Question about Pioneer VSX-60
Pioneer VSX 60 Overheating and shutting down
This unit has shut down twice after 4 hrs. When I went to the unit is was very hot. After cooling it the second time and doing a hard reset I now have no sound available.
  • 979 Answers
SOURCE: pioneer vsx-d307
You have a flashing "mute" on the display?...accordianman
Posted on Nov 26, 2007
SOURCE: pioneer vsx-d511 amp error
I've had the same problem for over a month and have yet to find the time to get to it. However, I there may be a fuse on the circuit board that needs to be replace. That's just my guess.
Hope it's the solution.
Posted on Sep 17, 2008
Gurudristi
  • 98 Answers
SOURCE: Pioneer VSX-D209 receiver shuts off when too loud
Dear Tabasco,
Your receiver is basically going into protect mode.
Just check your speaker cabling again. Make sure that all of them are seated properly, none is touching each other or the body of receiver. Take out all the wire and put them back again if necessary..
Some times even a little tiny frayed wire touching the receiver could trigger the protect mode. Be careful, since protect mode is sometimes not fast enough and it could blown a few trasistors in the power circuit.
Just check your speaker as well....whether they play all right thru another receiver or amplifier. its posiible they might be shorting inside. A little frayed wire could also trigger the protect circuit in your receiver.
I hope this should solve your problem.
If everything else seems all right and still your receiver shut down when you raise the volume then it possible that there are bad connections on the main board that are set in.
This would generally happen if the system is slighly old or have dry solder and when you raise up the volume. This should be a simple repair that will not require parts. If you can solder, you will be able to repair this yourself. If not, then a local service center will change the local labor rate.
Hope you can sort out your problem with the above trouble shooting. Let me know if I can guide you further.
Best of luck! Thanks for using FixYa!
Posted on Apr 21, 2009
  • 5 Answers
SOURCE: Pioneer VSX-D509S keeps shutting off
Aside from any intrinsic problem with your receiver, the usual suspects are;
1) Poor receiver ventilation. 2) Very high levels of bass. 3) Shorts in the speaker wiring. 4) A rubbing loudspeaker voice coil.
Posted on Oct 04, 2009
dunnbiker
  • 8546 Answers
SOURCE: Twice now my Pioneer VSX-819H has shut down. Can
I found this for the VSX918, 818. Perhaps it's similar.
The power does not turn on. • Disconnect the power plug from the outlet, and insert again.
• Make sure there are no loose strands of speaker wire touching the rear panel. This could cause the receiver to shut off automatically.
The receiver suddenly switches off and the power indicator
blinks.
• After about a minute (you won’t be able to switch the unit on during this time), switch the receiver back on. If the message persists, call a Pioneer authorized independent service company.
Resetting the main unit
Use this procedure to reset all the receiver’s settings to the factory default. Use the front panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the ADVANCED SURROUND button, press and hold the
STANDBY/ON button for about three
seconds.
3 When you see RESET? appear in the display, press ‘
ST –’. OK?
shows in the display.
4 Press SOUND RETRIEVER to confirm.
OK
appears in the display to indicate that the receiver has been reset to the factory settings.
Posted on Mar 02, 2010
Pioneer VSX830K FL OFF blinks display shows AMP OVERHEAT.
You need to determine what is overheating. For example if it uses a fan is that working? It it blocked with dust.
Operating the unit with the top cover off will quickly tell you which part is overheating. You can wait till it shuts down, then carefully, with it now unplugged, search for the hot parts. If you find only one overheating on it's own replace it.
Don't burn yourself!
May 18, 2017 | Pioneer Audio Players & Recorders
VSX 60 pioneer receiver shuts down on loud action dvd
Sounds like a bad speaker or speaker that is being over-driven.
Jan 09, 2013 | Pioneer Audio Players & Recorders
Pioneer vsx-518-k power problem
Thyat is called the protection mode, There is a internal problem with it when they do that,
Dec 02, 2012 | Pioneer VSX-518-K Receiver
My pioneer vsx-816 sshows overload then shuts down,it happends when the volume is around 42 i have wharfedale speakers
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Jan 25, 2011 | Pioneer VSX-817-S
Pioneer VSX D710S, I hook everything up and turn the unit on, after about 5-10 seconds it flashes POWER OFF and shuts down.
I wouldn't hold my breath waiting for free detailed circuitry.
A precise make and model might yield more-specific answer.
Jan 24, 2011 | Pioneer VSX-D710S Receiver
I just bought a VSX-820 and it seems to shut down automatically as soon as turn the volume up
Make sure the speaker wires are tight.
http://www.retrevo.com/support/Pioneer-VSX-820-K-Receivers-manual/id/23653ag912/t/2/
Jan 17, 2011 | Pioneer VSX-1016 Receiver
Twice now my Pioneer VSX-819H has shut down. Can not get any power to it. The first time I'm sure the phono pre-amp caused a surge. I no longer have it hooked up. The servicer said nothing was wrong and...
blinks.
seconds.
ST –’. OK?
OK
Mar 02, 2010 | Pioneer VSX-819H-K A/V Receiver
Sep 20, 2009 | Pioneer VSX-D509S Receiver
VSX-D704S
Have the speakers disconnected and turn on unit. If it still shuts down due to thermal protection the amplifier IC pack is damaged. Amplifier IC is tied to one side of the power supply by design. The left channel is probably shorted at the MOSFET on the pack. Nothing you can do but have it serviced. This is a common PIONEER failure.
Apr 08, 2007 | Pioneer VSX-D704S Receiver
Pioneer VSX-60 Logo
48 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
