Question about Dirt Devil Featherlite Bagless Vacuum M085845Vacuum
Cannot remove dirt cup baffle on a dirt devil upright featherlight vacuum
Need to remove to fully empty dirt cup
reddevil6
  • 1673 Answers
SOURCE: Dirt Devil Featherlite Bagless Upright
Check the brush roll, are the bristles worn down? Check the belt also, if it is stretched, then it won't drive the brush roll like it should.
Posted on Jan 15, 2008
Agent Don
  • 310 Answers
SOURCE: Instruction Manual needed for Dirt Devil upright model 088305
http://geeksquad.fixya.com/ThreadView.aspx?prdid=89362&thid=642772
Instruction Manual needed for Dirt Devil upright...
Posted by Innahouse on Jun 03, 2008
Describe your problem I need an instruction manual for a Dirt Devil upright model 088305.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Dirt Devil Model #M088300 Upright Vacuum. The best idea is to contact the Royal Customer Service Dept and give them the model 3 and serial 3 of the unit you are requesting the owner’s manual for, I will give you the website address and phone # listed below:
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://royalvacuums.com/ Customer Service 1-800-321-1134
Hours are: 8:00 AM to 7:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 11, 2008
advacak
  • 125 Answers
SOURCE: dirt devil vacuum spits out dirt
its a design flaw that cant be fixed
Posted on Dec 16, 2008
VacuumRepair
  • 438 Answers
SOURCE: Brush bar can't spin
Hi There,
Actually I just answered a question almost identical to yours! The belt on his model continiously snapped also.
I walked him through how to check the problem, and he was able to get his vacuum fixed. It really sounds to me like your brush roller has gone bad as well.
How to Replace the belt & Roller brush on a Dirt Devil Featherlite:
http://www.fixya.com/support/t4672507-eats_belts_immediately
Also here, another link to the exact roller brush that your model take on our website if you haven't already purchased one.
http://www.govacuum.com/rdd380.html
I hope this helped your your vacuum!
Chris Jones
GoVacuum.com
Here's the link:
http://www.dirtdevil.com/manuals/?id=5a3b999e-1922-401c-a419-69d2e2d13c78
Posted on May 12, 2010
Testimonial: "So grateful for your help!!!"
heatman101
  • 43501 Answers
SOURCE: vacuum won't pick up
Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...
Bissell Bagless Upright Vacuum not working
http://www.fixya.com/support/r4387950-bissell_bagless_upright_vacuum_not
heatman101
Posted on May 28, 2010
Why is my vacuum not pick up
Hi! Your vacuum is most likely not picking up because of a clog, dirty filter or worn belt or a combination of the three. Please try these trouble shooting steps below.
1. Check that the brushes are still spinning. If not replace the belt.
2. Remove the hose from both ends. Use a broom stick to loosen and remove any clogs from the hose.
3. Remove the dirt cup. Remove the red baffle tube by rotating 1/4 turn counter-clockwise. Clear the baffle tube of any hair or debris. Replace the baffle tube.
4. Remove the filter from vacuum base. Hold filter under running water to rinse. Allow 24 hours to air dry before replacing.
Hope this helps get your vacuum back up and running!
Aug 05, 2014 | Dirt Devil Breeze Bagless Cyclonic Upright...
How do i clean canister of dirt devil featherlight bagless caniter vacuum
Hi there! To clean the canister or dirt cup, first remove the dirt cup from the vacuum. Twist off the dirt cup lid. Remove the pleated filter and empty the dirt cup. Tap the filter against the trash can until the dirt stops falling. If the filter is really dirty it may need to be replaced. The filter should be replaced every 6 months. I have included a link where you may go to purchase a replacement filter if needed.
Thanks! Hope this helps!
F1 HEPA Filter
May 18, 2014 | Dirt Devil Featherlite Bagless Vacuum...
When i removed the bottom panel to clean out the roller brush, the front wheels fell off. I can't figure out how to put them back on!
I( think Dirt devil wheels are held on by a little clip, kind of round ish. Check the other wheel and see if it has that kind of set up. Chris
Feb 09, 2011 | Dirt Devil Featherlight Bagless Upright...
Why when I pull out the hose there is no suction?
filter might be blocked up.take the filter out of the dirt cup then try it again.also the intake hose at the bottom might be blocked.is the brush roller turning
Mar 16, 2009 | Dirt Devil Featherlight Bagless Upright...
No suction
Check the main filter cone - if it has a rip in it, then there won't be any suction in it, also clean it gently with a paint brush to get all of the dust out and check the back of the upright after the bin is taken out as sometimes there is dirt clogged at the back. Check the front of the sole plate i.e. where the roller brush is and check the dust channel behind this as it can get clogged. Due to the nature of this vacuum with the hose being located at the front of the floor head dirt can be trapped but most of all its the paper pleated cone filter that needs a good brushing. Hope that helps.
Feb 25, 2009 | Dirt Devil Featherlight Bagless Upright...
Dirt Devil Vision bagless not working
Check the dirt cup filter. remove the dirt cup and check for proper suction. if you have good suction, check your belt
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Jan 24, 2009 | Dirt Devil Featherlight Bagless Upright...
Dirt devil vibe 088915v
Are you talking about the beater bar? If so, you probably have a broken belt
Jan 16, 2009 | Dirt Devil Featherlight Bagless Upright...
Belt replacement
on the bottom you will see 4 screws.take them out and the bottom plate will come off.before you put the new belt on look at the motor shaft.if you see old rubber on it you need to clean it off or your new belt won't last very long
Aug 22, 2008 | Dirt Devil Featherlight Bagless Upright...
Dirt Devil Featherlite Bagless Vacuum M085845Vacuum Logo
42 people viewed this question
Top Dirt Devil Vacuums Experts
Jim Parker
Jim Parker
Tim Venetis
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
