FixYa.com
Tags:
D-Link Securicam Network DCS-950G Wireless Internet Camera
Wireless security
posted by bevp on Oct 26, 2007
I have a dlink DI524 router. How do i set up security on it? I have lost the installation CD. Thank You
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Feb 12, 2008
Not Rated (0)
Junoon007
Rank:Wiz Wiz
Rating: 83%, 56 votes
Hello sir,
GETTING STARTED How to Physically Connect the D-Link
1. Plug an Ethernet cable into the DSL modem. Plug the other end of the cable into the "WAN" port on the D-Link.
2. Using an Ethernet cable, plug any wired computers into any of the 4 Ethernet ports on the D-Link.
How to Access the D-Link Configuration Screen
The D-Link is configured using a Web browser. After you have connected your computer to the D-Link router, follow these steps:
1. Launch your Web browser. Enter "http://192.168.0.1" into the address bar and press the "Enter" or "Return" key.
2. A logon pop-up screen will appear. Type "admin" for the username and leave the password field blank.
3. Click "OK". A D-Link configuration screen will appear. All changes to the D-Link configuration are made here.
GENERAL SECURITY MEASURES
Change the Admin password
Leaving the password blank is not a good idea. It should be changed to something more secure. To change the password, go to the D-Link configuration screen and:
1. Click the "Tools" tab.
2. Click the "Admin" button.
3. Under the "Administrator" heading, enter the new password, and a second time to confirm.
4. Click "Apply".
5. The next time you access the D-Link configuration screen, you will need to enter the new Admin password.
Disable the Wireless LAN
If wireless access is not necessary, you should disable the wireless part of the D-Link. This will prevent anyone from accessing the network wirelessly. (If you are using the wireless features, please skip down to "Wireless Security Measures".) From the D-Link configuration screen:
1. Click the "Home" tab.
2. Click the "Wireless" button.
3. Click the "Disabled" button next to "Wireless Radio".
4. Click "Apply".
5. You are done securing your wired network. No further action is required.
WIRELESS SECURITY MEASURES
Enable WEP
Enabling WEP* (Wired Equivalent Privacy) will require anyone wishing to access the Internet through your wireless network to enter a password. After the correct password is entered, a connection is established, and all data sent from the D-Link to the computer and back is encrypted. From the D-Link configuration screen:
3. Click the "Open System" button next to "Authentication".
4. Set the "WEP Encryption" to "128 bit".
5. Set the "Key Type" to "ASCII".
6. Type a 13 digit password into "Key 1".
7. Click "Apply".
8. When you connect to your wireless network from a computer, you will need to enter the 13 digit password.
*Note: If your computer's operating system supports it, enabling WPA-PSK is more secure than WEP. The steps above can be modified to set up WPA-PSK.
Change the SSID
By default, the D-Link is set to advertise the existence of your wireless network to computers. It does this by broadcasting an SSID (Service Set Identifier), also called a "network name" because it identifies your wireless network. Changing the SSID makes it easier for you to distinguish your network from surrounding networks. From the D-Link configuration screen:
3. Change the "SSID" from "default" to an SSID of your choice.
4. Click "Apply".
Please don't forget to comment this
Good luck
Cheers!!!!!!!!!!
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Security Systems and Surveillance problems?
sears craftsman router
Just bought a sears craftsman... Answer This...
for got my pass word
D1 dedicated micros sprite 2 Answer This...
D-Link Securicam Network DCS-950G Wireless...
Dlink DCS950G
HOw do you set up the camera to... Answer This...
Repair Service
Find Security Sys. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
