Question about Hannspree 22" widescreen LCD Flat Panel HD Monitor
Display is grainy
How do I fix the grainy display on my monitor?
Lcd monitor grainy display
That means there is a problem with the capacitors inside your monitor. Capacitors basically what they do is to keep power and hold it long enougn for your display. If the capacitor is bulged or it is leaking, then it can no longer hold power long enough for your display. Whta you need to do it to open up your monitor using a sharp long device like a knife and you open it from the bottom working your way to the top. Please take note of the finger-like structures that are holding the two covers together, do not break them because they are the only supporting feature for the monitor covers to hold each other. Then check carefully on the power circut board and look for a bulged capacitor or any that is leaking. That is the faulty one. Take note of its ratings and buy a new one, It will only cost you a few cents to get it. Replace is in the way the old one was installed so that you do not swap negative and positive on the circut board. That is all you need to do
Oct 02, 2013 | MSI Computers & Internet
Compaq WF1907 19" monitor backlights are on, but
Check the monitor on another computer to verify if using correct setting for this monitor will allow a clear image to be displayed.
In windows 7, the monitor should be detected and installed automatically.
What version of windows are you using?
Dec 25, 2010 | HP Compaq WF1907 Monitor
Grainy colors
i have had the same problem with the Gateway LCD Monitor and have found a solution, First go to your control panel Secong there will be a program appearance and theme there you will find something that says screen resolution click it and adjust the color scheme to 1152 by 864 pxels.
May 17, 2010 | Gateway FPD2275W LCD Monitor
Just got a new computer DELL Studio...hooked it to my existing monitor (big W3000 / DELL)when i leave the office & it times out....i come back in & i move the mouse but the computer does'nt cpme...
Tom, try connecting a KNOWN GOOD monitor to your PC. If it works fine for 2 hrs and will recover from "time-out" then I would think that the monitor is having a problem with it's backlighting system. Have you had any problem with black screen while doing constant keyboard and mouse movement? Try adjusting time-out settings under "Control Panel" then "Display" then "Power" and select not to turn off monitor. See if that fixes the problem. 12fixlouie
Dec 15, 2009 | Dell Computers & Internet
I have a Dell monitor and the text is blurry and fuzzy, how do I fix this?
this is actually from dell support website.. hope it will correct your problem...
1 Ensure the correct resolution is set for the monitor. Flat panel monitors display the sharpest, clearest images when set to their optimal resolution. Sometimes games and other programs will change the resolution then fail to set it back once they are closed. This will then make the desktop look big, distorted, and grainy. Perform the following steps to adjust the resolution:
  1. Right-click an empty area of the desktop, and then click Properties. (Or, click Start, click Control Panel, and then double-click Display.)
  2. In the Display Properties window, click the Settings tab.
  3. Under Screen resolution, move the slider to the desired setting. For most flat panels the optimal setting will be all the way to the right.
  4. Click Apply, and then click OK.
  5. If prompted, restart the computer.
NOTE: If the resolution will not adjust to the appropriate settings, the video driver may need to be reinstalled or updated.
2 Ensure the screen is clean. Finger prints and smudges will make the screen look blurry. Clean the screen with a soft lint free cloth. If needed, dampen the cloth with warm water or use a LCD cleaning kit that can be purchased from most electronics stores.
3 Use the On Screen Display (OSD) on the monitor to select the Auto Adjust feature. Selecting this will synch the video signal and can sharpen the video image.
4 Reseat the video signal cable to ensure a secure connection.
5 Use the On Screen Display (OSD) on the monitor to select the Factory Reset feature.
6 Test the monitor on another computer or test another monitor on this computer. If available, testing different hardware will isolate if the problem stays with the computer or monitor
Sep 12, 2009 | Gateway FPD2275W LCD Monitor
Acer AL 1912 (black) resolution issue
[u][b]LCD Monitor Shadow Effect[/b][/u]
This problem is best described as the LCD monitor "Shadow Effect".
The solution to this very simple. No software or hard ware changes required.
The cables that are connected to the LCD monitors are causing the problem. Its also called as electromagnetic noise or electrical noise.
[u][b]Solution: [/b][/u]Keep the two cables - (power cable and moitor display cable), that are connected to the LCD monitor as far away as possible with each other and also away from other electrical cables.
Thats it. Your shadow effect is fixed.
Thank you.
May 27, 2009 | Acer AL1912 19" LCD Monitor
10.4 inch headrest lcd monitors
MOST OF ALL VIDEO OUTPUTS AR NOT STRONG I SUGGEST
ADD A VIDEO AMPLIFIER
Mar 18, 2008 | Car Audio & Video
Hannspree 22" widescreen LCD Flat Panel HD Monitor Logo
Top Hannspree Computers & Internet Experts
justwinwin
Computer Links
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
