Question about Building Materials
Stanley lightmaker sl700
My door opener has been working good since 98 until today.i open door ok but went to close it went about a foot and stopped and went back up.i checked for obstruction there is none.i disconnected door and worked button it moves a foot and stops up or down. will not run its full travel either way.
  • 375 Answers
SOURCE: SEARS/CRAFTSMAN 53628SRT Not Closing properly
sounds like the safety door sensors are at fault,also did you reprogram the remotes by pressing the smart button on the logic board,when the safety sensors are bad the door will reverse to open state.you can pully the rip cord to manualy close the door untill you solve the problem.
Posted on Oct 24, 2007
ctf1800
  • 4402 Answers
SOURCE: Garage Door Opener Intermittingly Reversing
try adjusted the sensor controls on the sode of the unit other wise replace the logic board
http://www.chamberlain-garage-door-openers.com/circuitboardcompatibilitychart.htm
Posted on Jan 10, 2008
  • 6 Answers
SOURCE: Chamberlain Liftmaster Pro. Garage door Problems closing
The sensor eye - or more likely, the other end, the sensor light - probably got knocked out of alignment. The eye should have an LED on it - possibly one that glows green when it's ready to close or red when it's obstructed or out of alignment. Try adjusting the light until the LED on the receiver glows green.
Posted on Dec 07, 2008
  • 244 Answers
SOURCE: GARAGE DOOR OPENS BUT WILL NOT CLOSE AUTOMATICALLY
is bulb on motor flashing 10 times. then you have electric eye problem. otherwise, sounds like you need to increase down force a hair. adjustement is on logic board, right knob.
Posted on Jan 15, 2009
rulds2008
  • 3866 Answers
SOURCE: Problem with Sears Garage Door Opener
The motors is cought on something check the motor if it moves inches it will move a yard the question is the motor is it getting power? if so is it stuck on its own drive chain? Check these things you be glad you did.
Posted on May 25, 2009
I NEED THE MANUAL FOR MY STANLEY 8500.51 GARAGE DOOR IT WON'T CLOSE
Try searching around here to find similar or hopefully exact opener. Stanley no longer is in the garage door business, and the company that bought them out went bankrupt.
Good Luck
http://www.teknuw.com/garage-door-opener-installation-manual/stanley/
Feb 23, 2015 | Building Materials
My stanley mod6500 1/2 hp lightmaker sometimes opens and when open to set distanve it kicks out to "reset mode" ( have to switch manually from operate to vacation then back to operate ) to reset and then...
You could have a problem with the door which is causing the opener to kick into a safety mode. Release the door from the opener, run it by hand several times. If you feel it bind, figure out where it's binding and resolve that issue. Then reset your opener again and it should be fixed. If it is not binding, then most likely you have a board problem and will either need to replace the board or replace the opener. Stanley's are known for these type of board issues. I would stick to a liftmaster if you replace it.
Feb 20, 2015 | Building Materials
My overhead door reopens immediatly after closing. The condition started after the door had been blocked at the bottom and continues after blockage has been removed
Your door jumped out of synch What you need to do is turn the open close knob on your closer toward the open mode until it stops opening when you close it.
Aug 14, 2011 | Stanley Garden
My Stanley 9600 opener will only work with the remote. Pressing the button in the garage, or jumping the terminals right at the two wires on the opener does nothing. This happened after an electrical...
You have shorted out your logic board. This could of been prevented with a surge protector 900 joules or higher. Whether you repair or replace get one. Stanley went out of business but you may still be able to find replacement parts online. Thanks BB
Sep 04, 2010 | liftmaster Chamberlain Garage Door Opener...
Sharp Insight Pro microwave drawer KB6024MS not working
The drawer often stops working when it is abruptly stopped while opening and forced closed or vice-versa. To fix, simply do the following:
1) Push the draw all the way closed
2) Push the "Setup" button repeatedly until the "Open/Close ...?" appears.
3) Hold the Start Button until the time reappears in the display.
4) Repeat steps 2 & 3 three more times
5) Unplug the Microwave for 30 minutes.
The drawer is now reset. The drawer will now open electronically (automatically) either by pushing the open button on the panel or by pulling the drawer handle slightly.
Feb 05, 2010 | Microwave Ovens
Programming my 98 blazers Garage door button on dash to a stanley
Here is some programming info for the Stanley.
http://www.aaaremotes.com/standualcodl.html
The programming information for your Blazer should be in the owners manual.
Aug 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
1997 BMW Convertible driver/passenger windows won't go down
I had a similar problem with a '95 Olds. Turned out that the wires between the door frame and the driver's side door had broken from the constant flexing of the door opening and closing.
Jun 11, 2009 | 1997 BMW 328
STANLEY GARAGE DOOR OPENER mODEL#9105 OPENS WHEN NOTHING IS UNDER
Stanley has been out of the garage door opener business for over 15 years. I reccommend replacing these openers when they start acting up because it is so difficult to get any parts. There is a reason that they went out of business.
Feb 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door won't open or close
Check the connection on your limit assy. Many times people forget to reconnect this.
Jan 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
