Question about Bosch Dishwashers
Bosch dishwasher she3ar52uc auto wash lights blinking
5 Suggested Answers
  • 4 Answers
SOURCE: Dishwasher lights blinking
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
Posted on Jul 01, 2008
SOURCE: my bosch dishwasher whistles when on washing cycle
it is your wash pump
Posted on Apr 16, 2009
SOURCE: normal wash light blinking, d/w wont start
Wish I could solve this, as I'm having the same problem too. Normal light blinks not matter which wash button is pressed. Cancel light will light, but still NOTHING happens. Same model as yours.
Posted on Oct 21, 2010
  • 147 Answers
SOURCE: Blinking auto lock Whirlpool
What does it say in fine print right under control lock? "Press & Hold"? Page 16 of the user manual shows it as "air dry" with two lights, twelve and three o'clock positions. It says hold it for four seconds and the light turns off.
Posted on Aug 28, 2012
2 blinking red lights on new bosch dishwasher
Might the manual mention anything about these?
If not, it's time to get a warranty call-out.
Feb 16, 2015 | Bosch SHE3AR56UC Dishwasher
My newly installed dishwasher won't drain, what could be the cause?
If the dishwasher is connected to a spigot on the waste under the sink, check that the end has been cut off the spigot (on the plumbing not the machine hose) or that end stoppers have been removed. Also, check the hose has not been crushed when installed.
Mar 04, 2013 | Bosch SHE3AR52UC Builtin Dishwasher
Aug 20, 2012 | Whirlpool GU1200XTLS Stainless Steel...
Unknown control panel symbols bosch dishwasher super silent
Wash Cycle Options
Delay Start (model dependent):
This option allows you to delay the start time of your dishwasher up
to 19 hours.
Sanitize:
The Sanitize feature is available only in the Heavy, Auto, Normal and Half Load cycles. Press the
"Sanitize Option" button to activate the Sanitation features during these cycles. The technical sanitation
measures may also improve the drying results. The sanitize LED or The "Water Pipe" symbol will light when sanitation
requirements are met.
Note: The dishwasher automatically defaults to Auto Wash when turned off and back on. If you used the sanitize option
in your last cycle, the dishwasher will default to Auto Wash with the Sanitize option selected when you turn it on.
To achieve proper drying, always use a liquid rinse aid, even if your detergent contains a rinse aid or
drying additive.
Note: The dishwasher indicates low rinse aid by turning on the Refill Rinse Aid indicator LED (for units without
a display) or The "Spray Looking" symbol (for units with a display).
If this light is on, you need to refill the rinse aid dispenser
I got the idea that the "squiggly arrow" has something to do with the sanitize feature also. If you post your model number "on the inside right hand side of your dishwasher door" I'll go get your manual and post the link here. Hope this helps so far! :)
Jun 18, 2012 | Bosch 500 Series SHX55R55UC Fully...
Bosch silenceplus 50dBA won't start
After 3 seconds of reset (start), turn the dishwasher off, wait a few secconds, turn it on, and use the arrows to select the washing mode (try Auto, perhaps) and see if this solves your problem.
Apr 12, 2012 | Dishwashers
Classic Bosch Active & end light are alternately blinking rapidly when turned on. It will not start
Thisjust happened to me. The wash program wasnt set. Check thedial and make sure it is set to a wash program.
Feb 13, 2011 | Bosch 24 in. SGS43C12 Classixx...
After the wash cycle dishwasher beeps
Hello, welcome to FixYa. While I don't have access to my PC files at the moment as I am on my iphone, I believe this is the procedure for most B/S/H/ built dishwashers ( that means Bosch, Thermador, Siemens and Gaggenau ). To Enable or Disable the Cycle Completion Signal... 1. Open the door, hold down the ?Quick Wash? button and simultaneously turn the Dishwasher on. The ?Quick Wash? light will blink (program mode). 2. While the light is still blinking, push the ?Quick Wash? button. ? If the machine beeps, then the Cycle Completion Signal has been enabled. ? When you push the button again and it doesn?t beep, it means that the Cycle Completion Signal has been disabled. 3. Turn the Dishwasher off to take it out of program mode. I hope this answer's your question. Thank you for choosing "fixya". Please rate the solution favorably if indeed it was helpful, if not please let me know. Good luck. macmarkus :)
Jul 13, 2010 | Bosch 24 in. SHV4303 Built-in Dishwasher
Our bosch diswasher on auto wash will stop functioning in middle of the cycle start beeping and there is an icon of a faucet on the display. What does this mean?
Hello zeviemail
Welcome
You said, your Bosch dishwasher on auto wash will stop functioning in middle of the cycle start beeping and there is an icon of a faucet on the display.
What is your model number and the year of the dishwasher?
Oct 04, 2008 | Bosch Dishwashers
Dishwashers Logo
415 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
