Question about Dyson Ball DC24 Bagless Upright Vacuum
Handle will not go in upright position - Dyson Ball DC24 Bagless Upright Vacuum
5 Suggested Answers
AceKiller
  • 7 Answers
SOURCE: No suction in upright position
Check the adapters at the bottom. They're supposed to move cleanly when you lower the handle. It's pretty obvious if there's an air gap when you lower the handle, and you should hear the suction in the air gap.
And...call Dyson...their support is great!
Posted on Nov 07, 2007
  • 83 Answers
SOURCE: handle wont go to upright position
The red pedal has slipped out of position. On both ends of the red pedal you'll see metal rods (the axel of the pedal). On one side you'll see the metal rod sits into a long groove, on the other side you'll see the metal rod sits into a round hole. They both have to be in the long grooves so you have to reposition the rod that's into the round hole by pulling it out and sliding it back into the long groove above the round hole. You'll now be able to bring the handle up and lock the machine back into the upright position.
Posted on Jul 30, 2009
Dysonteam
  • 167 Answers
SOURCE: Placing the handle of my Dyson DC07 into its
Hi its Darran at Dyson.
The brush control is designed to switch the brush bar off automatically when you stand the machine back into the upright position. It is designed this way to protect any delicate floor surfaces when you have the machine switched on and upright and when you are using the hose.
If the brush control should be in the centre position and move forward to the "on" position when you release the head. If it is not doing this, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Posted on Apr 19, 2010
askdyson
  • 2572 Answers
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: beater bar stays engaged when handle of dyson animal 17 is in the up position
    Hi Richard,
    I'm sorry to hear you're having difficulty with your DC17. The issue you've reported sounds very unusual, and we'd appreciate the opportunity to provide further assistance. Please give our customer Helpline a call on 1-866-693-9766 - alternatively, if you email us at askdysonUS@dyson.com , someone will be in touch as soon as possible to discuss this with you.
    We'll look forward to hearing from you.
    Best wishes,
    Jack
    Dyson Online Customer Support
    http://www.dyson.com
    Posted on Apr 25, 2012
    How do i disassemble my hoover f7220
    Hi there! The tanks, brushes, nozzle and handle can be removed from the cleaner by following these quick steps below.
    1. To remove the clean water tank simply grasp the handle and push down on handle to unlock it, then pull the tank out by the handle.
    2. To remove the dirty water tank, slide the latches open located on the sides of the cleaner that hold the tank to the base of the cleaner. Grasp the handle and pull up and off.
    3. For brush removal, with the handle in the upright position, tilt cleaner back until handle rests on floor. Grab brush assembly and pull firmly.
    4. To remove the nozzle, with handle in upright position, tilt cleaner back until handle rests on floor. Pull tab at rear edge of nozzle and pull forward to remove nozzle.
    5. For handle removal simply remove the handle screw and lift up on handle.
    Disassembly beyond this point is not recommended. Hope this helps!
    Jun 05, 2014 | Hoover F7425-900 SteamVac V2 Widepath...
    Eureka 4870 brush won't stop turning in upright position
    there will be a linkage that as come loose and not operating the limit switch to turn it off, try looking at 23. Idler Clamp Assembly on the link below.
    http://www.vacpartswarehouse.com/Eureka-4870-Ultra-Smart-Vac-s/1928.htm
    Jan 27, 2013 | Eureka Smartvac 4870 Bagged Upright Vacuum
    My new Hoover Wind Tunnel Upright UH50000 will not turn off unless I unplug it.
    First I would be sure the handle was properly installed. Remove the two screws holding the upper handle in place and tap it bacwards to remove it. Set the switch inside to the OFF position. Next set both buttons on the handle to the OFF position and re-install the upper handle. If the switch still does not turn the vacuum on and off, the switch will need replacement.
    Apr 01, 2011 | Hoover U6630-900 WindTunnel Bagless...
    Placing the handle of my Dyson DC07 into its upright and locked position causes the beater bar to stop turning. It will not start turning until the handle is first lowered to the working position and the...
    Kind regards
    Darran
    Feb 22, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
    Handle wont go to upright position
    Jun 17, 2009 | Dyson DC25 All Floors Bagless Upright...
    How do you get the handle from the upright position
    there is a pedal on the left side near the wheel press down and lean the handle back.sometimes you have to lean the handle forward while presing the pedal and then lean the handle back
    Apr 23, 2009 | Kenmore 35912 / 35913 Progressive Upright...
    Brush belt
    I noticed the same thing myself. I had set the handle in the upright position, and laid the cleaner on the table to remove the rolloer brush. When I re-installed it I noticed the belt was really loose.
    I checked several things before I finally lowered the handle to the operating position. This tightened the belt up, which makes sense when you stop and think about it. If you sit the handle upright to use an attachment you don't want the roller brush working away at your carpet when you don't need it.
    Placing the handle upright disengages the roller brush by loosening the drive belt.
    Dec 04, 2007 | Hoover U6616-900 WindTunnel Bagless...
    Oct 24, 2007 | Dyson DC07 Bagless Upright Cyclonic Vacuum
    Dyson Ball DC24 Bagless Upright Vacuum Logo
    12 people viewed this question
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Nick Olsen
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
