Question about Bosch Dishwashers
Dishwasher not dying the dishes - Bosch Dishwashers
    Problem Solver:
  • 14 Answers
Use jet dry.
Posted on Apr 08, 2014
Where is the flood switch on die dietrich dishwasher dvh640ju1
these are normally in the bottom of the dish washer
micro switch controlled by a float
Feb 15, 2014 | De Dietrich DVH610JU1 24 in. Built-in...
Ge profile dishwasher not cleaning
Our GE dishwasher never did clean correctly. Then it died. WE bought a new dishwasher different brand . New dishwasher is cleaning great clean dishes now. GE Dishwashers sucks!
Nov 10, 2013 | GE 24 in. Profile PDW7800 Built-in...
Dishwasher not cleaning dishes
If it is a cheaper brand/model of dishwasher, you may have to rinse the dishes, especially if they have been sitting for a while. While there are dishwasher who are powerful enough to clean even crust off the dishes, most need to have the dishes rinsed off even just with cold water right after use....If you do not use alot of dishes per day and let the washer build up dishes after a few days then I would recommend a warm/hot water rinse even with a dish sponge and some soap. While some may think that this defeats the purpose of using a dishwasher, remember that a dishwasher is more sanitary that using a dish rag or sponge that had the opportunity to build up bacteria and other gunk over a period of time ;-)
Aug 28, 2013 | Kenmore Dishwashers
Dishes not coming out clean
Hello
There are some things you can try, however, if your Maytag dishwasher is not getting your dishes as clean as you would like. Maytag recommends several processes for fixing this issue with your dishwasher.
Do not run your Maytag dishwasher while hot water is being used in other parts of your home, such as washing clothes or showering. Hot water is needed for your Maytag dishwasher to properly clean dishes.
Run water in the sink in your kitchen until it gets very hot. Then, turn on your Maytag dishwasher. This will ensure that the water cleaning your dishes is the hottest possible temperature.
Clean your Maytag dishwasher to improve the cleaning results for dishes. Run your dishwasher on a short wash cycle and wait for it to fill up with water. Stop the cycle and add about 1/3 of a cup of rust remover to the dishwasher and finish the cycle. Run your Maytag dishwasher through one normal cycle with regular detergent to finish the cleaning process.
Check your detergent. Old detergent or those that have been exposed to moisture can be clumpy. This detergent will not clean your dishes as well when loaded into your Maytag dishwasher. Purchase fresh detergent.
Use extra detergent when washing dishes that have a lot of built-up grease or food particles. The extra amount of detergent is needed to get your dishes clean. Choose a long cleaning cycle to clean these dishes.
Fill your Maytag dishwasher properly. Dishes should not be stacked on top of each other or excessively crammed into your dishwasher. This will keep the dishwasher from adequately cleaning all areas of your dishes and from rinsing them thoroughly.
Sep 13, 2011 | Maytag Dishwashers
Dishwasher has a terrible odor in it. I'm guessing it came from an empty sauerkraut glass jar and lid I put through the wash, heated dry and sanitize cycle. How do I get rid of that nasty, something...
Check whether the smell comes from the main drain. Pull your dish washer drain hose and check.
Leave dishwasher door open for few hours. Hope no rate has died inside the machine.
Run a empty wash several times!
Sep 26, 2010 | Whirlpool Dishwashers
Dirty dishes
On the bottom pull the wash arm straight up and out. It shouldn't be clipped because they held in by gravity. Under there is where you will find extra crud that gets lodged underneath the arm where you can't see it. Do you fill the rinse agent reservoir? Also try using liquid tabs or gel if you are using powder. Hope it helped!
Jan 12, 2009 | GE Nautilus 24" Built-in Dishwasher
My dishwasher isn't cleaning my dishes!!!
Look and see if the seals at the back of the dishwasher are worn. They may need to be replaced. The seals are easily removed and new ones replaced. If that isnt it then check to make sure the pump screen is not clogged. Remove the screws to the covers in the bottom of the dishwasher to expose the screen.
Aug 29, 2008 | Maytag 24 in. MDB8600AWS Jetclean II...
Dirty glasses
there is a new product out called the dishwasher filtration system. it actually filters the water going into your dishes. the dishes look dirty because your water has a lot of calcium and magnesium in it making them appear cloudy or dirty. the dishwasher filter reduces those minerals and my dishes look perfect now. no more dirty and grimy looking dishes. i also dont waste time washing them by hand before and after the dishwasher. hahaha you can get it at www.dishwasherfilter.com. use code DFMTEN and you will get 10% off. it fits right under your sink and is very affordable. you will be glad you bought this product. thanks
Sep 29, 2007 | Tricity Bendix 24 in. BDW53 Free-standing...
Dishwashers Logo
170 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
