Question about mkoss Untangle me
Untangle me: Is there a solution for levels 49, 88 en 90?
I've tries many times to solve 49, 88 en 90, but keeping ending up with the same end results. They seem to be unsolvable.
How too do the bleeding of power steering pump on 2007 Jeep compass?
Bleeding a power steering pump in general is just by moving the steering wheel from end stop to end stop. Do not keep it at the end stop for a prolonged time, because it will put a lot of stress on the pump and lines. Keep an eye on the power fluid level, because when air comes out, the level will drop.
Sep 20, 2014 | Jeep Compass Cars & Trucks
My gauge does not work, what can I do
Usually when this happens it is the fuel level sender. Occasionally it is the gauge, and once in a while it is the wiring somewhere in the fuel level sending system. The fuel level sender for most Dodge trucks can be purchased for about $90 and assuming that you do not have a lot of gas in the vehicle could be about 2-3 hours labor. Replacing the actual gauge is also timely but a new gauge could only cost about $20, and could be done on a week end afternoon with little to no experience. Checking the wiring (which I would fo just to save the time of changing stuff to find this out) only takes a fwe hours and could cost you the price of a digital multimeter, that you can get from your local parts store or Walmart. Keep me posted....
Oct 19, 2011 | 1996 Dodge Neon
Hello, I have a Lexmark 2670 which is relatively new. When trying to print an alert keeps popping up saying "Scanner Unit Open". I've tried different things, but don't know why this is...
Hi
Check your System scanner application is running. Open the End Task manager select the tab process and see there may be scanner.exe is there select that one and click end task.
Try it.
Cheer
Jun 05, 2011 | Lexmark X2670 All-In-One Printer
Are the ends adjustable? We need to turn the attachment point/bracket 90 degrees on the ball-socket end. Is this possible, or are they fixed permanently?
Sorry, but that question has me totally confused.
I keep trying to picture tie rod ends, ball joints, etc., and I have no idea what you are asking for?
Mar 12, 2011 | Volkswagen Camper Cars & Trucks
Dryer will not shut off in any 'auto' mode. Time display ticks down, then jumps up again and keeps running. Dryer does works properly when 'timed dry' is selected. Checked and cleaned exhaust vent. ...
How long is the vent from the dryer to the outside? Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dry-ability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
Jul 14, 2010 | Samsung DV337 Electric Dryer
Machine filled with water, but now won't continue with the cycle. How do I get the water out?
The easiest way is to siphon the water out with a hose. A small diameter plastic hose or tubing works the best.
Stick the hose in the water and drawn water up the hose or tubing by sucking it up...then either slide your finger over the end quickly so that the water doesn't drop out or lower your head till it is bellow the water level and stick the end of the hose in a bucket.
The water will flow right over the side and iinto the bucket.
Keep the end in the water or you will lose the suction. also keep the end outside the washer lower then the water level so it will continue to run.
This takes a bit of practice but will go easily once you get the hang of it...
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 16, 2009 | Maytag Washing Machines
What is java programming language?
http://en.wikipedia.org/wiki/Java_(programming_language)
In order to understand the difference between high-level programming languages and lower level languages you might have to have a deeper knowledge of computers than you currently have, although I can try to the best of my ability to explain it simply.
Lower level programming languages are more directly related to the actual machine language that the computer ends up reading in the end. Higher level programming languages are less representative of the actual machine code, and as a result may require either a more advanced compiler or may require being compiled several times. Generally higher-level programming languages are easier for the user to write in than lower-level languages.
Nov 11, 2009 | Sun Computers & Internet
Just hung sony 46''flat screen tilts slightly measurements =
this is quite common on older houses/buildings and on occasion newer ones aswell, when a house is built a decent carpenter keeps his building fairly level, usually within 1/16th of an inch, but there are times when this exceeds 1/16th of an inch, personally i'v seen houses being built where the whole foudation is off 1/2 inch or more end to end, and on older buildings as time goes by the foundation "settles" into the ground, depending what it was built on the whole building could settle further on one end of the house than the other, this can cause cracks to form in foundations. So if your tv is "level" (be sure to try another level) and your measurments are out, this usually means your house or building isn't level or the surface which you are measuring from isn't level. But be sure to try 2 or more levels to ensure the TV is in fact "level", hope this helps.
Sep 30, 2009 | Televison & Video
Toner cartridge is full - "toner life end"
when the printer is in "ready" state, press the GO and SET at exact the same time.
Now, using the (-) < button you can choose any "service" option to fine tune te printer
TONERLIFEEND is the first in the list, press the "set" button en chose "Nothing" and press "Set" again
Jun 22, 2009 | Brother HL-6050DN Laser Printer
Recharging problem
just wrap the aluminium foil (kithchen foil for food wrap) around the pin and it should be tight enough to make contact and grip, as its aluminium metal it will allow the electricity to pass on... and your device gets charged.. only point is if you keep on removing the plug and re connections... if just keep it always connected , this trick should solve your issue.. other wise try to glue the alumininum foil to it self by gluing at overlapping one end on the other end.
make sure the foil doesnt go in front( ahead of the charging pin tip, other wise if it may enter inside the tip and both + ve and -ve poles get connected , which may spoil the devices).. hope it solves your problem
Feb 28, 2008 | Magellan RoadMate 800 GPS Receiver
mkoss Untangle me Logo
113 people viewed this question
Top mkoss Apps Experts
Are you a mkoss App Expert? Answer questions, earn points and help others
