Question about Brother MFC-8670DN - 30 PPM Multifunction Network Monochrome Duplex Laser Printer, MFC8670DN, MFC 8670DN
Brother mfc 8670 paper jam duplex
No longer able to print 2-sided or booklet output- the page jams after printing the "front" side and the paper goes into the back drawer, then it jams, producing the message "paper jam duplex".
    Habit-Forming:
    New Friend:
  • 81 Answers
Remove the small, or scratch into pieces inside the duplex to clear the paper jam.
Posted on Feb 15, 2014
    Top Expert:
  • Brother Master
  • 11,573 Answers
Posted on Aug 03, 2016
4 Suggested Answers
Healeyman
  • 1198 Answers
SOURCE: Paper jams 1/2 way through drum/cartridge. Jams
Take the toner cartrige out, look around with a flashlight for a piece of paper or something that could jam the works. Check the movable tab that comes out of the front of the machine to hold paper up, maybe it has gotten crooked or something. Don't have anything in front of the machine to block the paper coming out. A can of compressed air can be used to blow the machine out.
Posted on Apr 26, 2009
intower18
  • 957 Answers
SOURCE: Brother CDW 4070 Duplex "jam".
1.Determine where the paper is jammed in the ADF on your Brother printer-- in the top or bottom of the unit.
2.Access the paper. If the paper is jammed in the top, open and flip down the cover on the left side of the ADF. If the paper is jammed in the lower part of the unit, lift up the document cover.
3.Grasp the paper on both sides and carefully pull it toward the right side of the machine and away from the feeder -- up slightly and right if working from the top; down and right if working from the bottom. If the paper rips and the remaining piece or pieces are too small for you to grasp with your fingers, access them from the opposite side or remove them with tweezers.
4.Return the ADF or document cover to its original position once you've removed all of the paper.
5.Push the "Stop/Exit" button to reset the printer to remove the error message from the display so you can start printing again.
Posted on Sep 05, 2011
puertobori
  • 7733 Answers
SOURCE: Brother MFC-8670. When we print we get a clicking sound from the left side of the printer and no paper is fed
Try here http://welcome.solutions.brother.com/BSC/public/us/us_ot/en/faq/faq/000000/002000/000024/faq002024_007.html?reg=us&c=us_ot&lang=en&prod=mfc8670dn_us&Cat=113
Posted on Dec 04, 2011
Duplex printing with card stock paper jams in back on Brother MFC-9840CDW
I would try manually inserting the paper for the back side. Most of the time it's best to wait a few minutes before trying the back side to give it time to cool so it will lie flat.
Sep 08, 2017 | Brother MFC-9840CDW Laser Printer
Paper Jam in Duplex mode when printing more than 1 sheet
check between the rollers there will be small bits of paper jammed in that is the reason.
Sep 09, 2008 | Minolta magicolor 2350 Laser Printer
Tip
How to make duplex copies with a Brother MFC-240C printer
The Brother MFC-240C is a well-performing multifunction color printer. There is a lot that it can do, but one limitation it has is the inability to make double-sided copies. If you need to make a duplex copy of something, you can do it manually by re-feeding the paper once you've copied the first side.
After the first side of the page has been printed, let the paper sit for a minute or so to make sure the ink has dried. Then, put it back into the paper tray on the top of the stack. Make sure the back side of the page (the side that has not been printed on yet) is facing down, and the lead edge of the page (the edge that was fed out of the printer first) is facing toward the inside of the printer, rather than toward you.
Once the paper is set, push the tray back in and print the document or image that you want to appear on the back of the page. If you are printing multiple pages, position the paper so that the page you want printed on first is on the top of the stack.
The MFC-240C was not designed for duplex printing, so you may run into some issues with it, especially when you are using very thick or very thin paper. With very thin paper, the ink may bleed through to the other side of the page. With very thick paper, you may have to let the paper sit for a longer time after the first side is printed, because the ink could take longer to set and dry.
on Jul 06, 2010 | Brother MFC 240C All-In-One InkJet Printer
Duplex feed not working
Check the C6200 Device Settings in the properties and make sure that the Duplex Unit is installed.
original?v=mpbl-1&px=-1
Dec 09, 2013 | Brother HL 5250DN Laser Printer
I have a 18 mo old 8500 OJPro wireless that won't advance the paper, makes a clicking sound and gives a false paper jam error. I have seen a split white gear within a black clutch assembly on the left end...
