Question about Oster HDX23 12-Cup Coffee Maker
Clock is on, so clearly there is power, but pushing on button and nothing happens
Have an Emerson MW 8115 SS. Kids have apparently locked in buttons on weight or defrost mode. If I set a time 30 sec. or 1 min. timer will count down but when I push start nothing happens. Is there a reset...
Product manual does not show reset protocol.
http://waterheatertimer.org/pdf/Emmerson-microwave-manual.pdf
There is Child-Lock feature on page 13 of manual, but display will not let you press buttons
Customer service 1-800-909-1240
Unplug microwave and see if it resets.
Press both Stop and Clear buttons simultaneously.
Try different power level by pressing Power button.
It is possible the Start button has gone bad.
Make sure clock is set.
Nov 03, 2012 | Hardware & Accessories
Oven doesn't heat
Hi Sharon Knight - Does any part of the range work? I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another questions, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. A beep will sound. LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Does the clock display "Sd" or "dddd"? If so, the clock is in sales demo mode. Press and hold the "BAKE TIME" button for 6 seconds to exit sales demo mode. If this does not prove to be successful, contact a professional to have EOC diagnosed and/or to confirm that there isn't a wiring failure.
Sep 17, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Our power went out, I need to reset the clock. I can't find my book and it showing 5ab bath. I'm pushing the clock button and nothing is happening.
Hello, Thank You for using FixYa. I will be helping you today.hold the clock button for 5 to 10 seconds..
Thank You and please rate my answer if it was helpful..
Jun 20, 2011 | Ovens
Power button not responding
Customer calls IRobot Customer Service (No Parts or Service Literature is available)
Customer Service at 877-855-8593
Nov 06, 2009 | iRobot Roomba 560 Robotic Vacuum
Accuwave DS Clock
The radio may not be able to get a strong enough or clear enough signal to process (night is best away from TV, computers and radios).  To regain "control" of the clock, take the battery out, wait 30 seconds and then reinstall it.  This will reset the clock.  You can then manually set the clock.
Press SET for a few seconds until the hour starts flashing in the display.  Then press the ADJUST button to set the hour.  Press SET to move to the different functions (Hour -> Minutes -> Seconds-> Month -> Date -> Year) each time using the ADJUST button to correct the setting.  Finally press MODE to exit the setting mode.
If the time zone is incorrect for your area (default is PST), press MODE to enter the Alarm Time Mode; then press SET to flip through the time zones; then press MODE again to exit.
The little "reset" is for use if the LCD display doesn't come on when the battery is changed. It doesn't affect any of the clock settings per se.
Nov 02, 2008 | Audio Players & Recorders
Lg lre30451sw oven the start button doesn't work
This happened to me on Christmas Day morning & it happened once before. I finally remembered how I fixed it. Push the "Clear" button & then push the "Start" & keep it held in until you see the lock button light up (takes awhile) & then push the "Clear" button again. After I did this the "Clock" worked again - reset the clock to the correct time & push "Start" Then click on "Bake" set your temperature & push "Start". Hope this works for you. It got me out of cooking Christmas Dinner, but I fixed it today!!
Sep 25, 2008 | Ovens
LG Range #LRE30451SW
This happened to me on Christmas Day morning & it happened once before. I finally remembered how I fixed it. Push the "Clear" button & then push the "Start" & keep it held in until you see the lock button light up (takes awhile - be patient) & then push the "Clear" button again. After I did this the "Clock" worked again - reset the clock to the correct time & push "Start" Then click on "Bake" set your temperature & push "Start". Hope this works for you. It got me out of cooking Christmas Dinner!!!
Aug 28, 2008 | LG LRE30451ST Electric Kitchen Range
Keeps flashing 12:00
I just kept plugging and unplugging the coffee pot. Eventually, the clock stopped blinking, the buttons worked, and all was well.
Jul 19, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Oster HDX23 12-Cup Coffee Maker Logo
56 people viewed this question
Top Oster Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
richie46
Are you an Oster Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
