Port forwarding How Do perform port forwarding in the primatel P104?
    Scholar:
    New Friend:
  • 149 Answers
In your router's setup menus, click Advanced Setup, then click NAT, then click Virtual Servers.
That's the port-forwarding configuration page for Primatel routers.
Posted on Apr 15, 2014
Belkin N300 - CISCO Clean Access Agent
All configuration can be done with the router GUI.
Firewalls: Server Side Having a server side firewall is the typical configuration on many systems. There is only one method for doing this, whether you use telnet or ssh: map a port to be forwarded to the server in the firewall router. It is not advised that you use telnet from the Internet for security reasons; that is usually why you have a firewall.Decide which method of connectivity will be allowed, and determine what port you will use to forward to this service. If there is only one server involved, you can use port 22 for ssh or 23 for telnet and forward them straight through to the server. But if there are several servers involved and they do not have public IP addresses, you will need to pick different ports on the firewall router and let the router forward those ports to the different internal servers.
Mar 01, 2013 | Belkin Surf N300 Wireless N Router
Ryobi batteries P103 (2) or P104
The physical differences between two models of Ryobi batteries is:
- The P103 (Part Number 130429008) is a 1.5 Amp/Hour (a measure of how long a battery lasts on a charge) battery. If totally discharged it takes about 15-20 minutes to charge back to full. It is lighter than the P104 because it has half the cells inside. Lighter, quicker to recharge, quicker to discharge, shorter lifespan.
- The P104 (Part Number 130429017) is a 3.0 Amp/Hour battery. It takes about 30-35 minutes to charge it to full if fully discharged. Slightly heavier, longer time to discharge & recharge, longer lifespan.
Considerations:
- No difference between batteries in the performance of your tools.
- The number of times you discharge and recharge a battery determines a batteries lifespan. That's why most manuals will tell you to fully discharge a battery before putting it on a charger.
- If you only have one battery you cannot use your tools while it is recharging. On big projects you have to have two batteries.
- The weight difference between batteries is negligable unless you are working with the tool in your hand for extended periods.
Mar 04, 2012 | Ryobi Two 18V Lithium-Ion Batteries +...
What Ryobi batteries p103 or p104 will a battery charger that came with my p100 batteries charge? Or will the charger work with these batteries?
If you have a P100 NiCad battery, the charger for that will not charge the new Lithium Ion P103 or P104 batteries. You need a specialised Ryobi Lithium Ion battery charger like this one
Jan 11, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
How do i change my nat type on linksys wcg200 router device page?
The NAT type on this wcg200 cannot be change. Its either you turn off the nat, Which will disable the routing feature of it.
If you having a hard time connecting to an online game or having problem with a certain application ,l would advice you to just perform port forwarding on this router.
In doing port forwarding you need to get the ports that is needed to open for that certain application to work.
I hope i answer your questions
Cheers,
KJ
Jul 04, 2010 | Linksys WCG200 Router
Netopia routers2247NWG/slow download speed/
Actually the application may be games or any other software which it setted port is not open/accessable through your router and it will work by default ports and the speed or the performance is very slow- Try to configure proper port forwarding according to the application port settings check those ports are open after configuration
Hothawk
Jul 14, 2008 | Computers & Internet
Linksys camera wvc54gc
make wsure that that port 1024 is assigned to the ip address of the camera under port forwarding, you can also try changing the remote port, try 5000 and above, if it still does not work try DMZ.
you can always check if port 1024 is open on your router by performing a port scan through the net, you can get a free port scanner on this site..
www.t1shopper.com
for the process on doing fort forwarding on your 2wire router check this link.
http://portforward.com/routers.htm
Mar 15, 2008 | 2wire 1800HG Router (RG1800HG00)
Netcomm router
google port forwarding, you need to set up your router so it forwards the port of the game that you are playing to your pc's ip address you will see significant performance improvements
Dec 31, 2007 | Computers & Internet
Port forwarding? 2wire 2701hg-T
try the link below it may do it for you if your router is supported on the site http://www.portforward.com/
Sep 04, 2007 | 2wire 2700HG-B Router (2700HGB)
Port Forwarding
there is a way for you to port forward to anything that you would want, the only thing that you would need is the port numbers in order for this to work. Using terms.
1.) In your address bar, type in, "192.168.0.1". And by default, your username should be blank, and your password is, "admin".
2.) Once onto the mainpage, look up at the top of the page, and go into advance.
3.) And then look on the left hand side, and click into a tab that says, "Forwarding".
4.) Fill in you information/chart.
a.) Easiest way to find your ip address is to go to, "Start"(bottom left of your screen), click "Run", and then type in, "ipconfig/all".
b.) Enter in your Start and Exits ports like I said in the beginning.
c.) TPC/USP
d.) And then click "Enable" box, and click, "Apply" at the bottom, and your done!
Jul 27, 2007 | RCA Cable Modem DCM315R (11603540)
Computers & Internet Logo
105 people viewed this question
David Payne
David Payne