Follow these steps in the order presented to resolve the paper jam. Step one: Remove any loose paper Remove any loose sheets of paper from the input tray and the output tray. CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism. Remove any loose paper Do not pull jammed paper c02073375.gif c01994705.gif Step two: Clear the jam from the rear of the product CAUTION: Never pull jammed paper from the front of the product. If you can pull it from the rear of the product or the tray, always try the rear first. Pulling paper from inside the front cover can cause mechanical damage to the product.
  1. Press the Power button (c01602202.gif ) to turn off the product.
  2. Disconnect the power cord from the rear of the product.
  3. Unplug the power cord from the wall outlet.
  4. Turn the product around so that you can access the rear side. Figure 1: The rear side of the productc01617574.gif
  5. Push in the button on either side of the two-sided printing accessory (duplexer), and then remove the duplexer. Figure 2: Remove the duplexerc02051407.gif 1 - Press the buttons on the sides of the duplexer 2 - Pull the duplexer out of product
  6. Gently remove any jammed paper or bits of torn paper from the rollers inside the product. Use both hands to pull any whole sheets of paper to avoid tearing them. Figure 3: Gently remove the jammed paperc02073376.gif CAUTION: Use a flashlight to thoroughly check the rollers and wheels for torn pieces of paper that might remain inside the product. If any torn pieces of paper remain inside the product, more jams are likely to occur. Figure 4: Remove scraps of paperc02073377.gif
  7. If you do not see jammed paper in the rear access area, push the buttons on the latch on the rear of the duplexer, and then lower the cover. Figure 5: Open the duplexerc01617577.gif 1 - Latch on rear of the duplexer 2 - Duplexer cover
  8. Remove any jammed paper from inside the duplexer.
  9. Close the duplexer cover.
  10. Gently push the duplexer into the product until it snaps firmly into place. Do not press the buttons on the end of the accessory while you reattach it. Figure 6: Reattach the duplexerc01617578.gif
  11. Reconnect the power cord to the rear of the product.
  12. Plug the power cord back into the wall outlet.
  13. Press the Power button (c01602202.gif ) to turn on the product.
Step three: Print a self-test report Follow these steps to print a self-test report. Printing a self-test report verifies if the hardware functions correctly.
  1. Load unused, plain white paper in the input tray.
  2. Press the Power button (c01602202.gif ) to turn on the product.
  3. Press the Setup button (c01726396.gif ).
  4. Press the Right Arrow (c01185072.jpg ) to select Print Report , and then press OK .
  5. Press the Right Arrow (c01185072.jpg ) to select Self-Test Report , and then press OK . The self-test report prints.
Oct 30, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Our machine shows E051. so what can i do.
The JAM DUPLEX message appears if you remove a sheet of paper from the face down output tray after only one side has printed.
The paper sizes you can use with the duplex printing function are A4, Letter or Legal.
If the paper adjustment lever for duplex printing is not set correctly for the paper size, paper jams may occur and the printing will be out of position on the page.
Open the back output tray.
Use both hands to slowly pull the jammed paper out of the fuser unit.
Close the back output tray.
If the paper jam cannot be cleared, go to the next step.
Pull the duplex tray and paper tray out of the printer.
Pull the jammed paper out of the printer
Put the duplex tray and paper tray back in the printer.
Click solved and vote if problem is solved. Otherwise post again
Aug 02, 2010 | Office Equipment & Supplies
Paper feeding problem with MFC-8670
Try REMOVING the white caked up paper dust from the pickup roller located at the front of the paper tray. Next, clean the pickup roller with either 409 or Fantastic all purpose holdhold cleaner using a Q-Tip or a rag.
May 10, 2010 | Brother MFC-8460N Laser Printer
Double sided copying
http://www.brother-usa.com/ModelDocuments/Consumer/Software%20Users%20Manual/SUM_DCP_7030_7040_MFC_7340_7345N_7440N_7840W_EN_1650.PDF
here is the manual p4 and p16 discuss the topic:
Duplex printing 1
The supplied printer driver supports duplex printing.
Guidelines for printing on both sides of the paper 1
�� If the paper is thin, it may wrinkle.
�� If paper is curled, turn over the stack, straighten it and then put it back in the paper tray or the Manual Feed
Slot.
