Diettes & tics - Computers & Internet
Hi the problem with my marantz sr770 amp is when I rise the volume the sound cut off & it make a sound like (tic-tic) inside,so pls help me!!!
It sounds like a shorted speaker or to many on one channel. It could also be a failed output device. I think the tic-tic is the overload safety cycling.
Aug 06, 2016 | Marantz Audio Players & Recorders
Tic tic tic sound when switced on no sound no video
:That sound usually means the power supply cannot start--due to an overload or overvoltage problem. Likely a few bad capacitors in feedback area or some short in horiz. area, possibly convergence chips if a tube set.
Mar 22, 2014 | Televison & Video
My 2002 yamaha ttr 125 makes a tic tic tic soud when running could it be the valve rocker arms havw to much play in the and are wobleing around
The rocker arms should be adjusted to specific valve clearances to ensure correct running...tic tic means too loose
Mar 04, 2013 | Yamaha Motorcycles
Car will not crank up. When you turn the key in the ignition you hear tic,tic,tic,tic, tic...the lights come on, the doors lock and the radio comes on.
If the battery is old, it may no longer have the cranking amp it needs to turn the starter. If you have a multi-meter. Check the load on the battery when you get someone to start the engine, if the meter reads that it drops below 10.5 volts. You need a new battery, if the readings are good, then you'll need a new starter.
Good luck and keep us posted, a set of good jumper cables and another car may help get the engine started for now by boosting the battery.
Sep 05, 2011 | 2000 Cadillac DeVille
Hi im having problem to start my 2005 escape,when im having problem and i turn the key the only thing it does is a tic tic tic tic and when i boost it, it will start no problem and could be having no...
Well, it could be the alternator or the starter, but I would definitely try to check the connections at the battery to make sure that when they are removed they look shiny and clean at the contact points.
If the battery is charged up, it should have enough power to turn any starter on the market that is in good condition.
To determine what is bad, I would take it to a battery retailer like Sears or Walmart and have them actually test the battery/starter/charging system with their computerized device.
That way, you can get to the bottom of things within minutes.
A good starter should draw 75 to 110 amps and turn the starter vigorously.
If the starter draws only 1 or 2 amps and doesn't turn, the solenoid is bad, but a new starter is indicated.
If the battery is charged up, then it's not the alternator. However, remember this, that batteries only last 3 years on the average as I learned at Sears Roebuck & Co. as a battery replacement technician. So, if your battery is older than that, then it should be replaced for dependability.
Good luck on this repair.
Oct 17, 2010 | 2005 Ford Escape
1995 cutlass ciera takes forever to crank,the
I HOPE THESE TIPS CAN HELP YOU MOSTLY WHEN A STARTER TICS IS A LOW BATERY VOLTAGE BUT IN SOME OTHER CASES IS THE STARTER THE STARTER CAN BE CHEKED REMOVE AN CAN BE SERVICED BY A GOOD MECHANIC BUT IF THE BATERY VOLTAGE IS OK AND THE STARTER IS IN GOOD CONDITION THE PROBLABLE CAUSE MAY BE THE START NEUTRAL SWICTH THAT IS LOCATED IN THE TRANMISIION LINK AND MAY BE THE CAUSE OF POOR TRAS PERFORMANCE TRY CHANGING OR CLEANING THE BATERY TERMINALS WHITH A LEMON AND SOME WATER
Sep 26, 2009 | 1995 Oldsmobile Cutlass Ciera
Tic tic tic sound
Check for other problems. You might need to buy another FET as well. But this time don't put the FET back in until you make sure nothing can blow it.
May 15, 2009 | LG L1915S 19" LCD Monitor
Tic tic problems
check filtering capacitor of lot+B & replace it
May 14, 2009 | LG Studioworks 700S 17" CRT Monitor
CAR WONT START ON FORD FALCON AU (AUTO)
Check the voltage on your battery. When the battery is low, you will still have lights and what not but not enough juice to start the car. Check the condition of your battery cables especially your ground. If everything check out fine, your problem may be a bad starter or the solenoid. If you replace the starter, replace the solenoid with it. Be sure to check the cable from the starter solenoid to the starter.
Sep 25, 2008 | 1994 Ford Taurus
Computers & Internet Logo
David Payne
David Payne
