Question about Vivitar Electronic Flash 2000 Automatic
My vivitar elect. flash does operate even sfter replacing batteries not even test button
    Novelist:
  • 193 Answers
This is very sad. I can only suggest to re-examine the battery orientation and check the contacts to see if they are bent or broken.
Posted on Jan 18, 2015
2 Suggested Answers
lightingman
  • 22 Answers
SOURCE: Vivitar 285HV Stop Working
There is nothing wrong with your flash unit. The regular AA batters are 1.5 v volts each- if 4 batteries are used that is a total of 6 volts for proper operation. The rechargeable batteries are 1.2 volts each and 4 will get you 4.8 volts- thats 1.2 volts short and that is probably the root of our problem .
Try recharging you rechargeable batteries and put the im one more time- if the same problem happens you will have to stick with standard AA batteries. There external 6 volt packs that will work with your flash unit0 the are a bit of an expense at first but you will save on replacement batteries in the long run,.
Ed
Posted on Nov 29, 2008
I got this flash a couple of days ago and took a handful of pictures using it. It suddenly stopped firing a full flash on that same day. It only fires a weak, barely noticeable blip that does nothing for...
If you replaced batteries with known good ones then the only thing that could have gone bad is the capacitor that loads up and fires the flash. Carefully discharge whatever is left in it , remove and replace. Should do the trick.
Aug 19, 2017 | Vivitar DF283 TTL Flash for Canon
Vivitar DF-283-CAN flash suddenly won't go off. I hear it power up and the ready and ettl lights go on but the ok light doesn't light up and the test button wont work either.I tried replacing the batteries...
This is more than likely a Manufacturing problem. A lot of Vivitar cameras have this problem as well as many others that are usually not the consumers fault. Just a glitch in the technology. I alone have gone through four Vivitar cameras in the last six months. The best thing to do is contact Vivitar directly. This is there website: www.vivitar.com It is best to see if you can find the number for technical support. To see if they can give you a refund or replace it for you. I hope this helps. -Richard
Jan 01, 2010 | Vivitar DF-200 Flash
Instruction on zoom operation and also operation of flash on came
u have 3 problems here zoom,the flash and language ,ok to change the language hit menu .button then first word that shall be setup menu then word on the line number 3 and use right and left arrows to change ,the flash .turn the camera lens wheel on the pyramid sign u see on the front of the cam and then use the push button right side with zigzag sign to switch the flash mode ,push the button then up and down to zoom in and out
Mar 21, 2009 | Vivitar ViviCam 3750 Digital Camera
Battery holder for Vivitar 283 is broken. Can I get a replacement
I think there are some listed on Ebay-check it out.
Dec 27, 2008 | Vivitar 283 Flash
Ed
Nov 27, 2008 | Vivitar 285HV Flash
No 'green' light on bacl of my 'old' Vivitar 285
Then I'd say it's a reasonably sure thing that the green light is just burned out, The lights are supposed to be off at first, then red when there's a partial charge, then green when there's a full charge, then flashing between red and green when the "battery saver" kicks in. If you're seeing off, then red, then off, then flashing red, then that means everything in the charging circuit is working perfectly, there's just no green light.
Nov 30, 2007 | Vivitar 285HV Flash
Flash
i press the flash button its next to the mode button on the back, its the button that points left that changes the mode of the flash, dont press it to much tho battery dies quicker. Mel
Nov 15, 2007 | Vivitar Cameras
Foot replacement instructions on Vivitar 285
Black to ground
Red or other color to center
Alexander
atdlee@netzero.com
Sep 05, 2007 | Vivitar 285HV Flash
Vivitar 283 charges but fails to flash
I had the same problem with my early Vivitar 283 flash.  I discovered that the thyristor on the trigger board tested as an open circuit.
Trying to find a replacement for a 30 year old thyristor semi-conductor proved to be fruitless.
My solution was to purchase a broken, late model Japanese 283 flash off of ebay and transfer the trigger board to my early Japanese model. The late model thyristors could handle more heat.
Problem solved.
Mar 15, 2007 | Vivitar 283 Flash
Vivitar Electronic Flash 2000 Automatic Logo
96 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
