Question about Kitchen Appliances - Others
Ice matic machine
Hi there I have an Ice matic N131M it makes a single load of ice then the alarm comes on and stops working. I have switched it off and back off an back on again and the same thing happens.
22yooper
  • 828 Answers
SOURCE: Not making ice
If your machine is air cooled it is possible that the condenser fan motor is not running when necessary or the fan switch that turns the fan on by pressure may be defective.
Posted on Oct 23, 2008
SOURCE: b195 ice maker not making ice
the solenoid might have packed it in
Posted on Oct 27, 2008
SOURCE: GE Profile side by side fridge - water dispenser doesn't work
More than likely, your water line is freezing up in the door. You can remove all of the ice cubes and lower the freezer temp to about 3. Leave the freezer door open for about 5 minutes or so and if this does not work, leave the door open a little longer. Also, disconnect the water line at the base of the freezer door, near the floor, and press the dispenser lever. If you have water there, you most likely have a frozen line in the door. Changing the water filter often will help but it is not the answer and is can get quite expensive. By the way, Make sure to hold the dispenser lever forward for at least a couple of minutes each time you test for water flow. If you do not get water at the connector at the base of the door after you have disconnected the line, you have a problem with the valve in the back of the refrigerator.
Posted on Nov 17, 2008
  • 85 Answers
SOURCE: Ice maker makes ice, but won't dispense.
if you hear a click when the actuator is depressed the swt is ok remove ice bin and try rotating auger mtr by hand if you can't the auger motor is frozen, you can remove the whole auger asm and let it thaw out and dry out for a few days
Posted on Dec 14, 2008
  • 37 Answers
SOURCE: Whirlpool Ice Magic Plus not make ice at all.
The most likely cause is the water solenoid behind the fridge. Take an ohm meter and test across the two terminals and it should NOT ohm out(beep). If it does not ohm out I would replace the P.C. Board kit, emitter & receiver icemaker control.
Posted on Jan 03, 2009
Ice getting to thick and not dumping
go to the freeze timer which has off and on dip switches. take some freeze time out by moving the first switch to off this will shorten freeze time. Also check the harvest assist solenoid and plunger when it go's into harvest. make sure the machine is cleaned and check the cube plate to make sure that none of the plates are not loose this will cause ice to freeze between the loose spots and will not let ice come off the plate.
Jul 21, 2014 | Ice-O-Matic ICEU220HA Undercounter Ice...
Where is the low pressure control and why cant the timer be bad on the ice o matic ice machine
Low pressure switch is usually in the control box which has a cap tube that connects to the low side of the system the timer can be bad but all a timer does is add a few mins to the end of your cycle but if you not making any ice you may have another issue
Apr 04, 2014 | Ice-O-Matic ICEU220HA Undercounter Ice...
Icematic n131m
The more activity the freezer and fridge see, the more cold escapes. If the freezer defrost system gets issues (broken defrost heat coil, stopped up vents, frozen peas in coils) things slow down. Find the defrost timer and mark the knob on it with white-out to see if it moves. It moves very slowly, one rotation a day.
Nov 26, 2013 | Kitchen Appliances - Others
I have a ice o-matic model iceu220ha1 freezes but will not go into harvest
Go to Google put in model number ICE220ha1 when it comes up the fourth one down, Service parts manual The ice series under-counter... It is a PDF down load it then go to trouble shooting look for not going into harvest this will tell you what to look for.
Oct 24, 2013 | Ice-O-Matic ICEU220HA Undercounter Ice...
Machine has stopped working and is in alarm
Possibly a stuck or defective ice level switch in the ice bin. It's supposed to cease the ice making when the bin gets full and then return the ice making components back on when the ice level drops to a certain level. Should be an easy fix if the switch is bad. The wires have push connectors on them.
Sep 06, 2017 | Kitchen Appliances - Others
I'm having problem with my icematic 132M . I freezes the cubes allright , but the cubes doesnt fall out before the harvest stops, so the cubes is still hanging on in the machine which causes the m
First i would clean the machine per manufacturers instructions with nickel safe cleaner and sanitizer. When the plates get dirty it will cause ice to hang on to plate. Also check the thickness of ice if to thick it will not come off plate.
Oct 08, 2012 | Ice-O-Matic ICEU220HA Undercounter Ice...
Making ice but won't drop it, then the compressor stops working.It is a Ice-o-machine
You can try and adjust your thickness a bit thicker. If this does not help, your hot gas bypass is not working and the evaporator is not warming. You will need a technician.
Apr 21, 2010 | Ice-O-Matic ICEU220HA Undercounter Ice...
Kitchen Appliances - Others Logo
21 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
