Question about Viking DDSB423D Side by Side Refrigerator
How to adjust ice maker water overflow on viking
  • 72 Answers
SOURCE: Viking freezer leaking
you have a clogged drain, it is either clogged with ice or some kind of debris, thaw the freezer out and push a length of weed trimmer line down the drain. The drain is accessible by removing the back wall of the inside of the freezer. If there is no clog then the drain may be freezing up, if that is the case, take a piece of 14 gauge romex wire and loop it several times around the heating element at the bottom of the evaporator and push a few inches of it into the drain, this will get hot and transfer heat when it goes into a defrost cycle which is where the water is coming from in the first place
Posted on Jun 17, 2009
tborn6
  • 700 Answers
SOURCE: Viking Ice Maker Leak
have you cleaned the machine lately? the float may be dirty and getting stuck and not shutting down the water as it should.
Posted on Jan 06, 2009
Kgt1962
  • 59 Answers
SOURCE: Water dispenser freezing on viking refrig
One thing that can cause this s the removal of the styrofoam block that surrounds the water reservoir. A lot of people think this is just for shipping but it is necessary to prevent the water freezing.
If it is missing it ill need to be replaced.
Posted on Mar 04, 2009
SOURCE: 48 " viking ice maker tray frozen no ice
Try replacing
the icemaker unit. I used Supco model RIM943 and its working great. Found it online for $55 on line.
My Viking 48" ice maker has given me a little trouble too. The first ice maker assmble was replaced under warranty. It only came with a one year warranty so when it just went out again I thought I would take a look. Just like you I had no ice. It only take two screws to remove the ice making unit and a quick discount plug. I read up on the unit to trouble shoot it. My Ice maker had the ejection forks stuck in the down (in the ice cubes) postion indicating the unit was out of sync and needed to be completly replaced.
On another note:
I also had a proble with the flapper ice cube door on the outside ice dispenser. Ice cubes would get stuck in the door and would not drop into the cups. This was a lot tougher to fix, but I like figuring things out. Turns out I had some ice that got stuck in the flapper and some how it melted and froze back up to lock the flapper. When the motor came on it sheard a shear pin in a coupling just off the drive motor. I made a home made shear pin and put it back together and all work great now. It was a bit of work to take it all apart and to tell that the motor was good and the relay was working right.
Posted on Dec 13, 2009
SOURCE: how do i turn my ice maker off?
To switch off the ice maker simply pull out the ice bucket and remove and you will see a thin bar under the maker that you can simply push up until it clicks, hey presto its off!
If the leak continues look underneath the right hand door at the bottom and you will see where the waterline is attached, either turn the shut off tap (if one was fitted) or unscrew the pipe after disconnecting the mains water.
Posted on Mar 29, 2010
Ice maker leaking water into the ice bin
If it leaks steadily you need a new water valve that feeds the ice maker. If it only overflows when it goes through a cycle, then the timing is off in the ice maker, and will need to be replaced, or adjusted. If it is adjustable, it will have a screw with a spring on it with a +/- symbol by it, behind the front white cover plate. You will just simply tighten or loosen the screw, to make the metal rod around the screw go into the - area. If it is not adjustable, there won't be the adjustment screw and it will need to be replaced. Also, sometimes its not overflowing, and it is just leaking from the mold, which also means you need to replace it.
Jan 27, 2015 | Refrigerators
Seems like my icemaker overflows when filling. I have an ice build up around the plastic box. How can I adjust water
There is not an adjustment. The ice maker dump arm has a cam on it that engages the water fill switch. switch is bad or ice maker motor has a bad spot in it .
Jun 19, 2014 | U-Line Icemaker
I have a 10 year old, at least Kenmore ice maker overflowing into the ice chest. No obvious adjuster.
