Question about Sensio Bella 13576 Triple Buffet Server
Do you put water at the bottom of the heating unit under the crock pot
Where can I buy a lid for a general electric 2.5 quart crock cooker model sc15
Go to this site http://www.crock-pot.com/CustomerService.aspx?id=rpt and put in your model number (located on the bottom of the unit) and you can order the liner and other parts for your crock pot.
Jan 04, 2015 | Crock Pots & Slow Cookers
Where can I get a new lid for my Corningware programable sow cooker model SC-6
Nov 16, 2014 | Crock Pots & Slow Cookers
Replacement lid for hamilton beach 33182
Go to this site http://www.crock-pot.com/CustomerService.aspx?id=rpt and put in your model number (located on the bottom of the unit) and you can order parts for your crock pot. The cost is $15.00 plus shipping and applicable tax.
Apr 28, 2014 | Hamilton Beach 33182 Slow Cooker
Cracks in slow cookers. what causes that and how can it be fixed?
Cracks caused normally in slow cookers is normally caused from the unit being real hot, and then put under facet cold water. When the unit is very hot, and then is put under cold water before it has cooled down on its on to a warm temperature the dramatic change of hot to cold, cracks it. When its hot, its expanded, and then when it goes that fast to cold, it retracts to fast and causing cracks over a period of time, like stress cracks on air planes, when they go up they expand with cabin pressure, and when they come down to land they retract, over a period of time they get worn and cracks develop , same as a crock pot, except yours is with heat, the planes are with air pressure.You can't really fix the cracks. Well, you could have a shop fix them. but the cost would be way more than the crock pot. The only way you can help this from happening in the future, is after using it,before you wash it out let the crock pot cool down on its own for a while. Thanks Mike
Sep 14, 2011 | Crock Pots & Slow Cookers
I never used a crock pot before,do I add water between the heating unit and removable pot??
No, don't put water around the heating unit... All food, liquids will be added in the pot.
May 18, 2010 | Crock Pots & Slow Cookers
Use of an old slow cooker
NO!
it should say on the metal below the ceramic pot to not get it wet
slow cookers make enough heat to heat the contents of the ceramic pot.
Jan 10, 2010 | CorningWare SC60 Slow Cooker
The inside bottom of my crock pot doesn't heat up, is that normal
Hi. The heating element is located on the in side / sides of your **** pot base in a circular element. That is normal.
Jan 06, 2010 | Rival 3755 5.5-Quart
Crock pot
no !!!!!!!!!!
just put the water in the top
May 23, 2008 | Rival 38601 Smart Pot 6-Quart
Can't find replacement crock.
the lid on our crock pot broke. We will sell you the bottom if you're interested.
This unit does not seem to be cracked.
Apr 05, 2008 | Rival SCVE500 Slow Cooker
Sensio Bella 13576 Triple Buffet Server Logo
Top Sensio Bella Crock Pots & Slow Cookers Experts
tsalagi152
charles
Irene Tulloch
Are you a Sensio Bella Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
