-Help.com)
TDC should mean Top Dead Center.
It is the sensor that tells the computer the #1 cylinder piston is at the very top. And therefore, fires the spark plug.
Since the maintenance done above, I believe the the timing marks for the timing belt is not lined up properly. Being off by one tooth will cause this problem.
Posted on Mar 21, 2009
  • 5 Answers
SOURCE: ford laser 1990 model wont start
well my ford taurus had hte same problem and we fixed it my putting the peddle to hte floor when we cranked it.
Posted on Mar 26, 2009
02 mercury sables starts but within 6 minutes shuts completely down. Won't start for bout 15 minutes later then shuts down again.
Something electronic is overheating , transistor , . the engine computer , ignition module . crankshaft position sensor. Also check PCM power relay . losing power . Check for spark , fuel pressure when it stops running , see what is missing .
Jun 21, 2016 | Mercury Cars & Trucks
I think i lost the spark engine just cranks over but does not start
then just check if you have spark at any of the sparkplugs...
1. remove one of the spark plugs,
2. re-connect the cable
3. make contact between sparkplug anode and engine (have rubber gloves - it helps... there is 15kv on the sparkplug...)
4. turn engine and check if there is spark in
you can check that on all/any cylinder
if there is no spark - check:
1. starter fuse
2. ignition fuse
3. coil
4. distributor cap if mechanical...
hope this will help you - do not forget to vote...
Feb 22, 2015 | Cars & Trucks
MY MOWER WILL TURN OVER BUT IT WILL NOT START
if you spark a little starting fluid to it does it fire?if so then fuel is the problem then is the gas older than 30 days dump it out and try fresh gas if new gas then open the carb and clean it if it does not fire on starting fluid check for spark if no spark pull the top cover from the engine and look for wiring damage unplug the coil from the engine side of the coil and check for spark if no spark then the coil is bad and if its a riding mower the carb might have a anti back fire valve that could stick closed
Apr 27, 2012 | Garden
Not firing on 1 cynlinder
change faulty sparkplug or ht lead,check lead by holding sparkplug end near to engine nearly touching,have someone turn engine over whils checking for spark jumping,if spark present then not lead,change spark plug,if sparkplug ok then check pressure in cylinder, poss piston damage
Jan 02, 2012 | Cars & Trucks
I have a gx610 that runs nicely for about 3 minutes to 5 minutes then it stops FAST. Like very sudden. It wont start or crank again until a few minutes pass then it cranks, and a minute later or so it...
Check for plugged fuel tank vent. Vacuum builds up then fuel stops. Also check if it has a low oil presssure switch that might cut it off (check the oil level). This engine has many variations so finding a specific problem is not easy.
Apr 25, 2011 | V-Twin Horizontal OHV Engine with Electric...
No spark
Have you checked that the ignition switch is on. If so, then check the oil level. Then take the sparkplug out and replace. If still no spark, the ignition coil may be faulty. Take the sparkplug out of motor and rest it on the outside of the hole. Slowly pull the motor over and you should be able to see a spark coming from the sparkplug. If there is no spark then there will be a problem with the ignition coil. Put new ignition coil on and test.
Jan 07, 2011 | Honda Pressure Washer PSI 3000
2001 gti won't start, it cranks.
the first thing to do is find out whats missing, you will need to see if it has fuel going to the engine, this is done with a fuel pressure gauge, then you need to check for spark, remove a sparkplug wire from a sparkplug and with a spark tester check for spark, there could be a loss of spark or fuel and last thing may be a broken timing belt.
Jan 02, 2011 | 2001 Volkswagen GTI
I will be driving down the road and the check engine light comes on and the engine stops running i let it sit for 10-15 minutes and it starts again
What model and year honda do you have? If it's an accord, 90-93, take a look at your distributor by checking for spark, when the engine dies. If no spark, it's usually a bad distributor on those year accords.
Oct 13, 2010 | Honda Civic Cars & Trucks
My 95 honda civic stop when im driving and wont start again until later.
You need to verify what is missing when it won't start, spark or fuel!
Jul 28, 2010 | 1995 Honda Civic
Garden Logo
60 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
