Question about Microwave Ovens
Have a daewoo over stove microwave need to find mounting brackets model MT1510B production date Sept 2008
2 Suggested Answers
  • 5 Answers
SOURCE: How do I remove Frigidaire FMV156DCC under cabinet microwave?
Underneath the microwave, on the right & left hand corner sides at the back, there are levers that you pull down & it releases the mounting bracket.
Posted on Sep 12, 2009
What model would be equal to a sharp microwave model R1490
Chances are only an identical model will fit the brackets. Any new unit will come with new brackets. Just swap the brackets out and install the new unit
Oct 16, 2016 | Sharp Microwave Ovens
I just bought at Lowes a marked down Samsung over the stove microwave but it didn't have a manual or installation instructions. The model # is: SMH 1926S. Can you help me? Especially with installation
Did you get the wall mount bracket? If not. it will never mount up. Go to the Samsung website. You should be able to get operating and mounting instructions there.
Aug 22, 2014 | Microwave Ovens
Seeking to purchase Goldstar MV-1304W/B - need microwaave 24" or less with vent for over stove. Is it still available or is there another model that will work?
There may be a General Electric model that is essentially the same with a different label. Other brands will work, although you will probably have to change the mounting bracket. They are not as likely to have problems with the magnetron's magnet losing field strength, as was the case with some Goldstar/GE wall-mount units from the 1990's.
Apr 14, 2014 | Goldstar Microwave Ovens
Microwave runs but does not heat. model number mt1510b All the settings go on and the turn table turns but there is no heat.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
May 07, 2011 | Daewoo Microwave Ovens
Instalation Instructions for Frigidaire Over the Range Microwave 850 Watt Model #FMT118EPB
HI,
Frigidaire makes several over-the-range microwave models that are all installed in the same manner. To install correctly, you must have at least 45 1/2 inches from the bottom of the top cabinet to the cooking surface of the stove to provide enough clearance for the microwave. The top cabinet must also be at least 30 inches wide and 12 inches deep. Find someone to help you, then follow the steps below to install your Frigidaire microwave.
Things You'll Need:
  • Stud finder or hammer
  • Screwdriver
  • Drill
Instructions
Pull your range away from the wall so you can work comfortably. If this is not possible, cover it with a drop cloth. Find and mark the locations of the studs in the wall behind the range. They will be either 16 or 24 inches apart.
Follow the instructions on the wall template to mark the location of the mounting bracket and the four anchor holes on the wall and the bottom of the cabinet. Drill the anchor holes. Follow the instructions on the top cabinet template to mark and drill the two holes in the bottom of the cabinet.
Attach the mounting bracket to the wall studs using the six wood screws included with your microwave. Screw the toggle nuts onto the toggle bolts and push one through each of the four drilled holes. Screw each toggle bolt until the nut is snug against the inside of the wall.
Pick up the oven with your helper. Plug the oven into the outlet and slide the oven onto the mounting bracket arms. Push the oven back against the wall. Tighten the two screws on the microwave faceplate to fasten the microwave to the mounting bracket arms.
Attach the louver to the top of the microwave with the three provided screws. Insert the two top cabinet screws and washers from the top cabinet into the microwave and fasten tightly.
Take care.
Jun 16, 2010 | Frigidaire Microwave Ovens
Daewoo Microwave MT1510B will run for one minute or longer then stop for now apparent reason.It will stay off for 10-15 minutes then when it comes back on it is in spanish language. What is the issue?
Is it new???
If it is still under manufacturers warrenty, then take it back to where you bought it.
It appears to be a fault in the control chip. Not a lot can be done, it may be cheeper to buy a new one. Wallmart have cheep ones.
Jul 03, 2009 | Daewoo KOR-6115 Microwave Oven
Micro wave has come loose from hanger on bottom. Need to know how to reattach microwave to brackets. maytag mmv5100
MOST OF THEM YOU CAN TAKE THE SCREWS LOOSE FROMTHE TOP OF THE CABINET OVER THE STOVE, YOU NEED TO PPL, REMOVE TOP SCREWS HOLD IT AN TILT IT AN THEN PULL IT AWAY FROM THE WALL, MOST WALLL BRACKETS HAVE A HOOK THAT THE MICRO MOUNTS TOO IT 90%OF THE WEIGHT IS BEEN HELD BY THE WALL. GOOD LUCK LEAVE SOME FEEDBACK.!
May 28, 2009 | Maytag MMV5100A Microwave Oven
Wall mounting needed for a top mount microwave/hood combination Whirlpool Model MH2175SB1. The cabinet above the stove is too flimsy to support the heavy microwave (50-60 pounds). Called Whirlpool. Sent me...
Is there a wall behind where the microwave is to fit?
Most of these ship with a mounting plate and instructions for mounting to the wall. In fact, the wall bracket carries about 1/2 the weight, and the overhead cabinets carry the other half. The plates come with a good set of instructions for how to install.
Whirlpool is sending you to a distributor because they have to watch liability in this litigous world we live in..
Jan 29, 2009 | Whirlpool Microwave Ovens
Removing a Sharp Carosel R 1440 over the stove microwave
you should be able to do this yourself. Do you have an outlet to plug this into, or will you need to hard wire it into your apartment/house wiring/. If the former, then you should be okay. You will need a bracket/plate to mount the microwave to.
May 26, 2008 | Sharp R-510HW Microwave Oven
Microwave Oven
You can call Magic Chef in Canada at 866-587-2002.
Nov 15, 2007 | Daewoo KOR-1B4H Microwave Oven
Microwave Ovens Logo
16 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
