Hotpoint wmf 940
Temperature control button does not change temperature. Permanently on cold wash. Wash quality is poor
  • 1028 Answers
SOURCE: Temperature Control Problem
is washer less than a year old? if so call reapir ..there was an issue with the temp controls on a small number of those machines they use an electronic control in what looks like a mechanical switch..if over a yr old could still be a temp switch but be sure hoses are connected correctly and on a rinse cycle the water does come in hot ..don't worry too much about wash cycles temp is controlled to to prset temps and is based on final water temp in tub after fill not incoming water temp
Posted on Aug 07, 2008
  • 32 Answers
SOURCE: Wash temperature too high
your thermostat is most likely malfunctioning.you need to have it replaced..i hope this helps
Posted on Dec 23, 2008
huuum
  • 750 Answers
SOURCE: Hotpoint BWD129 - Wash temperature too high
Hello
Welcome to Fixya
My name is Huum,
Water temperature switch
The water temperature switch directs power to the valve. If there is no power getting to the valve, check the switch according to the wiring diagram for your machine.
Faulty Water Inlet Valve
The water inlet valve is the device that meters water from the supply lines into your wash tub. On domestic washers, there are two lines, one hot the other cold. These valves are susceptible to mineral build-up and sediment deposits. There are two common failure modes:
Failure Mode One: Valve will not open.
If you can verify that the solenoid on the valve body is receiving the requisite voltage and the valve will not open, then it is faulty. Since the solenoids operate independently, it is likely that one side of the valve will work and the other will not. This can produce strand results such as a very hot wash when warm is selected (due to no cold water). Or the reverse in that the wash water is cold when warm is selected. If mineral or hard water deposits are a problem, you may witness a substantial increase in the time required for the tub to fill. This is caused be a decrease in the flow ware of the valve.
Failure Mode Two: Valve opens but will not close.
This is verified by a valve that allows water to flow into the tub even though no power is being supplied to the solenoid. This one is usually quickly diagnosed when the machine begins to overflow and the power plug for the washer is disconnected from the wall. However, this will not stop the water from flowing into the machine. The water must be shut off at the wall. As with the previous failure mode, the variant of this failure mode is that it may take the valve a while to completely bridge the flow of water after the power has been removed from the solenoid.
How to Diagnose?
There are a couple of ways to diagnose a faulty valve. However, there is a simple test that one can perform that will usually let you know if the water inlet valve is faulty.
Scenario:
When set to cold wash and rinse, the unit will not fill. When set to warm wash and cold rinse the washer will fill with hot water only and will fail to rinse. This is a common scenario where the cold water side of the valve does not appear to be contributing to the fill, but the hot water side does. This symptom could be easily reversed where cold water is being supplied, but never hot water.
So, how can the problem be determined? It is as simple as switching the wire harness plugs on the hot and cold side. In the example above where the cold water is never being supplied, the symptoms would be the opposite when the wiring harnesses were switched. So the machine would produce only produce cold when warm or hot is selected. No water should be present when you select cold. This verifies that the timer, wiring and switches are all in working order. Assuming this tests checks out, you simply need to replace the water inlet valve.
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
  • 2118 Answers
SOURCE: I can't set my Neptune washer temperature to cold
you need to call your parts store or the factory number in your book,give the model and serial number to them and order the console,the touch pad is damaged and they sell you the whole top console on the washer
Posted on Feb 20, 2010
  • 1937 Answers
SOURCE: kenmore 110.82891120 washer is old but recently in
First, see the Sears parts list for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.82891120&pathTaken=partSearch
Next, see the Whirlpool / Kenmore Service Manual for top load, direct drive washers:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It does sound like a Temp control problem. The Service Manual has testing procedures to verify the problem.