�� If the paper is not feeding properly, it may be curled. Remove the paper, straighten it and turn over the
stack.
�� When you use the manual duplex function, it is possible that there may be paper jams or poor print quality.
If there is a paper jam, see Paper jams in the User’s Guide. If you have a print quality problem, see
Improving the print quality in the User’s Guide.
Manual duplex printing 1
The machine prints all the even-numbered pages on one side of the paper first. Then, the Windows® driver
instructs you (with a pop-up message) to reinsert the paper. Before reinserting the paper, straighten it well,
or you may get a paper jam. Very thin or thick paper is not recommended.
Simultaneous scanning, printing and faxing 1
Your machine can print from your computer while sending or receiving a fax in memory, or while scanning a
document into the computer. Fax sending will not be stopped during PC printing. However, when the machine
is copying or receiving a fax on paper, it pauses the PC printing operation, and then continues printing when
copying or fax receiving has finished.
�� Manual Duplex
Check Manual Duplex. In this mode, the machine prints all the even numbered pages first. Then the
printer driver stops and shows the instructions required to re-install the paper. When you click OK the odd
numbered pages are printed. There are six types of manual duplex binding directions available for each
orientation.
�� Booklet Printing
When you want to print a booklet, use this function. To make the booklet, fold the printed pages down the
middle.
�� Binding Offset
If you check the Binding Offset option, you can also specify the offset for binding in inches or millimeters
May 14, 2009 | Brother MFC-7440N Laser Printer
Canon mx850, paper jams when reloading for two sided copies. once the 1st side is printed the paper is released, recaptured and starts to feed back into the prt. 1/3 into the feed it jams, paper is...
Mel, this is what I found in the online manual:
Set the Ink Drying Wait Time longer.
Doing so gives the time enough to dry the printed surface so that paper curling and ink blots are prevented.
(1) Make sure that the machine is turned on.
(2) Open the printer properties dialog box.
See Opening the Printer Properties Dialog Box Directly from the Control Panel.
(3) Click the Maintenance tab and then Custom Settings.
(4) Drag the Ink Drying Wait Time slide bar to set the wait time, and then click Send.
(5) Confirm the message and click OK.
Make sure that the actual size of the paper is suitable for automatic duplex printing.
The sizes of media suitable for automatic duplex printing are A4, Letter, A5, B5, and 5" x 7".
Load paper of suitable size and then press the OK button.
Make sure that the Page Size or Paper size setting matches the actual size of the paper with a size suitable for automatic duplex printing.
First, check the Page Size or Paper size setting in the application software you are printing from.
Then, check the Page Size setting on the Page Setup sheet in the printer properties dialog box (Windows) or the Paper size setting on the Page Setup dialog box (Macintosh).
Note
Depending on the version of the application program, the automatic duplex printing may not be supported.
Make sure that the type of loaded paper is suitable for automatic duplex printing on the Main sheet (Windows) or the Quality & Media sheet on the Print dialog box (Macintosh).
Note
To switch to manual duplex printing, follow the procedure below.
Open the printer properties dialog box, clear the Automatic check box on the Page Setup sheet, and reprint.
When performing manual duplex printing, note the following.
If you are printing three or more pages of a document with manual duplex printing, one side of all sheets of paper will be printed first. Turn over the paper and reload the paper in the machine, and then the reverse side of all sheets of paper will be printed. Be careful not to change the order of paper in the stack.
The procedure for reversing the paper varies depending on the staple side and printing orientation. Follow the on-screen instructions.
MX850 series On-screen Manual for Windows:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=16279
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 11, 2009 | Canon PIXMA MX850 multifunction InkJet...
Oki C9300 - paper keeps jamming in the 2 same places, reads either 383 paper jam or non paper sense error. All drums and tonners are new, paper is loaded.
your getting a 383 paper jam, find paper in two different places.
See if it's a duplex related problem. print single sided documents, if that works, try printing two sided documents (it'll be the duplexer) if it only fails while printing duplex.
Also, check the back door. Make sure the back exit tray is closed all the way.
You can also have a paper jam in the duplex unit (open the front door), the duplex unit slides out the front. You can easily remove the duplex unit and run the printer without it.
Oct 20, 2008 | Office Equipment & Supplies
Brother MFC-8670DN - 30 PPM Multifunction Network Monochrome Duplex Laser Printer, MFC8670DN, MFC 8670DN Logo
373 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
