Question about Brother Sewing Machines
How do I embroider Somerset House with Somerset above House?
I have a viking designer 1. When I put the embroidery arm on the pressed foot will not stay down. But does stay down when regular sewing arm is attached.
When embroidering, the presser foot hovers above the fabric a few millimeters. The machine does this automatically.
May 04, 2015 | Sewing Machines
Not embroidering
you say it runs, is the needle going up and down or is just the motor running
Apr 21, 2014 | Brother PE-770 Embroidery Machine
How do you start embroidering a design where the thread breaks on a Bernina Artista 180 sewing/embroidery machine?
Most machines have a stitch counter, stitch forward and step back features. Check your manual and embroidery machine's screens for this.
IN case you have misplaced your manual I found this one for you. It's big so allow time to download.
http://www.itsastitchonline.com/mastery_on_the_web/Mastery_170_180_1-10-02.pdf
Sep 10, 2012 | Bernina Artista 180
My brother 270D keeps shutting off
Take your machine back to the other side of the house. See if it works better there. If it does have an electrician come out and check the new location's power. There may be a problem in the houses wiring.
Sep 07, 2012 | Brother SE-270D Computerized Sewing...
Manual/picture codes
what's the name & model number of the machine?
Feb 26, 2012 | Brother Sewing Machines
I have a Husqvarna Angelica sewing machine and need the user manual to learn how to operate it. #73901664 Q96287. elaine emr@pitt.edu
Try this :
Husqvarna - Viking Ltd,
Viking House,
Wedmore Road,
Cheddar,
Somerset,
BS27 3EB.
01934 744533
That info is a little old. But you may get lucky. Also try The Sewing Machine Trade Association for a local dealer.
Nov 10, 2010 | Husqvarna Viking 1
Viking Designer 1 won't embroider
I have seen some of the older style machines that are very susceptible to static charge. Usually this doesn't happen with newer ones. If you get static shocks on door knobs in your house, do not touch the screen of your machine with your finger. Use a stylus instead. You may also try touching the metal presser bar just above the foot and ankle when sitting down at the machine prior to using the screen. This should not be happening with a new machine. Check with your dealer.
Nov 24, 2008 | Husqvarna Designer I
Sewing Machines Logo
48 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
