Question about Toshiba Satellite Pro 490XCDT Notebook
Where is the start button on saterlight pro
How to start
How do I program a "clicker" brand remote for a genie pro 83 garage door opener?
generally you find the program button on the motor housing, press it once and it should start blinking, then press the remote button, and then press the remote button again and see if it works.
Jul 10, 2015 | Genie Pro Building Materials
Factory reset button on macbook pro
There is no 'Factory Reset' button as such. If you are running OS 10.7 to 10.10, then you need to start up from the 'recovery' partition (CMD+R) on startup. You will then be able to erase the hard drive using 'Disk Utility' and then re-install the OS.
Mar 06, 2015 | Apple MacBook Pro Laptop Computer with...
Surface pro will not start
Please explain- do you mean that nothing happens when you push the power button? Does it show anything at all then go black with the windows button vibrating being the only thing? Is there any error message? Please clarify.
Mar 10, 2014 | Microsoft Surface Pro
MacBook Pro is slow when disconnected with electric charging.
First step would be to Reset Your Mac's SMC
The method for resetting your Mac's SMC depends on the type of Mac you have. All SMC reset instructions require shutting down your Mac first. If your Mac fails to shut down, try pressing and holding the power button until the Mac shuts down, which usually takes 10 seconds or so.
Mac portables with user-removable batteries (MacBook and most MacBook Pros):
1.Shut down your Mac.
2.Disconnect your Mac portable from its MagSafe connector.
3.Remove the battery.
4.Press and hold the power button for at least 5 seconds.
5.Release the power button.
6.Re-install the battery.
7.Reconnect the MagSafe connector.
8.Turn your Mac on.
Mac portables with non-user-removable batteries (MacBook Air and some late 2009 MacBook Pro models):
2.Connect the MagSafe power adapter to your Mac and to a power outlet.
3.On the built-in keyboard (this will not work from an external keyboard), simultaneously press and hold the left shift, control, and option keys while you press the power button. Release all keys at the same time.
4.Press the power button to start your Mac.
Mac desktops (Mac Pro, iMac, Mac mini):
2.Unplug your Mac's power cord.
3.Press and hold the Mac's power button for 15 seconds.
4.Release the power button.
5.Reconnect your Mac's power cord.
6.Wait five seconds.
7.Start your Mac by pressing the power button.
Alternative SMC reset for Mac Pro:
If you have a Mac Pro that isn't responding to the normal SMC reset as described above, you can force a manual SMC reset by using the SMC reset button located on the Mac Pro's motherboard.
2.Unplug the Mac's power cord.
3.Open the Mac Pro's side access panel.
4.Just below the Drive 4 sled and adjacent to the top PCI-e slot is a small button labeled SMC. Press and hold this button for 10 seconds.
5.Close the Mac Pro's side door.
6.Reconnect your Mac's power cord.
7.Wait five seconds.
8.Start your Mac by pressing the power button.
Now that you have reset the SMC on your Mac, it should be back to operating as you expect. If the SMC reset didn't fix your problems, you can try combining it with a PRAM reset. Although the PRAM works differently than the SMC, it can, depending on your Mac model, store a few bits of information that the SMC uses.
Jan 23, 2013 | Computers & Internet
I have an old echostar receiver, but i was going to buy the HD dish Vip 612 DVR. I wanted to knwo if the new DVR will take my saterlight card? and can i manually upgrade my LnB to a HD version?
Hey there, ihacharya! I saw your post and would like to offer you assistance. You are going to need to upgrade your dish satellite to a newer model as the LNBF on the one you have isn't capable of receiving HD signal. You can email me your account number so that I can look into that for you. My email address is michael.lemar@dishnetwork.com.
Hope that helps!
Mar 25, 2011 | DISH Network ViP 612
My dopod 818 pro gets hanged on start up at htc innovation logo....please help
do a hard reset, beware all data will be lost and you need to calibrate screen again.
press two soft keys above call and end button press power button and insert stylus in reset hole,
phone will display some thing press green send button to restore or format.
you are done
Dec 22, 2010 | Dopod 818 Pro Smartphone
The heater wont start got power,got propane ,when i release the push in switch it wont start
YOU WILL NEED TO HOLD THE START BUTTON FOR ABOUT 2 MINUTES, ON YOUR FIRST START UP , TO GET THE FRESH GAS UP INTO THE UNIT
Dec 01, 2010 | All-Pro Propane Garage Shop Heaters - All...
The screen on my Apple MaxBook Pro with 17" display started flashing repeatedly and then went blank. I took out the battery and unpluged it. When I pressed the power button, nothing. I did...
Have you tried starting from the system disks that came with the computer? Put the disk into the computer and start up holding the C key down.
Nov 26, 2010 | Apple MacBook Pro with 17" Display
I plugged in my Pro-Form 730cs treadmill and it won't start.
My i FIT treadmill won't turn on. Is there a reset button somewhere?
Aug 28, 2009 | Proform Quick Burn Pro Treadmill with 12...
Toshiba Satellite Pro 490XCDT Notebook Logo
13 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
