Question about Epson LX Office Equipment & Supplies
BARCODE PRINTING ON INKJET PRINTER - LX Epson Office Equipment & Supplies
3 Suggested Answers
LineMatrix
  • 34 Answers
SOURCE: intelligent mail barcode
I'm 75% sure it will, without looking at the postal intelligent mail barcode printing specifications... I will be glad to answer your question, if you can get me the Specs. for the new postal intelligent mail barcode... the other important question is... what is you current IBM 6400-XXX printer configuration? press the print config, then the Start on your printer. 1st Paragraph is all you will need to give me... Worst case, you might need a differenent Emulation program...
Posted on Mar 14, 2009
Nic61
  • 1073 Answers
SOURCE: s there any free software for running Datamax E 4203 Printer? it is meant for printing library barcode labels.
http://www.datamaxcorp.com/software/e-class/
There u go!
Manuals, drivers, firmware and utility for the E-class,E-4303,E-4204 and E4304
Good luck
Nic
Posted on Apr 24, 2009
Printing barcode using font 39
The printer can get out of "phase" and the print will look shaky. These instructions are for the P5000 but the phasing process has not changed.
http://themrpsolution.com/v//vspfiles/Tech%20Tips%20Q&A/Printronix/P5000_phasing.pdf
Jan 14, 2016 | Printronix P7220 Matrix Printer
BROTHER MFC J435W BARCODE PRINTING PROBLEMS
Sounds like a problem with the printer. The software that came with the printer should have some tools that might help you, My old Epson printer came with a set of tools, one in particular tool (which may help you) was head aligment. This use to fix the issue of non straight lines being printed. Head cleaner was another tool i would use to have thin consistent lines printed. Check your printer install cd and add the extra software if all you have installed is the basic driver.
Dec 14, 2013 | Brother International Brother MFC-J435W...
We're using 4.00 X 2.00 inch labels. The barcode is printing just under an inch long when it should be about 2 inches long so our scanners cannot read the barcodes. The text is printing out the
in some barcode software you can see the preview. if you click on the barcode itself maybe you can stretch it out to fit better. or try swapping to 2 by 4 format and see if that works. good luck
Aug 12, 2017 | Zebra ZM400 Thermal Label Printer -...
I always use my brother printer as my default printer but nowaI days I face the problem with my printing especially with colour printing where as my magenta colour can't be printed. I've many time run the...
If an inkjet printer has not been used for some time and several print head deep cleaning has been done and it still does not print properly then the nozzles in the print head are blocked.
Inkjet printers need to be used frequently to prevent nozzles blocking with dried ink.
You need to replace the print head to get the printer functioning again.
But these print heads are expensive to replace, it may be better to buy a better and a later model printer for not much more costs.
Feb 25, 2011 | Computers & Internet
I have godex 1100 barcode printer which is not working. It doesn't print barcode. it responds the print command from the computer and tries to print but halt immidiately blinking status light. It gives...
You did not tell us, whether it is not printing barcode's alone or no text is printing.
You might hear beeps for 2 reasons, Sensor posistion is not correct. or ribbon is not correctly fitted.
Kindly check both these. hope this will solve your problems.
If you have any other queries with barcode printer kindly mail/call us.
Regards Trridev Labelss Mfg Co Web Marketing Division www.trridevlabelss.com email Kirubakaran.rv@gmail.com trridevlabelss@gmail.com
Manufactures of Self adhesive labels and resellers of barcode printers and scanners and ribbons
Sep 14, 2010 | Argox X-2000+ Thermal Label Printer
Argox x-2000+ barcode printing is not clear
Hello !
This model is an thermal printer.
The thermal printhead need to be cleaned with isopropylic alchool with a cotton bud.
All the best !
Nov 05, 2017 | Argox X-2000+ Thermal Label Printer
Ladder orientation barcode printing bad resolution needs correcting
Try slowing down the speed of the printer. Faster speeds degrade the quality of your print. Try printing your serial (ladder) barcodes at 2-4 inches per sec. It should improve the quality of your format.
Apr 13, 2009 | Zebra Z6M Plus Thermal Barcode Label...
How do you speed up he printing speed on a Paxar 9800/9850?
Are you printing a serial or parallel barcode? If you don't know, a serial barcode looks like a ladder as it prints out on the label. A parallel barcode looks like a picket fence. A serial barcode (ladder) prints at 2.5 ips by default. You can't increase the speed. If you're printing a parallel barcode (picket fence) you must hit "enter' once you adjust the speed setting in the printer menu. If you've done that and it still won't increase speed, then the speed is set by the software itself, and overrides any changes you make in the printer menu. The speed adjustment must then be made in the software, not the printer.
Apr 08, 2009 | Paxar Monarch 9850 Thermal Printer
Intelligent mail barcode
Jan 30, 2009 | IBM 6400 Matrix Printer
Improper printing of barcodes
recalibrate the label length in the printer(hold feed and power up). from memory bar-one uses the label settings from windows, so go into printers and faxes under control panel and correct the label size
May 25, 2007 | Zebra TLP 2844-Z Thermal Label Printer
24 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
