Left side dark&verticle lines - Televison & Video
  • 50 Answers
SOURCE: black verticle line on screen of zenith p42w34
I'm sorry you have not been given a clear answer on how to repair your TV. I know how to fix the problem you are having (1.5 inch Black vertical lines that come and go) If you still need help fixing your Plasma TV please feel free to message me @ pleasefixitdave@yahoo.com or just give me a call @ 1-503-432-9904 and I'll help you fix your TV buddy! Ask for Dave! If your reading this post and you have a plasma or LCD type TV and need any type of help please feel free to give me a ring or message me with the problem your having. I'll do my best to help you!
Talk to you later!
Dave :-)
Posted on Feb 04, 2009
  • 441 Answers
SOURCE: Dark lines in background
This may be caused by the electrical outlet, try to run it off a extention cord from another room and see if the lines are still there. If they are you have a loose ground in your outlet. If the line still show them check your cables that feed the a/v signal to the tv. I have had this happen and it was just the outlet, hope this helps
Posted on Jul 07, 2009
  • 10 Answers
SOURCE: one big black verticle line 2 inches from left side...Help
Honestly you have a big problem because the driver IC & Tape Carrier Package inside controller board at vertical area are damage or itself defective could cause you have 2 inches line appear in your display. The best solutions for this replace lcd panel to fix vertical line.
Posted on Aug 25, 2009
  • 453 Answers
SOURCE: Dark verticle line down screen
u have bad lcd panel
Posted on Apr 15, 2010
  • 1156 Answers
SOURCE: THE LEFT SIDE ABOUT 4"
Hi,you might wish to unplug the TV for an hour or more. If this power reset does not allow the TV to turn on component failure is indicated. These sets are assembled using the wave soldering process they are known for having cold solder connections.
The safety circuitry shuts the TV set down or will keep it from turning on when it detects a problem. This model of TV has over 2,000 parts, which includes millions of transistors inside the integrated circuits. The capacitors will change value, leak and become defective. Resistors will change value and burn. Diodes and IC can go bad.
This may have a domino effect and cause other parts to fail. Replacing one defective part may make the TV operate for a short time but the part will fail again if the parts that caused the failure to begin with are not replaced.
The only way to know for sure which parts that are no longer within factory specs and for a proper repair all the electronics must be diagnosed by someone with the correct electronic test equipment specifically designed for TV service and the skills to use the test equipment. I wish I could tell you there was a quick fix or button to push that would fix the TV but that is not the case or the solution needed to get the TV operating correctly.
Most problem of vertical lines on TV set are caused by T-con board.There is a fuse on the T-con board, when the fuse on that board cut, is might cause the vertical lines to appear, So you might need to replace the Fuse..
But if the fuse on the T-con board is still OK,That means you will need to replace the All T-con board and the TV set will be ok..
Good luck..
Posted on Jun 21, 2011
LG REAR PROJECTION TV DARK SCREEN PROBLEM
very possible unit has bad optical engine .May not be worth repairing.Optical engine is complete unit that includes lamp,LCD panels, fans,optics and other parts.They come complete and cost about 3-6 hundred dollars ..thanks
Jul 30, 2009 | LG 62SX4D 62" Television
Black line on left side of paper
It sounds like a cartridge issue. Try changing the cartridge.
May 21, 2009 | HP LaserJet 2430dtn Printer
One big black verticle line 2 inches from left side...Help
Mar 28, 2009 | Mitsubishi LT-46144 46 in. LCD HDTV
There are verticle lines when faxing, copying, and scanning.
This print defect can be caused by a foreign object or substance on the outside of the scanner assembly, usually located on the plastic cover that the paper passes over.
Feb 04, 2009 | Lexmark X7170 All-In-One InkJet Printer
Sony kf50we610 hd pink stripes
That's a good one!
If you're using component video cables, make sure they are good and tight. If it's composite video or S-video inputs, you will likely need service.
Sep 12, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Verticle line on the screen
Hi!!
I think that it's a hardware problem!!
Aug 26, 2008 | Computers & Internet
Dell All in One Printer 962-dark vertical line on photo copies
If you are running your copies through the document feeder then see if the line goes away if you make a copy directly from the glass. If the line goes away then open up the doc feeder assy. by hinging it to the left. Underneath you will find that there is a thin strip of glass that the document passes over when it is scanned. Clean this strip of glass and this should correct your problem. If there is a smudge of dirt or small line, it will come out as a solid verticle line when scanned.
Jul 31, 2008 | Dell 924 All-in-One InkJet Printer
Verticle lines
You should connect your TV to an Active DtH Connection or a Live TV Cable or even to a working DVD/VCD Player etc. and tune it to the frequency of the same and it should start working. If it doesn't, please contact Service Center.
Jun 18, 2008 | LG RU-42PX11 42 in. EDTV-Ready Plasma...
Shrinking Picture
sounds like your main power supplyis going bad . It supose to be 130 dc but I'll bet its down to around 90 to 100 volts!!! its probably the main filter cap or the regulator IC . hard to say without measureing the b+ good luck
May 01, 2006 | RCA HD61LPW42 61" Rear Projection HDTV
Televison & Video Logo
11 people viewed this question
Top Televison & Video Experts
Electro Med Services...
