Question about Ovens
Demo mode aeg owen BP7314621
I can not get out my owen AEG BP7314621 from demo mode. What to do?
  • jonas
    jonas Dec 21, 2016
    Deactivate the "Demo" function.
    1.Deactivate the appliance.
    2.Touch and hold power button an acoustic signal sounds(for minimum 5 seconds).
    3.Touch and hold clock and minus (V) buttons at the same time for 2 seconds until an acoustic signal sounds.
SOURCE: My AEG oven is switching off by it self after about ten minutes.
think it shutting of as its getting to hot
Posted on Jun 19, 2008
  • 139 Answers
SOURCE: AEG double oven- fan assisted not heating up
you oven element has failed.
it is located at the back of most electric ovens sometimes at the top,,
the insulation of the element has failed and when you come to remove it you will see visually see the damage... its easy to replace as there are only wires attached to it and only a few screws to undue to get to it..
hope this helps cheers
the washdoctor
Posted on Aug 24, 2008
barkencoa
  • 3463 Answers
SOURCE: aeg single oven
You need to reset the timer to manual from auto , that is why your oven won't come on.
Refer to your user manual on how to do this.I can't tell you how as the sequence differs from model to model.
Plz leave feed back for this solution.
Thanks.
Posted on Dec 13, 2008
Coggy1
  • 6 Answers
SOURCE: THE LIGHT ON MY AEG COMPETENCE OVEN AND GRILL IS N...
It's either the thermostat / switch or the timer unit. Make sure the timer was not set to have turned off the grill first
http://www.espares.co.uk/part/cookers-and-hobs/thermostats/aeg/p/1604/143/0/0/1061574/top-oven-thermostat.html
Posted on Jun 25, 2010
  • 174 Answers
SOURCE: aeg oven d4100 cutting out
There is a cooling fan in the cabinet of the oven which is not working either the fan is faulty or the controling cut in stat is, The fan should run when the grill is selected if does not it is more likely to be the fan/motor at fault.
Posted on Jul 13, 2010
Aeg manual
In order to help you turn on the oven you will need the oven manual. But as you have not provided the model number it is hard to advise which manual applies. You may want to visit this website and type the model number after you check it from the plate on the oven door. (side). AEG Service Support User Manuals
OR
if in Australia
Aug 21, 2014 | AEG Ovens
Aeg oven how do you change the bulb?
unscrew the glass. unscrew the bulb
Jan 20, 2013 | AEG Ovens
My oven is locked out and I cannot get it to work
Is the digital clock/timer set correctly? Sometimes after a powercut I have to reset this to get the oven controls back into manual mode. Follow this link to the user guide for your oven and have a read. Re set the timer and should be ok....hopefully! http://safemanuals.com/user-guide-instructions-owner-manual/AEG-ELECTROLUX/B1180-4-M%20UK%20R05-_E
May 08, 2010 | AEG B1180-4 Electric Single Oven
MY AEG OVEN IS IN SAFE MODE HOW DO I GET OUT OF THIS MODE
Just found out that the 'safe' mode on my oven is for child protection. I had to press 'p' en 'minus' (-) at the same time for a few seconds. Problem was solved immediately. My oven is an AEG-Electrolux Micromat-Combi.
Apr 23, 2010 | AEG B8139-4-M Electric Single Oven
The top oven of our AEG D5701-4 is slow to heat.
Hi it could be the element on the grill it maybe burning out, what slows the grill to get hot quicker. best to turn of the mains or by the main switch. and get a toorch to check around the element or use a continental reader check if it is receving 240volts
Mar 09, 2010 | AEG D5701-4 Electric Double Oven
I need a rubber seal for an AEG B6139-M Competence door oven
If you are in the u/k, then look in telepohone directory for Service Force, they are the service agents for AEG.
Please rate my solution.
Thanks.
Jul 16, 2009 | AEG Ovens
Oven cuts out after ten minutes and comes back after cooling down.
We have the same problem with our oven, AEG B2190-1.It started on on Christmas day[worst day of year]gets up to temperature after 10-15 minutes cuts out everything switches off until the oven has cooled down, The oven is only 18 months old. We have been told that it is a thermostat problem.
Dec 10, 2006 | AEG B2100-4 Electric Single Oven
Ovens Logo
75 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