Also see the following for how to access the components in the Console.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=3b9a5af78841261f90d2276a3a64320c
Posted on Mar 29, 2010
Hotpoint aquarius washing machine why has h 20 come up on my machine
http://www.hotpointservice.co.uk/help-and-advice/error-codes
F10 - No cold fill. Check that the taps are on or if the drain hoses are kinked. F11 - No hot fill. The ambient temperature is likely to be below freezing possibly due to the pipes being frozen. Also check that the taps are on or if the drain hoses are kinked. F12 - No mixed fill. It is likely that the water is not turned on at the taps. F13 - Check the water supply, inlet valve and hot and cold hose connections. F14 - A fault with the water heating has occurred* F15 - Water is not being pumped out and a flood condition could occur. Check that the drainage hose is raised to the recommended minimum height and that the pipe is not blocked. F16 - Extremely high water level. Disconnect or turn off the water supply and ensure that the water level does not rise any more* F17 - Door not closed properly. Close door firmly at the 3 o'clock position. F20/1 - The thermistor resistance has drifted or the temperature scanning sequence is incorrect. The ambient temperature could be below freezing* F30/31 - A motor drive problem has occurred. Try running the programme again. If the problem persist, book an engineer. F40 - Water below protection level during a heat step* F41 - Water level detect sequence incorrect* F50/51 - Customer language and wash programme have not been saved. The system will run with default conditions (1000rpm max and English language)* - See more at: http://www.hotpointservice.co.uk/help-and-advice/error-codes/#sthash.w5Uocmoi.dpuf
Sep 08, 2014 | Washing Machines
I have just taken delivery of a Hotpoint Whirlpool washing machine today.Please explain how on a 30 min cycle the water can be warm when it is cold fill only
Sorry but I'm not certain that I understand your question ;-0(
Maybe if I explain- 'cold fill only' means exactly that; the washer has only one hose and is connected to one cold supply to fill and then the washer will heat the water up to the selected temperature of the wash. The description does not mean that it washes in cold water only.
In the case of a hot and cold fill, the washer would open the hot inlet until the correct temperature is reached and then would continue filling to the right level with a mix of hot and cold water whilst maintaining the temperature. Cold is then used for rinses in all cases as far as I am aware, including yours ;-0)
I sincerely hope that I have not totally misunderstood your question. If I have I apologize.
If this has answered you question please consider a 4 thumbs up on our rating.
Thanks and good luck.
John C
Apr 13, 2011 | Hotpoint Washing Machines
I just rehooked up my washer and I only have cold water going to it. It will go for a while and then reads F-20. What do I do?
he F20 error is a no water detected entering machine error and yes it is related to the hot water not being hooked up.
Newer washers sense and control the incoming water temperature. If you select cold wash and cold rinse you may think that it will not ask for hot water so you don't need it hooked up but you can't do that on this washer.
Even on a cold wash the temperature sensor will read the temperature of the incoming water. If your cold water is 60 degrees then the control will sense this and it may cycle the hot water on to bring the temperature up to 70 degrees.
This temperature monitoring is something all the newer washers do. Both water valves must be hooked up to water.
Jan 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Error code F20
The F20 error is a no water detected entering machine error and yes it is related to the hot water not being hooked up.
Jan 11, 2011 | Whirlpool WFW9400S
Washer only has cold water. Hot water is good to machine but only cold water enters machine on warm cycle, no water ar all on hot cycle.
Hello there
The Water System temperature sensor is normally what is wrong with these units with this condition that you are experiencing
The water system consists of the hot and cold water inlet valves, a water temperature sensor, a water
flowmeter and control and the dispenser distribution system along with a traditional pressure switch.
Water Inlet Valves -
The hot and cold water inlet valves are located at the back of the washer. These valves receive a control
signal from the Central Control Unit to manage the temperature of incoming water. The temperatures
are determined by the specific wash cycle selected and a temperature sensor located in the wash tub.
To improve cleaning of heavily soiled clothing and to provide a sanitizing feature, the water temperature
can be increased through the use of a heating element located in the bottom of the tub
Dec 25, 2009 | Maytag LAT3600A Top Load Washer
When I wash dark clothes, I get lint on them or white spots
The lint is from some other garment in the same wash.
Do the white spots wipe off or are they "bleach stains"?
Assuming they wipe off, then your detergent is not dissolving all the way. Make sure the water is hot enough. Even cold water needs to be a minimum temperature and during the cold months the water can get too cold. Try warm or mix hot and cold by changing back-and-forth on the control for the wash temperature. Also, try putting the detergent in first or buying a higher grade of detergent (i.e. Tide). Best of luck.
If this information was useful, please select YES to the first two rating questions. Good Luck and thank you!
Oct 22, 2009 | Washing Machines
My Hotpoint WMA58 washing machine is not heating the water so the cloths are only getting washed in cold water. Will this be the heater element that has gone? If so how do you change it.
We had this problem & called our repair man in. We had accidentally knocked the 'Variable Temperature' dial down too low. It should ALWAYS be set to max (95). The programmer will still sort out the correct temperatures for the different programmes, such as cold wash, but setting that to whatever temperature means that that is the max it will ever reach, Since then, we have not had that problem again.
Apr 02, 2009 | Hotpoint WMA58 Front Load Washer
W'm63 won't hot wash
Make sure you have not selected economy wash,as this bypasses the heater, and washes at the temperature the water has come into the washer at,
If it still is not getting hot, then the heater element is more than likely to be the culprit., these 2 things are about the only ones that would enable the washer to wash in cold water.
Plz rate my solution.
Thanks.
Jan 07, 2009 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
