Question about Panasonic UF770 Laser Printer
Disable LAN adapter
How do you go about disabling the LAN adapter?  We keep getting an error code 710, that says we need to check the LAN adapter, but we'd rather disable it.
    Scholar:
  • 104 Answers
Hi, If you are using XP you can disable the network adapter by going to "Control Panel" then "System" click on the "Hardware" tab and then on "Device Driver". In the list find your "Network Adapters" and open it to see your actual card. Right click on your card and select "Properties". On the panel that displays, right at the bottom near the "OK" button there is a drop down "Device Usage" text box, at the moment it would be reading, "Use this Device (Enable)". Click on the Drop down arrow and and select the "Do Not Use this Device (Disable)" option and then click "OK"
If your PC is a desktop type with a network card in one of your PCI slots, or similar, you could also actually remove the adapter card simply by removing the outer case covers and then unscrewing the nut holding the card in and carefully pulling it out quite firmly in a straight motion. You may want to get another small metal cover strip to screw in where the card came from.
Before opening your PC though be sure you are not voiding any warranties that you may have got when you bought it.
Posted on Oct 28, 2007
Disable wireless lan
Hi Bounthavee S,
I understand that you want to disable wireless LAN
In router :
Open Internet Explorer
Go to 192.168.1.1
This is home page of router
Type the following user name and password when prompted
User name admin
Password admin
Click on LAN Settings on the leftside menu
Right side, you may find option to disable the Wireless LAN
Click on Save settings at bottom
Router will reboot and take 3 to 5 minutes
Check if the Wireless LAN is disabled.
In one computer :
We need to disable the Wireless Adapter
Goto Start >> type devmgmt.msc in the search box and press enter
This will take to you Device manager
Expand the Network Adapter
Right click on 802.11 (wireless adapter) and select disable.
This will disable the Wireless LAN only in this computer
Oct 03, 2013 | Trend Micro Computers & Internet
Im trying to connect my wii to the internet .I have the lan adapter connected to my modem. I am not getting a connection and error code 52020 is on my screen. what am i doing wrong?
You probably have a firewall on your PC (or mac), or router preventing you from connecting to the internet, either plug the cable to the router, disable the firewall (if using a Netgear router, disable the "SPI firewall" under the "WAN setup" of your router), your Internet Service Provider or ISP might be preventing systems like the wii to connect, check with the ISP to see if they are or not.
May 07, 2011 | Nintendo Video Game Consoles & Games
Onboard lan not working even after update of driver gives windows error
Hi Good day!! What message of windows error? Check your network adapter in the device manager, if it is install if not pls try the following.
1. On the desktop right click "My computer and then properties"
2. go to Hardware tab and then click device manager check the network adapter.
3. Disable it and then re enable it. hope your on board lan will work now if still not re-install your lan driver through your motherboard cd..
pls reply o assist you more..
REGARDS:
JR
Oct 07, 2010 | Biostar TA785G3HD AM3 AMD 785G HDMI Micro...
Satellite R25-0520 Won't POST. Message: For Realtek RTL139(x)/8130/810x Fast Ethernet Controller v2.13 (0202326) PXE-E61 Media Test Failure - Check cable PXE-M0F Exiting PXE ROM Is something "loose" inside...
This message is shown once the computer is booted; more than likely these Network Adapters are not being utilize, because the network connection is using "Wireless"service; the "Ethernet Controller is part of the (Wired-LAN) Family." The Drivers maybe (Disabled), or the ("drivers") need to be "Updated. "Do the following; go to Control Panel, open Device Manager, click to open "Network Adapters", check to see if adapter are in ("error, disabled, or working properly etc"). "Update Drivers", and restart the computer." "I hope this help FiX it!"
Jan 23, 2010 | Toshiba Computers & Internet
Wireless connection 6715b Compaq
Go into the setup/BIOS and disable the wan/lan switching feature.
Oct 30, 2009 | HP 6715B Wireless Adapter
PROBLEM WITH THE lan card
Windows XP:
Click Start
Right click on My Computer
When a window pops up click on properties
Click on the Hardware tab
Click Device Manager
Click the [+] next to Network Adapters
Find your LAN card and right click on it.
Click Disable
Windows may warn you that disabling the device may make it stop functioning.
Continue disabling the device.
Wait 30 seconds or so.
Right click on your wireless again and click Enable.
Exit the device manager.
Reconnect to your router.
You should now be able to connect to the internet.
Windows Vista:
Click Start Logo
Right Click Computer
Windows will ask you about opening Device Manager
Click Continue
Find your LAN and right click on it.
Click Disable
Oct 14, 2009 | Acer Aspire 5500 5570-2609 Laptop
Wireless lan disabled
Go into the device manager and check it's status and for any error codes, you can also update the driver from there.
Aug 22, 2009 | Acer Aspire 5050-3242 Notebook
Hello sir, my system has been conducted a problem. lan card is disable so . i donot know how to enable lan card please give me a solution. thanking you
if the lan card is disabled then you have to reseat the lan card if that is a external lan card connected & not the integrated one..also check for the network adapters if they are installed under device manager or not...in case not you also have to install network adapters...
Apr 29, 2009 | Computers & Internet
Error 313
Network connection showed 3 LAN or High-Speed Internet connections. One said it was disabled, another one had a big red X over it, and the last one said connected. The big red X, though unplugged, was apparently still active. The fix was as simple as disabling it.
Apr 09, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Wifi connection
hello
1. what is the model number of your adapter?
2. what is the operating system of your computer?
3. did you install the wireless adapter on your pc or is it a built in wireless adapter?
-- if you install another wireless adapter on your pc, possible that its the one causing the conflict between the two utility. I suggest to disable the other adapter before installing the other wireless adapter
-- if the wireless adapter is a built in wireless adapter and you are using a windows xp computer, chances are that the built in utility and the xp wzc are the one causing the problem. you have to disable one of this utility to make your connection working
-- the utility is sometimes located at your system. if you wish to use the utility you have to disable the wzx or the other way around.
Apr 30, 2008 | WiFlyer - Portable, shareable WiFi base...
Panasonic UF770 Laser Printer Logo
385 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
