Question about Nakamichi Televison & Video
Tv have power but not working turning on
The television has power but its not opening..
My Samsung TV HLS4288W shuts off by itself. When I turn it on it repeats with the same, shuts off. I have to repeat this process several times before the TV finally stays on.
There's a loose connection in the power supply of your television.Try to fix this problem.If you want to do the repair,just open the back cover of your TV and look the power supply.Try to resolder the board of the power supply and check the connector to power supply from the board supply.You can power on the televisions while the back cover is open to see that the power supply is working. Thanks!!
Aug 21, 2011 | Samsung Televison & Video
Conia plasma.no buttons work on the tv and the picture does not appear when you turn it on.it shut of one day.the aerial works and the tv has power.
How long have you owned the television. What is the exact model of the television. Once I have more information I can help you further.
Thanks,
Lee
Aug 26, 2008 | Televison & Video
The tv just turned off can't turn it back on tried everything nothing works
Checked Power cable is proper after that remove power cable & open the tv set and checked Power Supply Board.Check AC/DC fuse if its ok than replace that board.
Jan 21, 2010 | Protron PLTV-32 Television
After the tv is turned on a green light flashes more than 8 times and the tv screen never turns on and then a red button turns on but not on the screen.
Power board is dead,open the tv check power board for those capacitors are puff up or bust open.Must know how to solders change these puff up or burst open capacitors.Or buy replaced the whole power supply board at Shopjimmy.com,Ebay.com.
Jan 19, 2010 | Sony KDF-E42A10 42 in. LCD Television
Television wont turn on
Goog day sir, We need to replace first the bad switch, need to unsolder it, find the replacement one and solder it back. You may need to open the back, remove the main board, and replace the bad switch. reassemble the tv and test. Sad to say this but you may do the repairs or hire a person to do it. check you remote batteries they may be almost dead. hope this helps let now your progress.
Aug 10, 2009 | Sharp 27J-S260 TV
I have a 57" 57F500. It will not stay on
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
If ever resetting is no effect then the problem is in the "DM board"
Hope it may help you;
Regards;
VOTIT
Jan 30, 2009 | Hitachi 57F500 57" Rear Projection...
Timer light blinks on and off and tv wont turn on
Resetting the TV
NOTE:
7. Turn on the TV.
The constant blinking green light means that the TV is not booting up. This is a common problem on this set. Hope it may help you; Regards, VOTIT
Sep 25, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Samsung 40" Full HD LCD
Resetting the TV
NOTE:
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 22, 2008 | Samsung LN-S2651D 26 in. LCD Television
Picture gets hung
Resetting the TV
NOTE:
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
Aug 17, 2008 | Fujitsu P42VHA30WS Television
Samsung lcd tv
Resetting the TV
NOTE:
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
Aug 07, 2008 | Samsung LN-S2651D 26 in. LCD Television
Televison & Video Logo
16 people viewed this question
Top Nakamichi Televison & Video Experts
Henry  Thomas
Henry Thomas
Josh Whitehead
Josh Whitehead
Jim Goldsmith
Jim Goldsmith
Are you a Nakamichi Televison and Video Expert? Answer questions, earn points and help others