Can you locate the Kenmore Model Number? It will look like this=> 321.654987 What I think is the dual water control valve is leaking once it turns off. Here below is a ice a ice maker repair clip on You-Tube where he shows a slug of ice filling the ice maker fill tube. In most cases replacing the water control valve will stop the continued water flow to the ice maker once the ice maker fills. I will be here to answer any questions you have Thanks Sea Breeze
Apr 15, 2013 | Refrigerators
Large mass of ice cubes frozen together in tray, most likely from leaky ice maker. Can this be fixed without purchasing a new ice maker.
have you checked it when it's filling to see if it's overflowing or the heater on the ice maker might not be shutting off and melting some of the cubes but you have to check,also it could be the water valve,see if there's an adjustment on the ice maker,look in your book,some of them have an adjustment,try to adjust it so less water is coming into the ice maker but to answer your question you might need a new ice maker or a water valve,the only way to tell is to watch it when it fills to see what's happening,you can pop off the cover to the ice maker and jump it out with a piece of wire,in the bottom right hand corner you'll see two holes close together,t and h stick the jumper wire in those two holes and the ice maker will start up,watch it until it fills,if it overflows try the screw to let less water into it,if that doesn't work then it's gonna be the water valve letting to much water come into the valve
Feb 11, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
My icemaker overflows and does not produce cubes but a solid block of ice over the unit and down into the cube reception tray and over the bottom of the freezer unit. Have removed all the ice and restarted...
Hi
you need to adjust the water level, carefully remove the front cover of the ice maker itself.
On the front of the ice maker, there is a small nylon screw that controls the water intake amount.
If the screw is turned to the Right, it will Decrease the amount of water entering the ice maker.
If the screw is turned to the Left, it will Increase the amount of water entering the ice maker.
The screw should only be turned 1/4 of a turn at a time; therefore, more than one adjustment may be required.
The maximum adjustment is one full turn in either direction. Additional rotation could damage the ice maker..
OR
Dirty icemaker water valve or broken valve can cause icemaker to overflow.
Thanks for contacting fixya.com
Oct 22, 2009 | Hotpoint Refrigerators
Ice Maker Overfills With Water
Ice maker has adjustment on right side of power head. If ice maker is inside on upper left, you can remove white cover from it and the adjusting screw in on right. Turning counter-clockwise will decrease fill by 1/2 to 3/4 of ounce. Sounds like a small amount, but ice make only uses 4 ounces per fill. If this does not fix, try replacing fill valve. If ice maker ice bin is in the freezer door, you have to remove cover to ice maker in the top of freezer. Ice maker is screwed into top of freezer and need to be removed to take off cover to adjuster screw. same procedure for reducing water flow time as above.
Jul 23, 2009 | Whirlpool ED2FHEXN Side by Side...
Ice maker seems to be overflowing with water
check for a ice blockage inside that fill tube that sits in the ice maker.
Jan 10, 2009 | Refrigerators
Ice maker feeding too much water and overflows
I have the GE Profile TFX24PR that exhibited the same symptoms. I had water leaking, making ice in the bottom of the ice bin, as well as under the ice bin. I also discovered ice down the back wall of the freezer.
A technician replaced the ice maker, which did not solve the problem. He put the original back and replaced the valve on the back. That too did not solve the problem. I took matters into my own hands.
I discovered that the ice maker water fill tube that comes in through the back of the freezer wall was leaking. Water would run down the outside of the tube. Some of the water would go into the ice maker, some would go into the ice bin and some of the water would also run down the wall of the fan housing where it passes through a hole in the fan housing. The big problem was the water running down the wall of the fan housing. From there it ran onto the cooling coils, where it would freeze, causing the freezer to go into extended defrost. My freezer and fridge would warm up and I had some food spoil.
If this looks like it may be your problem, you may want to enlist some help for this; it is tedious, time consuming and requires working in the confined spaces of the freezer.
After disassembling the fan housing I was able to access the fill tube. It just pushes in and is prone to wear, especially after fourteen years. I just reversed the ends of the tube and pushed it back in for a snug fit. You may want to consider using a sealer. Everything is working fine now; lots of ice in the bin, and no stray ice or water.
Nov 21, 2008 | GE Profile PSW26P Stainless Steel Side by...
Frigidare FRS23KF6CB manufactured 03/07 ice maker water fill wont shut off
There is a float in the icemaker which controls water height. I'm going to bet the float is jammed or the switch it controls is bad.
Dec 08, 2007 | Frigidaire FRS23KF7AB Side by Side...
Viking DDSB423D Side by Side Refrigerator Logo
124 people viewed this question
Top Viking Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Charles T Nevin
Charles T Nevin
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
