Question about Lifetime Brands Kamenstein Brushed Bronze 4-piece Kitchen Canister Set Bronze
Cannot find Kamenstein brushed bronze canister set
Has this set been discontinued or is it just out of stock
How to calibrate a kamenstein scale model #5105596
Usually, you have to hold down a button to zero out the scale.
I would refer to the user manual for instructions on usage and controls.
Mar 31, 2017 | Health & Beauty
My 541t remington doesnt feed shells well and wont extract empties.
Second time on this one snce my last seems to have disappeared.
You can check the extractor on the bolt face for the second prob, be sure it's good and not snapped off, but your probs are classic fouled chamber stuff. Remove the bolt and remove the action from the stock and then really soak the chamber in some sort of cleaning fluid. Brake cleaner, transmission fluid, Hoppes or Rem Oil, or WD40. Soak the chamber and let it sit a bit. Then use a brass or bronze bore brush and scrub the chamber out well. I sock my cleaning rod into my power drill and use it to spin a brush really good in the chamber. WD40 or oil it and swab it out well and clean and lube as usual. Be sure to clean the feed ramp.
Oct 18, 2016 | Optics
Need motor brushes for kenmore vacuum
Chances are the part has been discontinued. You might want to check for a replacement motor. Sometimes panasonic may have something compatible. Good luck
Aug 30, 2015 | Kenmore Vacuums
Need brush bar and bearings
The brush roll you need has been discontinued. I have one in stock at this time. ($49.99) Please contact me if you want it.
May 12, 2014 | Eureka 8853AVZ Capture Plus Pet Lover...
Hi, my husband bought me your KAMENSTEIN WORLD OF MOTION SERIES ANIMATED HORSE CAROUSEL many years ago. I did not keep the box or manual and now I want to ask can you e-Mail me a download or one I can...
I cannot loacte an actual manual but....The Kamenstein Carousel teapot was part of the MKI versions of teapots Kamenstein released in the mid-2000s. The teapots came in a range of colors, from blue to red, and they had a small carousel on the top. As the water boils the carousel spins around, bringing an element of whimsy to your tea time. The teapots are all metal and can be used on any type of stove top.
Instructions
    • 1 Fill the Kamenstein Carousel teapot with water just below the sprout.
    • 2 Place the Kamenstein Carousel teapot on the stove and set the heat to "Medium."
    • 3 Allow the water to come to a boil and remove the Kamenstein Carousel teapot from the stove.
    • 4 Pour the hot water into a cup over a tea bag.
Read more: How to Use a Kamenstein Carousel Teapot ' eHow.com http://www.ehow.com/how_7718254_use-kamenstein-carousel-teapot.html#ixzz1JAQxUJn2
Thanks
Apr 10, 2011 | Vacuums
Where can I buy parts for a Kalorik bagless vacuum cleaner? It looks like the model pictured above, but the # on the manual is USK VC2.
Kalorik ' Parts and Accessories ' Discontinued ' item VC16107
Here is their site, it looks like the canister vacuum is discontinued.
If this is not adequate information, you can find several contact options on this page.
Gary
Feb 16, 2011 | Kalorik VC16107 Bagless Canister Cyclonic...
Stock availability of TCM 5000 ev
This model was discontinued about 3 years ago with no replacement. The closest model to this is the Marantz PMD201.
Nov 15, 2008 | Sony Pressman TCM-5000EV Desktop Cassette...
Lifetime Brands Kamenstein Brushed Bronze 4-piece Kitchen Canister Set Bronze Logo
69 people viewed this question
Top Lifetime Brands Toys Experts
ray gallant
Are you a Lifetime Brands Toy Expert? Answer questions, earn points and help others
