Question about Dryers
Zing ear switch TP-01 ZH
Need wiring diagram
5 Suggested Answers
  • 101 Answers
SOURCE: zing ear switch from a hampton bay ceiling
Did you try Home Depot, Lowes, or any lighting supply store. It's a pretty common item, so they should all stock it
Posted on Apr 07, 2010
FixinFax
  • 3085 Answers
SOURCE: Need Zing Ear switch ZE 238S
http://www.ceilingfanparts.com/images/product.htm
Posted on Jun 27, 2010
taran_2005
  • 10515 Answers
SOURCE: My fan would run only
First, check to see that the fan blades turn freely by hand and coast after being spun. If rotation is in any way stiff, this is a sign of dirty, dry, or gummed bearings, which can slow the motor. Sometimes the bearings can become tight and binding which can also be an issue.
Second, does the fan wobble at all? If for any reason the blade pitch is steeper on one or more blades than the motor is designed for, this will slow the motor. This can often be the cause of warping, or a blade being knocked off balance. This will also cause the fan to wobble or shake. See the section on balancing. You can bend the blades to a shallower pitch if they appear to be too steep, but be extremely careful as blade brackets can break easily.
Most ceiling fans made in recent years use permanent split capacitor motors, as they are efficient and reliable. However with age capacitors can drift in value. If the blades turn freely and are balanced, the cause of a fan running slowly is almost always a bad capacitor. The capacitor is a small black box or silver cannister with two or more wires attached, and is located inside the switch housing, motor housing, or inside a bell on top of the motor. It should be replaced with a capacitor of equal value, they are marked i.e. 6uf, 4uf, etc. Some fans have capacitors with two or more values, they should be replaced with the equivalent of those values by one or more capacitors.
Read :-
http://www.ceiling-fans-n-more.com/ceiling-fan-capacitors.php
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 04, 2010
SOURCE: Where can I find a replacement switch. Zing Ear
I have a Hunter Fan I bought in 2007 with the Zing Ear ZE-268S6 with the . Lowes sells a Zing Ear that works on my 3 speed fan. The chain is yellow so it will show above the light fixture. This is for a 4 wire. The color wires on the switch were black, green, gray and brown. You have the four markings L 1 2 3 so write down where each color wire attaches before you disconnect the old. All speeds work
Posted on Jul 20, 2013
I need a zing ear part ZE-301D+ZE-109M for a HUNTER CEILING FAN WITH LIGHT #28698
Fixya does not sell replacement zing ears. Check with a local appliance parts supplier.
Jul 05, 2016 | Hunter Dryers
How do i wire a 3 speed zing ear ceiling fan switch 208s with purple, yellow and gray wires?
First, is this the correct switch? Do you know the make/model of fan? No black wire? fanman9952@aol.com
Mar 15, 2015 | Dryers
Need a zing ear switch ze-268s6.
Let me know the model # of fan & I'll see if I have one. This Zing Ear # doesn't mean anything.
Sep 02, 2014 | Hunter Ceiling Fan Control Switch
Where can I find a replacement switch. Zing Ear ZE-268S6. Thank you.
Hi Eric...
Click here Amazon com zing ear switch and chose the best one for you. Anyway contact the seller before buying, to see if fits on your model. I hope this helped.
enjoy
Jun 27, 2011 | Hunter Ceiling Fan Light Switch Control
I have a hunter fan and my contractor switched the load and green wire in the new zing ear switch. I just need to switch the 2 wires and I can't get the switch open. can anyone help?
I found out that mostly they are connected with fastons. You can get them at hardware or auto parts stores.
From what I've heard Zing Ear switches are a bear when it comes to taking apart or taking off wires.
Good luck.
I hope this helps. If it does, I would appreciate a vote. Thanks,
Handie Andie
Apr 03, 2011 | Vacuums
Hi. My name is Nivardo, I’m from México and
In the base of the lamp, cut the 2 wires coming in from the wall.
On one wire from the wall, connect it to the same wire going to the lamp (white wire, if you can tell which is which), AND the white wire from the Zing Ear (3 wires connected together).
For the other wire from the wall, connect it to the BLACK wire from the Zing Ear.
For the remaining wire to the lamp, connect it to the RED wire from the Zing Ear.
You also need to fasten the "TOUCH" wire from the zing ear to the frame of the lamp -- the metal part where you would touch the lamp.
That should do it.
Jun 11, 2017 | Hampton Bay 52 In.Carriage House II in...
Zing ear switch from a hampton bay ceiling
Dec 12, 2009 | Hampton Bay 52 In.Carriage House II in...
Dryers Logo
90 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
